[APP][Pro] Roborock Cloud - Intelligent robot vacuum cleaners
Hey,
The support for q7 and q10 series robots is incomplete. Room based information is one of these things that does not work properly.
I have to reverse engineer it further to be able to provide support for this. Sadly this takes time, a lot of time.
You can try with the trick for the q10 series:
This is what I did to setup the rooms, hope it helps.
Found the best way for me was to open the Roborock Map as I triggered (Test) each number in the flow card. The map would then highlight the room it was going to and shade the others. Seems to be working as intended. Also figured out that I needed to place the room numbers in the order that I want each room done.
Thanks man! You did save me a lot off headache! :blue_heart:
Hey guys,
I’ve pished v3.15.0 towards test, this includes a number of changes and improvements.
Enjoy,
Hey,
I’ve pushed v4.1.0 to test. This includes experimental support for:
  • Wet/Dry Vacuums
  • Maps for Q7
  • Maps for Q10
All untested, as I do not have access to any of these devices.
Kind regards,
I’m still using Justin Haring’s Roborock app in combination with Xiaomi Home mobil app. It is up to date working good. But the live camera can not be used.
To use the live camera my S6 maxV has to be registered in Roborock mobile app instead.
  1. Is S6 maxV work supported with Roborock Cloud app? I have found a few comments that indicate that this is true.
  2. Is it possible to migrate to Roborock from Xiaomi Home with maps and rooms? I guess not.
  3. If it is possible to migrate how do I do that?
Hey Morgan,
The camera support is not available at this moment. I would have to dig deeper how to integrate it.
For this app to work, your robot must be registered in the official Roborock app. If that is the case it should work straightforward.
Kind regards
Kenny
Hello Kenny,
it’s great that you are so persistent in developing this app! I just tested with a Q7. Unfortunately, it doesn’t respond correctly to flow cards yet, for example, for selective room cleaning. Also, if you tap a room directly, the robot doesn’t respond correctly. Perhaps you can still do something about this. It would be amazing if you manage to get it working! Thanks for your efforts. In any case, I’m making a donation for a few beers. Kind regards, Ad
I don’t see my need for camera other than in mobile app.
Hello Kenny,
following the latest update, my Q7 L5+ vacuum cleaner triggers an error alert every time it finishes a cleaning run. I don’t understand what the problem is, as the Roborock app detects no anomalies. Thank you for your work.
Here is a diagnostic report. : 7502ad6b-df18-4db3-a78e-6e7a24302d13
Hey
@thierry_arguimbau
You mean with v4.1.0? I’ll check it out during the next days.
@AdrianusJ
That might be possible, not everything is reverse engineered yet for Q7/Q10 devices…
Hi @KennyMoens
Have sent you some PM but no response from you for a while.
Hey @Daniel_Fille
I saw your message but did not had time to look into it yet.
@KennyMoens
Hey Kenny just wondering when will version 3.15.0 be pushed out to download Currently only lets you get Version 3.13.1
Thanks
You can use the test url to install it, but it was replaced with 4.1.0 already.
I have to update some graphics to be able to push that one to stable though.
@KennyMoens
ok thanks
on another note i am getting an error when i open the device.
@KennyMoens
The error message no longer appears after changing to 4.1.0 as suggested.
Thanks a lot, worked!
Hello, with version 4.12, my Q7 L5+ works correctly, but at the end of the cleaning cycle, I receive a notification from the device: “Cleaning complete. Returning to dock.”
The app detects a problem, even though it is simply the end of the cleaning process.
Since the Q7 L5+ is not equipped with a camera, an error appears when I check the vacuum status.
