[APP][PRO] Renault Z.E
Hi, today the connection to the 'ID Connect Europe" from Renault is not working for me, on their official website (Edit : I don’t receive the code by email). I guess that would explain why today (any maybe yesterday) the Device on Homey is not working for me.
Other with the same issue ?
The device is still working for me in homey, but I cannot add another car (invalid login credentials) .
I CAN login at Renault.nl.
But the Kelec iOS app is also not able to authenticate at the moment.
I guess Renault is still changing things :frowning:
I deleted my scenic recorded under the Zoe to save it as megane to see if I had more options. Unfortunately, my credentials no longer work on homey and no longer on the Android app kelec. :sob:
Hey, the Renault website is working again today.
I’ve been able to install and connect to the app on Homey, that’s great!
However, I have the feeling I have no possibility to start the charge via a Card. I can only stop the charge. However it works with the official Dacia application.
I have a Dacia Spring.
Can it be a bug with the Homey app ? I really don’t find how to have the Start Charge working properly anymore.
Thank you !
The developer fixed issues for the Renault Megane with a new version. GPS coordinates and Total milage are working again without adding a new device again.
Thanks Oreste !
Hi @Oreste_Dimaggio , is it possible the Start Charge would not be working in the app (Dacia Spring) ? The stats are here, the Stop Charge is working without problem, but impossible to Start the charge.
Thanks !
Sure let me check what’s wrong…
Thank you so much ! Let me know if you need my credentials
Good evening,
Question regarding the Dacia app. The Dacia app on Homey states that the car is not at home, is not plugged in, and is not charging. None of this is true. It is actually the opposite. Why is this?
The total battery capacity, however, is correct, and the battery also follows the percentage when charging.
Did you check the Renault app first ?
I have the same so it looks like this issue is related to Renault and not the homey app.
i have multiple domotica and those also do not show the correct gps location but was uptodate since yesterday/today.
On my side the official Dacia app is not working fine neither.
I disconnected my vehicle from the app and it’s impossible to add it again.
Before deleting it, it was not showing the right % of battery and it didn’t detected the car was charging.
I hope Oreste_Dimaggio could fix the issue for the charging part on Homey, so I can manage my car this homey instead of the Dacia app.
Edit : actually the issue might be bigger than just my Dacia app, the battery % is not updated neither on Homey right now.
Do you guys also have this issue ?
Hi, I just got a Renault 5 is it possible to connect it somehow?
of course, i’ve got a R5 and a scenic connected like a megane
cool, so just use the megane option to connected it then?
Yes
Just an update : I’ve been able to restore the connection with my Dacia app. Looking at the comments of the app, it seems to be a very common issue and hopefully the days after I’ve been able to restore it just by trying again…
However I’m still unable to start the charge from Homey (but I still can from the Dacia app).
@Oreste_Dimaggio have you been able to have a look to thing, or is it something hard to fix?
Thanks :slight_smile:
Hi guys, i’m on vacation for few weeks. I’ll look at it once i come back home. Sorry about that.
Hello Oreste,
I hope you had a relaxing holiday. Thanks for your work on the App and for adding the Renault Megane E-Tech. I used the Profiles of the Dacia Spring and Zoe before and had some nice Flows working with the given states.
Now to my request… I miss the possibility to use the states of my Megane in the flows (… is plugged in/is at home/is charging etc).
Is it possible to add those states to the available flow cards?
Thanks in advance!
Best regards,
Hubi
Since a while ago my Zoe object show this when opened.
Is it possible to fix without remove and re-add?
