PLEASE NOTICE: The latest update 1.5.2 requires you to re-add your device!! This is a one-time issue.
Seams that when you re-add a S6MaxV in 1.5.3 it shows up as S7 instead in homey after connect. Tried two times becuase i thought i clicked the wrong model…
Thanks for reporting! That’s an easy fix, I can name device whatever I want after adding
Guess I added the wrong name in the wrong page. I will edit this!
PLEASE NOTICE: The latest update 1.5.3 requires you to re-add your device!! This is a one-time issue.
And don’t forget to copy your token before removing the device (so you don’t have to find the token again, it’s already in the “old” device settings
hello everyone, sorry to bother you with a simple problem. I just heard about this app today and I’m super happy. But when I put the IP address and the token, it says “Could not connect to device, handshake timeout”. Unable to connect. I have the S6 Pure model. Thanks for your help.
Good morning! Useally the handshake error shows up because of problems with the token. I encountered this error in the very beginning also.
Make sure that you reset wifi soo the ip settings are totally reset (it’s also disconnected from the app), re-add the device and then search for your (new) token. This should work!
In addition to the advice of @justin: has the vacuum cleaner a static IP-adress? I experienced that without a static IP-adress the vacuum cleaner switched periodically between two IP-addresses.
Regards,
Paul
That’s something that your router is doing. It’s probably setup as “short lease period”.
My advice would be to disable this. I do not advice to use static IP adresses since this might conflict in the future, but using the lease period isn’t convienent for Homeys apps!
Edit: using static adresses is always a discussion between IT’ers. Yes, it’s a solution for stuff like this, but it might conflict when you’re adding something else with the same IP. Using DHCP takes care of that.
There might be an issue when the complete network is resetted, but that won’t happen very often.
By the way @Homykit, did you manage to succeed?
Same for me - S6 is added as S7 in 1.5.3…
@Justin FYI, thank you.
Static vs DHCP will always be a discussion, and there is even a 3rd way, which is probably the best of both worlds, DHCP with reservation, that way a device will always get the same IP, but the DHCP server knows this address is taken and won’t give it to any other device
Thank you. I will take care of this in the next hotfix.
The naming issue is solved in test and will be published soon. I’ve already asked for a release.
@Justin may I ask you - is the Flow “Rooms have changed” supposed to be working for S6 ? It’s unfortunately not working for me and yes, I have re-added related Roborock devices.
Diag. log if you see there anything : 0798d972-f7ec-40b0-ba12-126c63df5424
Have you also splitted the rooms in the official Xiaomi app? And gave every room a name? If yes, your log shows a unresolved error… Please try to make a small change in your map and wait for the flow to trigger, see if something happens.
Good hint! Thank you - it was necessary to name the rooms
No it’s not possible within the firmware.
A workaround might be using a logic numeric value, when starting zone 1 set it to 1, when status changes and logic is set to 1; start zone 2… etcetera.
The only problem might be that polling interval kicks in when the vacuum is already back on the dock, and starts from there.
Thanks for your answer.
I’ll use my old app for mopping the floor. If the polling takes to long, homey will think the room is finished (when my roborock has returned to the dock a room is finished).
