I’ve just removed the clean water tank from the dock and this is confirmed here on the app - unless I’ve mis understood?
The Homey app still reports the tank as attached.
Cheers.
The tank attached in homey is the tank inside the robot, not the one of the docking, if I remember well. I would have to check the code to confirm, but I believe I implemented it that way.
Understood, thanks for confirming.
It is possible to add alarms for the removal of tank/tanks are full? It may be that you’ve already added them but I can’t see them specifically for the Qrevo Edge 2.
Cheers.
Hey @JUUR
You should get alarms when the tank is empty (clean water) and tank is full (dirty water).
Kind regards,
That’s probably because your dock type is not registered yet. It is hard coded. Could you restart the app, wait 30 seconds, and submit a diagnostics report?
Restarted, 30 second-ish wait, diag report: 0a4268fe-540a-477b-930f-56a74ee271bb
Cheers.
Hey @JUUR
Can you test with the test version (v3.13.1) available at Roborock Cloud | Homey?
This should add your dock code.
Kind regards,
Hi @KennyMoens,
The test version worked, I can see the alarms, plus additional buttons for emptying the vacuum and washing mops. Thanks so much for resolving!
Cheers.
Just wanted to share my experience with adding a new Roborock Qrevo Edge.
Environment:
When trying to add the robot in the Roborock Cloud Homey app, device discovery failed with the following error:
“Failed to retrieve the home details: invalid token (code: 2010)”
The robot was already working correctly in the Roborock app.
What solved it for me:
After reinstalling the app, I was able to authenticate with Roborock Cloud and the Qrevo Edge was discovered correctly. The robot has been working normally in Homey since then.
If anyone else gets the “invalid token (code: 2010)” error while adding a new Roborock, this may be worth trying.
Thank you for this, works great!
Hallo Zusammen, ich nutze die Roborock App. Mein 1. Roborock läuft und ließ sich problemlos einbinden. Ich habe jetzt einen 2. Roboter. Ein ich den aber einbinden möchte (Email-Adresse+Toke) kommt immer die Meldung “Invalid Token”.
Was kann ich tun?
Post removed
You need to remove the roborock app in Homey and reinstall and connect it with email and password again, then fill in the token you get on mail. Then all robots in your Roborock app will install on the Homey. Unfortunately the flows with the first robot needs to be fixed with new flowcards, so make a screenshot of your flows before you remove the roborock app
Hi @KennyMoens,
Thank you for your hard work on the Roborock app. I am currently deciding which Roborock to buy, the Qrevo edge 2 or the Saros 20 version. I saw some posts above that, with the latest test version of the app, the Qrevo edge 2 is supported. Is the Saros 20 also supported by the app and if not will it be in the future? This would make the discussion easier because i want it to be in advanced flows.
Thanks.
Kind regards,
Arie
Hey,
Both should be fully supported. The support issues are with the q7 and q10 series.
Mvg
Hi @KennyMoens,
I bought eventually the Saros 20X and added it in my Homey Pro 2023. I found an issue that not all cleaning modes are displayed. When I select the cleaning mode flow card you see 3 options but in the Roborock app I have also the option “vacuum, than mop”. This is missing from the selection. Also when you are in the device settings and navigate to cleaning mode it only shows “vacuum only” instead of all the 4 options.
Hopefully you can look into it.
Thanks.
Hey
I will do so, although it might take some time as I am unable to work on the app the next weeks.
Mvg
Hi Kenny,
Q7 M5
Roborock Cloud v3.12.0
Diagnostics: 450ab228-0b4e-4a56-82cc-64b4dabacfa7
I have two maps:
- Begane grond
- Eerste verdieping
All rooms are named in the Roborock app.
When I use:
Poets kamer → Keuken
Poets kamers → Keuken
-> the robot starts a full clean.
I also tested:
Select map Begane grond
Wait 5 seconds
Poets Keuken
same result.
There is no room autocomplete, no room tags visible and “Refresh room information” does not seem to change anything.
Could you check if room mapping is loaded for this Q7 M5?
Great thanks.
No problem take your time.
If you need me to test anything let me know.
