I also have issues on SHS, but seems only with images or other then text. text only works fine
Hi SHS users, can you please try out this version:
Please submit the output here - value of the error-message.
I suspect the way Tokens are treated differs for SHS and hosted.
Everyone else, do not install this test-version - ITS BROKEN (ON PURPOSE)
I expect the message to contains two url (one most probaly).
Please also insert the url in your local browser - should be accessible to you only.
BONUS: If you have a login, you can check if your image is here:
When you generate an image - the image should be available in this page. We might need to check this out, if my debugging does not give us enough information.
@EdP @BigSniffer @Mike_de_Vries give me your feedback.
Just installed and tested. Got an error I never got before
URL:(http://192.16x.xxx.xxx/api/image/934575e0-7b1d-42e4-989c-55adb8ca6a5a) ### (https://xxxxxx.connect.athom-prod-euwest1-001.homeypro.net/api/image/934575e0-7b1d-42e4-989c-55adb8ca6a5a)
The first URL gives an error, not found, and the second part shows the image.
I have x-ed out my ip and id in the links above
Hi, can you please try this version: Pushover | Homey
Go to settings (settings of the app) and enable: Cloud Url
Then restart the app and try again.
Yes for me this is working, I can test and add an image and that works again!
Release is live now.
Itās working now! Thanks!
There is a very useful API parameter, āTTLā which defines the number of seconds until a message gets automatically deleted. https://pushover.net/api#ttl
Could you integrate this parameter? Or is there any other possibility to use this parameter?
Thank you!
Hi @widameista
The feature have been implemented. Iāve put the option under Settings of the app.
All the features are kinda advanced, and for some hard to understand, so not to confuse to many already and this feature is optional. Not to mess up all the cards with another parameter - this is now available under settings:
Thank you, but under settings it means that it is valid for each message?!
This is not intended! The idea is that you set ttl for some scenarios where you donāt need the message that long.
But it should be at message level like priority.
Is this possible? To have an extra parameter at message level?
thanks again
Okay, itās just the way Homey is designed with cards, all 7 variants of cards must be updated. With feature bloating parameters - with Homey attending to be simple and Pushover kinda advanced.
I will make TTL available in all cards.
Check the test version: Pushover | Homey
One option would be to have some extra advanced cards with TTL, and not to include them in the current once?
perfekt, works like a charm and i like, that the parameter is not a must, so it does not break existing flows!
I agree with both of you. Its just a lot of features/options that Pushover supports - it does not goes well with Cards.
Another Question:
i use different applications in Pushover, mainly to get different Message symbols.
In homey pushover i can only setup one single application.
Is there any way to use another application beside implementing in in homeyscript?
Thank you
@widameista
Sorry for the late response. The app is global, so unfortunately not. It will require development/funding and breaking changes, to do so.
As of now, the app is locked to single license only.
New version available in the store. Updated packages.
