[APP][Pro] Plugwise App by Plugwise [Adam, Anna, Smile P1] [v3.3.0]
Got a new router and the fixed IP address of the Adam changed. Homey can’t connect now. Can I change the IP in the settings to fix it?
Adjusting the IP of the Adam is something you would need to do in the settings of the device itself, not within Homey.
You could try to restart Homey.
The Plugwise Aram will send a discovery announcement on the network (if Homey is in the same network), which should be picked up by the Plugwise app and it should update the IP address automatically.
Recently I moved from Homey 2016 to Homey-SHS (+Bridge). I am unable to add my SMILE P1 to that Homey installation.
I do get a plugwise icon in the discovered section when you add device.
When I try to add a devices via the Plugwise app in homey, I get “No new devices have been found”.
  • I have reset the device
  • Device is up and running in the same network (on LAN or Wifi)
  • Device is available via the plugwise app v3.2.0 (on LAN or Wifi)
  • Plugwise support desk (Ticket 80135) has access and cannot find any issues
Does anyone have any ideas?
It shows this in the log when I try to add it:
Homey [log][ManagerApiLocal] IO homey:manager:apps:installFromAppStore
Homey [log][ManagerAppsLocal] Installing app from app store… com.plugwise.adam@null-live
Homey [log][ManagerAppsLocal] Got app details from app store com.plugwise.adam@3.2.0-live
Homey [log][ManagerApiLocal] IO homey:manager:apps:installFromAppStore → Success 204
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Stopping…
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Exited. Code: 0, Signal: null
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Stopped
Homey [log][ManagerAppsLocal] Deleted app before before installing from app store
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Preparing install…
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Starting download from “``https://apps.homeycdn.net/app/com.plugwise.adam/14/cd488f22-222c-4da4-8038-4a65002dfac4/42f21b48-abc2-443a-96c1-bebbd119ba1e.tar.gz”…
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download size: 3917830 bytes
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Downloading…
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 10%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 20%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 30%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 40%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 50%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 60%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 70%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 80%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 90%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Download progress: 100%
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Downloaded
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Installed
Homey [log][ManagerAppsLocal] Created app, starting…
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Starting…
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Session ID: com.plugwise.adam-3.2.0-2a32af2f
Homey [log][ManagerDiscoveryLocal][DiscoveryStrategyMDNSSDLocal:e68ab8f2-5f28-477e-993b-ad5734f9f828] Init mDNS-SD Strategy: _plugwise._tcp
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Child process spawned successfully
Homey [log][ManagerAppsLocal][AppLocal:com.plugwise.adam] Started
but it still states that it cannot find anything new….
i’m working with plugwise as wel and i want to make a request if it is posible on the homey app to change settings in the Adam modul.
you can only change setting in the Adam wel you are on the local network and it should be nice if i can change settings if i am not on the local network.
i mean the setting you find under the tap setting, heatingsystem, heating, advanced settings.
i like to change the settings for ketel temperaturen and tapwater
another request, is it also posible to make a insight for the pressure ?
because than i can set a notification if the pressure is to low
Edit 24-1-2026:
I’m using the homey app to set my room thermostat at the themeratur i want, but the plugwise app to control the tom radiator opner.
some time i hear the tom opening but the widget on my dashboard is not chaging to the stat of heating.
And i if look on the plugwise app it says it is heating. Is there some comunication missing?
This always happens when the room temperatuur and the theremostat temperatuur are the same.
Tapwater on/off. Plugwise Anna thermostat, feature request to include a “When” action on tapwater events, so I can use it in flows.
Version 3.3.0 has been release to the app store, pending Athom’s approval:
Plugwise v3.3.0
Requires Homey v12.0.0 or newer.
:warning: Check your flows
  • Adam boiler: the read-only max boiler temperature and domestic hot water setpoint values are removed. Both temperatures are now settings of the boiler device (see below). Flows that use these values need updating.
New device
  • Central heating boiler (Anna): boiler state, hot water state, modulation level, supply, return and outdoor temperature, water pressure, status and error codes and the hot water comfort mode.
New capabilities and flow cards
  • Adam zone: new zone state that shows whether the zone is off, preheating, heating or cooling (also error and bleeding hot / cold). Use it in flows with the zone state changed to … and the zone state is ….
  • Anna and Adam zone: new flow cards the scene changed to … and the scene is …, for example to set the scene back to away when a window is still open.
  • Adam and Anna boilers: new flow cards set the maximum boiler temperature to … °C and set the maximum hot water temperature to … °C. Values outside the range of your boiler make the flow card fail with an error.
  • Adam and Anna boilers: new flow cards hot water turned on / off and hot water is on, for example to switch on the bathroom fan, and boiler turned on / off for heating and boiler is heating.
  • Adam and Anna boilers: new flow card boiler reports an error, with the error code and status code as tokens, for example to send a notification.
New settings
  • Adam and Anna boilers: set the maximum boiler (supply) temperature and the maximum domestic hot water temperature from the device settings in Homey or with the new flow cards. The settings follow the values on the gateway, and values outside the range of your boiler are refused.
Fixes and improvements
  • Plug: the energy meter now keeps a running total instead of showing only the last quarter of an hour.
  • Lisa, Floor & Tom and boilers: battery, valve position and modulation level are shown correctly on newer gateway firmware.
  • Adam boiler: correct hot water state, water pressure and outdoor temperature, and the set hot water mode flow card works again.
  • Smart plugs connected to a boiler: paired as a plug, no longer as a boiler.
  • Anna pairing: the Anna ID is no longer case sensitive, capitals from the phone keyboard are accepted.
  • All devices: more reliable reconnection to the gateway after a restart or an IP address change.
  • App: available in all Homey languages.
