[APP][Pro] Roborock Vacuum Cleaners
Should work? Did you acutally use a capital D? Because that might be the problem.
Could you test this flow and see if it returns a status every 60 seconds (polling interval)?
IF new summary available
THEN push/log/whatever all variables
Sorry, i think i didn’t make myself clear, i have a flow with “The vacuum Cleaner is Docked” in the AND part of the flow .
I’m trying to accomplish that the flow can only trigger if it’s not cleaning and on the dock. I could use Stopped, that works, but that status can also mean it’s stuck somewhere I think?
No I understood :slight_smile: The flow I posted showed that the correct status is ‘docked’ instead of ‘Docked’. Try using a small letter instead of a capital
Oh wait now I see… Sorry never mind. It was me that didn’t understand
I can’t, it’s a selection field :slight_smile:
Hmm seems to work here… Try sending yourself the current vacuum status using logic, as shown in my image when I said I understood (lol). What is this returning?
The official model name is S502-00, but I remember that when I bought it it was referred as Roborock v2
In the app I used the S50 Max as it seemed the closer model to mine.
Thank you for trying. Would you be able to spend some time testing the different options this app gives you and let us know the results? The only thing that wouldn’t work for sure is water intensity, since it needs a controller water tank.
If it all works fine, I will add the device to the supported models list.
Think i’ve found what is causing this, if i let it dock through homey it seems to work, when you dock it through the xiaomi app (or when it’s finished cleaning) it does not…or at least not after 5 minutes after docking. Is there a delay in sending that information maybe?
Status of the logic card is in that case “cleaning”
Have you tried this app?
It should support with S50 V1 and V2 (originally developed by Xiaomi) according to information in this forum.
S5 Max is not the same vaccum (developed by Roborock).
Sounds like a possibility! I will try and see if your conclusion is the right one.
Could you please test the summary flow trigger for us? We are actually awaiting test results from somebody else with a S7 to see if it works for them. If yes, we can conclude that the summary will only work on the S7 model.
I might understand wrong, but I think he mentioned that his S50 (V2) was working with this Roborock app using the S50 Max device?
The S5 (V1) should not work with this app.
Sure, can you describe exactly what you want me to test?
Because off the fact that I removed the “is something changed” part in the code, you will get a push message every XX (polling frequency) settings.
Users with a S6 and S6 MaxV are not getting any message at all and I can see errors in their app. Mine (S7) is working just fine. I wish to confirm that your S7 is working fine as well.
Let us see! He wrote it was promising.
Sure, have to update to 1.5 for that, was searching for that card and couldn’t find it lol, i’m on the stable 1.4.2.
Please notice two things; you need to add a new device in order to make this update work (or re-add your device) and it’s not 100% stable. But your doing good in helping us out here :wink:
Yes I get results, sorry didn’t do any markup on the message yet lol
No worries. Thank you for testing! I think I can only conclude that the summary card does not work for other devices then the S7. For now, I will delete the card from other devices but I will keep searching if there is a workaround to get this working.
Interim score …
  • No trigger for the summary
    Solved
  • No trigger when map changes
    Problem found, trying to solve this
  • Problems with setting the polling interval when adding new devices
    Solved
  • Problem with setting the vacuum power
    Not solved and still a mystery
If you could please focus on the last one for me, trying to figure out why this isn’t working? Whe tirggering my S7 i get a “PING” sound and the vacuum power is actually changing, but @Morgan replies that the “PING” sound is working but it is not changing power. Could we check this on multiple devices??
Already resolved too, don’t know what exactly the "docked"status means, is that just on the dock, or on the dock and charged to 100%? In that case it seems it’s 99,9% charged or something, the app shows 100% (Xiaomi), but if you wait a few more minutes the flow works great.
If it’s just checking if it’s on the dock it just sometimes takes a few minutes extra before the status changes, but since that interval is not always the same i’m guessing it’s also checking if it’s charged.
