[APP][Pro] Rika Connect - Monitor your Rika Pellet Stove
Hello everyone!
I’m happy to present my new app: Rika Connect. If you own a Rika pellet stove with Rika Firenet, this app allows you to monitor it directly from Homey!
:fire: Features
  • Real-time Monitoring:
    • View current status (Ignition, Operation, Standby, etc.).
    • Monitor Room Temperature and Target Temperature.
    • Track accumulated Consumption (kg) and Runtime (hours).
  • Daily Statistics:
    • Today: See how much you’ve consumed and burned since midnight.
    • Yesterday: Get a frozen snapshot of yesterday’s total performance.
  • Smart Stock Management:
    • The app automatically decrements your pellet stock based on consumption.
    • Visual “Pellets Stock” meter.
    • Flow Actions: “Add Stock” or “Set Stock” allows you to easily update the inventory when you refill your stove (e.g. via a physical button or just a Flow).
  • Insights:
    • All data is available in Homey Insights for long-term tracking and beautiful graphs.
:warning: Requirements & Limitations
  • Rika Firenet: You need a working Rika Firenet account and your stove must be connected to the internet.
  • Monitoring Only: This app currently focuses on monitoring and does not control the stove (On/Off/Temperature).
:inbox_tray: Usage
  1. Install the app.
  2. Add a new device “Rika Connect”.
  3. Login with your Rika Firenet credentials.
  4. Your stove will be added automatically.
Stock Tip: Go to the device settings to set your initial stock level!
If you find this app useful, please consider Buying me a coffee / Donating to support development! :hot_beverage:
Enjoy! Olivier
Hello Olivier,
Thank you for the app for Rika stoves, but is it possible to add some ‘AND’ and ‘THEN’ possibilities too?
I’m missing the settings for temperature and power in ‘THEN’ and maybe a couple of compare possibilities in ‘AND’ ?
I guess there is a little more work for you to do then?
:smiley:
Hello Havok, great work well done !
Do you plan to do also with MCZ pellet stove ? :slight_smile:
Thank you,
Julien
Hello Olivier,
I still don’t have the ‘AND’ and ‘THEN’ possibilities.
Do you think you can try to get them working too?
Good evening.
Would it be possible for you to publish the application’s zip file so that I can add the control?
Have a good evening.
I’ve created my own version of the app. It monitors but more importantly, it controls the Rika Firenet. Due to the submission rejection from Homey, I cannot put it in the store.
@Havok Are you open for a collaboration or can you put the code into GitHub so I can merge our code bases together?
For those who want to test it, dm me for the link :slight_smile:
Hi
If my program doesn’t control the Firenet (even though it could), that’s by design.
We’re talking about a device that controls a fire, so I decided it wasn’t prudent—for a variety of safety reasons—to allow an unofficial module to control the stove.
Therefore, it is read-only.
Best regards
I’ve published the app that can control your rika stove. Try it out @ RIKA Firenet | Homey
