[APP][Pro] Roborock Vacuum Cleaners
I’m getting also an error when trying to do a room multiple times or trying to clean 2 rooms in one flow.
I think its the same answer as above.
@Justin
Yes, I succeeded and thank you very much. The problem was that my vacuum cleaner was connected with the Roborock app and not Xiaomi. So I connected on Xiaomi and the code was correct. Thanks so mutch.
Cleaning rooms multiple times is not supported. You are able to clean multiple rooms by using a comma, cq ‘16,20, 23’
It isn’t work for me. I’m getting the same error as when I add multiple times the same number.
No clue, and just a guess, can you order the numbers small to big, so 16,17 or try 16, 17 (i see @Justin uses both in his example, not sure if that was on purpose)
If you haven’t found a way to fix it tomorrow, i’ll setup some tests to see if i can get it to work (but probably Justin will be faster :+1: )
I’ve try to do 16,17 and it didn’t work either.
It’s fine for me for now. Running 2 homey apps for the same roborock. So I can switch when I want to do something different.
What do you mean by two apps? Which one is the second one?
If that app has a way, I can build a way… Do you have a download link?
Yes of course. It’s an app someone made on GitHub. I use this one only for multiple zones and rooms. Here is the download link.
https://github.com/Maxmudjon/com.xiaomi-miio/files/6408030/Roborock_Zones_Goto.zip
Same here the multiple rooms doesn’t work
Hi, connecting a s6 pure works well… But I can’t get it to start cleaning using a flow, in homey status is cleaning but it does nothing… .
Have you tried with THEN-card “Start cleaning” or another card? Is status still Cleaning after 5 minutes? Is vaccum cleaning according to Xiaomi Home mobile app?
Yes, it’s a then-card, after 27min in homey still on cleaning…
Did it say ‘Hi i’m over here’ after connecting?
I will look for this later on and add it with a updateS
Good question, I think it did, created the flow only now after weeks being connected
If you created S6 device with an earlier version of the app you may need to delete it and create a new S6-device.
I think that might be the problem indeed. Try to re-add and please pay attention if the device says hi!
Hi, I removed the s6 pure and readded it… It said ‘hi’… So seems OK, but I can’t do anything with it via homey
Hello!
I have a problem when I try to start cleaning a room. If I for an example try to clean room 01 the s7 is just backing out a few centimeters and then is says “finished cleaning, going back to the dock”
In the xiami app room cleaning work fine.
I have removed the s7 and added it again but it didn’t help. What I’m I doing wrong?
At first you need to name your rooms. Then you try room numbers starting with room 16 and upwards until you find the right room (room number 1-15 are not valid).
If you have the map in Xiamo Home open while testing room numbers, you can see everything except chosen room to be greyed. If wrong room, stop vaccum and test next number, for example room 17.
