Could you make me a diagnostics report right after the cleaning is finished? Additionally does the event tab show more info of the problem?
Another way to learn more can be to create a flow for any error that occurred, and then make a notification with the error text (available as tag).
All that should help in finding the issue.
The camera view should show the map. Appearantly that does not work yet. A diagnostics report here is welcome as well. This is best done after a restart of the app, but give it 5 seconds after the restart.
Does the cycles function for the Roborock q10 s5+ work? I’ve managed to get the rooms to function with the ‘Clean rooms” function. But I haven’t seen any one say if this flow is also able to set how many passes or “cycles” 1 or 2 the vacuum does.
Also No one seems to have mentioned that the room number needed to set rooms for the “Clean rooms” flow matches the number originally given to the room during mapping so if you’re having trouble finding them you could remap and find the numbers you need that way. I figured this out because I went through testing the numbers to fast and the sections of the map never lit up before i sent the vacuum a new command
i hope someone can help me. I would like to make a flow like this:
When i come home, and roborock is stuck, the vacuum should say ,here i am". In the homey app i can click “locate” and it will say “here i am” so it should be possible somehow.
I tried with chatGPT and it told me to use the “send … command” flow card and type in “find_me” but this doesnt seem to work.
This worked to get the rooms set up. But not to get the vacuum to do 2 passes. I want to be able to set whether it does a single pass or does 2 passes 1 then another perpendicularly. Seems it hasn’t been worked out yet. Still very happy being able to press a smart button in each room and have my vacuum go to that room and clean! Hopefully someone gets it working though!
Is there anything I can do to keep me from repairing all flows, @KennyMoens? I sent you a diagnostic report with nr de70e632-fa28-40ef-9386-be06f2c5cde2
I have 1 robot - which was repaired by Roborock. But only the mopping module was replaced, so otherwise it should still be the same. At least the wifi-module is; mac (and therefor dhcp IP-address) hasn’t changed.
The app was restarted but didn’t help.
I could remove the device and re-add it of course if you see no other way(?). Would mean I have to repair the flows (with or without the app/script) and loose history. Do you think it is necessary?
When I try to add the robot again, it gives the following error, immediatly after entering my email address and clicking authenticate (either with password and token or with token).
I still wasn’t able to repair the existing device, but was able to add an new (second) device/robot. That way I was able to repair the robot’s flow with the Flow Converter app.
I sent you a new log under nr 083176d7-6432-4d90-bca0-d23ace6e3e29, if you’re interested.
