PS could you send a diagnostics report? Homey > Settings > Apps > Roborock > Settings icon > Create report
Version 1.5.1 model S6 MaxV:
- Edited “Map change detected” triggers every 30 s (polling setting is 30 s). It reports just “0”,“Upstairs” even if I change map to Downstairs.
- “New cleaning summary” do not trigger at all.
I will try. I have no experience doing that.
Regards,
Paul
Received both your reports, thank you for that.
Somewere in the last days somebody posted that he let’s the robot drive towards the dustbin after X area cleaned. I can not find this post anymore. If this was you and you’re reading this; please send me the github repos from the app that could do this. And what model are you using? I guess the S7.
@Morgan and @Paul_Scholte could you both check your Xiaomi app and search for the firmware version of the robot? Please let me know the version number.
@jseverinson didn’t you own a S7?
S6 MaxV firmware 3.5.8_5850
I’m at 4.1.5_1196 … I am guessing that the summary isn’t a option for models older then the S7. I am also getting back response failures in your logs.
Let’s wait for people to react on my questions above to verify my thoughts.
Is “Wash my car” available in firmware for S7? It is a deal breaker for me to buy one.
No you need to take childeren for that.
Solution for the ‘more then one child’ in China… The Xiaomi Robo child S1 is know available on AliExpress
Ok. Thanks for your efforts.
Regards,
Paul
Hi Justin, I can help with Italian (native) and Spanish translations!
Also, I am currently testing the S50 and it’s kind of promising
Interesting that the S50 is supported by this API! What model did you choose to test with? The S50 Max?
Please send me your mail address for the translations. Thank you in advance!
Edit:
Honoured that my app has your first post, lol! Welcome
It’s the S50 V2, pretty much a basic version. I didn’t test all the flows yet but the core actions work!
Thank you! I am quite new to the Homey world, I got my first one about one month ago, but I am slowly catching up with all the possibilities ![]()
What is a Roborock S50 V2 exactly? Is that the S50 Max? Or a Viomi? Looking at released Roborocks I can not find this version.
In my Homey app, which device did you choose to test this with? The S50 Max?
In the webinterface of homey, while trying to setup the device it autocompleted 6 (while typing 60) to 30 (no clue why 30 if 60 is the minimum), but i was also unable to clear out the 30 again to increase to 60. After a few attempts i added 60 behind the 30, giving 3060, after that i could remove the 30.
No clue if this is just in the webinterface of homey or also the app, but might be something to have a closer look at.
Already fixed in my development environment
I will release this in the next test version.
What device model do you have?
I think V2 refers to Generation 2
In the beginning the name was Xiaomi (generation 1 models).
Roborock contributed more to the second generation robots, and got their name on the faceplate. The Roborock Generation 2 was born. After Roborock took over, they re-released the Gen 2 under the name Roborock S5.
Another small thing i found during testing, when i use the card: AND the vacuumcleaner is “Docked” the flow won’t continue, cause apparently it thinks it’s not docked, but it is and 100% charged too.
Tested with Roborock S7
