This is how I have done it for Tibber in Sweden. I take the current price from tibber, add the fixed cost from my distributor that is a fixed cost per kWh and one for tax per kWh, then add that price to a variable that I can use in other flows and last update the price that PBTH uses. It updates every hour and is correct +/- a few kWh and SEK per month.
You also have to add the fixed cost for the Total Summerizer, that is 39SEK/month from tibber and 405 EK/month from my distributor, total of 444 SEK here:
If this was what you where looking for :slight_smile:
Amazing!! Thank you very much.
I was close, my “vaste opslag per kWh” was on 0,17014965.
So I must have forgotten a tax or something somewhere!
Cheers.
You can indeed use the current price from the Tibber app. But when you setup DAP in PBTH you have all future price as well, and all the good flowcards that come with that :slightly_smiling_face:
Searched most of this thread and tried a lot myself, but didn’t found the answer to my question.
Is it possible to create a flow that sends me a notification x hours (e.g. 3 or 6 hours, adjustable) before the absolute lowest price? To be honest, I don’t understand the meaning or function of some of the available flow cards either.
https://homey.app/nl-nl/flow/-MHEiO/
The app has so many flow cards itself that I (an old stager) didn’t even thought about using a logic card. :man_facepalming:t3:
Thx Robin and have a great Christmas!
new version 5.9.3 is ready for testing: Power by the Hour App for Homey | Homey
  • SUM: ignore unrealistic meter values.
  • BAT: added energy value settings.
  • DAP: added price ranking.
  • homey-api@3.4.9
Ignoring unrealistic meter values will hopefully get rid of the spurious large negative usage that Shelly devices are sometimes reporting. But I don’t have Shelly myself, so no way to test it :slight_smile:
The other features were requested by @Torch1969. Hope it works :wink: Enjoy if it does!
Edit: I did notice it is not possible anymore to add a new SUM device. Will be fixed in next test release.
Great app, and impressed of what you have made.
Could you please help me with my post from 5 days ago? I do not know what is being done wrong…
Dont know. Cant read your flows. Most people that use vurtual device mistake power (Watt) for energy (kWh). The data needs to be in kWh.
But does the source app have electrical energy (kWh)? If so, what is the capability called in Homey? I could add support natively in PBTH.
Thank you for your support.
I did add a picture of my flows, but you might not see them?
I send energy used last hour in kWh to the virtual device through send power function.
As far as I know I do send data in kWh
Native support would be fantastic. Data is drawn from the homey app MyUplink made by @frodeheg
It should be total electric energy ever used, not just from the past hour. But maybe it already works when you enable ‘resets to zero’.
Thanks.
The power meter do only report energy used in kWh the last hour. It does not show total energy used, so this is why I try to use PBTH to get daily, monthly, and yearly usage only for this device.
Do you mean reset to zero each hour, since I send new data for used kWh last hour every hour
Merry Christmas
That wont work then. Ask the app developper to add a meter_power that provides the total electric power in kWh that was used in total (e.g since unit was installed or since app was installed)
A major new version 6.0.0 has been released as test: Power by the Hour App for Homey | Homey
  • BAT: Completely new ROI strategy flow.
  • BAT: Deprecated old ROI flow card.
  • SUM: Fix paring new devices.
I have been working on and off on this version for a few months now. It introduces a completely new way to calculate the best Battery ROI strategy. I had to learn how to model a Linear Programming Solver, and find a solver that I can use with Homey. And I’m really happy I was able to create something that (as far as I tested) works extremely well!
With this new ROI method the battery will be able to use a number of (dis)charging speeds, depending on the efficiency of a certain speed. So in the Battery device settings you need to set some extra (dis)charging values, with the accompanying losses in efficiency. Per default the Sessy Battery speeds/efficiencies are available.
The ROI calculation is performed using a THEN card (only available in advanced flows). The card produces the best actual charging power:
  • 0 Watt: do not charge/discharge
  • Positive Watt: Discharge the battery with the given power
  • Negative Watt: Charge the battery with the given power
Also available is the optimum duration (most often 60 minutes when you start it at the beginning of an hour) and the SoC after this duration. For hackers amongst you the full future strategy scheme is available as JSON.
The calculation is pretty CPU intense. Running it will use 100% of Homey CPU for a few seconds. So don’t use it too often :wink:
This is a major change, so I will not release it until some of you have tested it and have given feedback.
And yes, when all is good and I have too much spare time, I do have plans to show the strategy as an image in the battery device.
There is always more to want…:face_with_hand_over_mouth: I’m really glad I managed what it does now :sweat_smile:
But the fun with Homey flows is that you can build your own seasonal switching between ROI and XOM😜
Do I force it to start on the hour, and once an hour when using ‘ the price has changed’ in the advanced flow ?
I’m still working that out myself. I think best is to trigger it at the start of every hour, with some delay (say 30s) because at the start of every hour Homey is already quite busy. So not use the ‘price has changed’ as trigger (since price could stay exactly the same between hours)
New version 6.0.1 is available as test: Power by the Hour App for Homey | Homey
  • BAT: added support for Sonnen Batterie app.
  • BAT: Added new ROI strategy trigger card.
The new ROI trigger card makes running an ROI flow even simpler. Just 2 cards required! Also, this card is available for non-advanced flows as well :tada:
The card gets triggered automatically when a new hour starts. Off course it will only be triggered if you have coupled Day Ahead Pricing to the PBTH battery.
https://homey.app/f/tPdYHO
@Paul_Scholte Many thanks for your kind donation. Much appreciated! :heart: :beers:
TestFlow created to monitor this new functionality for a while :grinning::+1:t2:.