TypeError: Cannot read property 'value' of undefined
Component stack:
at DevicePickerControl (address at index.android.bundle:1:5080810)
    at DeviceGeneratedControl (address at index.android.bundle:1:5073120)
    at RCTView (<anonymous>)
    at View_withRef (address at index.android.bundle:1:2470573)
    at SceneView (address at index.android.bundle:1:4870194)
    at RNCViewPager (<anonymous>)
    at PagerView (address at index.android.bundle:1:7549397)
    at Animated(Anonymous) (address at index.android.bundle:1:5690057)
    at PagerViewAdapter (address at index.android.bundle:1:4868494)
    at TabView (address at index.android.bundle:1:4867738)
    at Carousel (address at index.android.bundle:1:5092150)
    at DeviceControlsView (address at index.android.bundle:1:7641363)
    at anonymous (address at index.android.bundle:1:4356319)
    at DeviceScene (address at index.android.bundle:1:5064401)
    at withNavigation(DeviceScene) (address at index.android.bundle:1:7160170)
    at ThemeProvider (address at index.android.bundle:1:3156775)
    at WithThemeDarkComponent (<anonymous>)
    at SurfacePortalProvider (address at index.android.bundle:1:3785195)
    at SurfacePortalBoundary (address at index.android.bundle:1:3785454)
    at SurfacePortalHostWrapper (address at index.android.bundle:1:6555139)
    at StaticContainer (address at index.android.bundle:1:3209543)
    at EnsureSingleNavigator (address at index.android.bundle:1:3184689)
    at SceneView (address at index.android.bundle:1:3208614)
    at NavigationProvider (address at index.android.bundle:1:3185078)
    at RNSScreenContentWrapper (<anonymous>)
    at ScreenContentWrapper (<anonymous>)
    at DebugContainer (address at index.android.bundle:1:3794921)
    at RNSScreen (<anonymous>)
    at Suspender (address at index.android.bundle:1:3791641)
    at Suspense (<anonymous>)
    at Freeze (address at index.android.bundle:1:3791707)
    at DelayedFreeze (address at index.android.bundle:1:3791472)
    at InnerScreen (address at index.android.bundle:1:3789748)
    at anonymous (address at index.android.bundle:1:3791387)
    at ScreenStackItem (address at index.android.bundle:1:3793939)
    at SceneView (address at index.android.bundle:1:4487598)
    at RNSScreenStack (<anonymous>)
    at anonymous (address at index.android.bundle:1:3793911)
    at ScreenStack (address at index.android.bundle:1:3793279)
    at FrameSizeProvider (address at index.android.bundle:1:4461581)
    at SafeAreaProviderCompat (address at index.android.bundle:1:4466001)
    at NativeStackView (address at index.android.bundle:1:4487302)
    at PreventRemoveProvider (address at index.android.bundle:1:3185585)
    at NavigationStateListenerProvider (address at index.android.bundle:1:3210015)
    at NavigationContent (address at index.android.bundle:1:3209870)
    at anonymous (address at index.android.bundle:1:6167690)
    at NativeStackNavigator (address at index.android.bundle:1:4493152)
    at NavigatorRoot (address at index.android.bundle:1:4435695)
    at ThemeProvider (address at index.android.bundle:1:3184785)
    at BaseNavigationContainer (address at index.android.bundle:1:3178027)
    at NavigationContainerInner (address at index.android.bundle:1:3210987)
    at AppNavigationContainer (address at index.android.bundle:1:4412152)
    at ViewManagerAdapter_ExpoBlur_ExpoBlurTargetView (<anonymous>)
    at ExpoBlurTargetView (address at index.android.bundle:1:8410524)
    at BlurTargetView (<anonymous>)
    at AppBlurTargetProvider (address at index.android.bundle:1:3799373)
    at Provider (address at index.android.bundle:1:3168312)
    at RNGestureHandlerRootView (<anonymous>)
    at GestureHandlerRootView (address at index.android.bundle:1:2864869)
    at RNCSafeAreaProvider (<anonymous>)
    at SafeAreaProvider (address at index.android.bundle:1:3170093)
    at ErrorBoundary (address at index.android.bundle:1:6223971)
    at App (address at index.android.bundle:1:4409742)
    at AppContainer (address at index.android.bundle:1:2618992)
Stack trace:
    at DevicePickerControl (address at index.android.bundle:1:5081334)
    at renderWithHooks (address at index.android.bundle:1:2505295)
    at beginWork (address at index.android.bundle:1:2537196)
    at workLoopSync (address at index.android.bundle:1:2554362)
    at renderRootSync (address at index.android.bundle:1:2554197)
    at performWorkOnRoot (address at index.android.bundle:1:2551081)
    at flushSyncWorkAcrossRoots_impl (address at index.android.bundle:1:2499398)
    at processRootScheduleInMicrotask (address at index.android.bundle:1:2499793)
    at anonymous (address at index.android.bundle:1:5582666)
That’s a bug in the Homey mobile app. It should be reported to Support:
