[APP][Pro] Net Connect App: Discussions and Feedback
I have just released the Net Connect app. Unfortunately I do not have a lot of time to offer support but did want to make it available to others who are looking to solve the same “problem” of wanting to integrated network connected devices that do not have a dedicated app. As homey script does not support / offer Net communication support I’ve created this app. The App offers Wake-On-Lan, TCP and Sony SDCP Support / Communication…
Personally I use it to control a Sony Projector and a MadVR Envy video processor.
Hope it is useful to others. Feel free to comment in this thread.
(but again no promises :wink:
Jeroen
In a future release, you might want to link this topic in the app.json. This way the community topic can be found from the store page of your app.
Yes that is planned, did not want to create a topic before releasing something. Will add it in the next release - thanks
Some explanation on the settings. You have per device two buttons. Currently labeled “On” and “Off” which you can enable and add your commands to in the settings of the device. Some examples:
The buttons
Some setting samples.
There is also the option to use these in a flow, or send a custom command in your flow (or script), where you set the Protocol ( Wake on LAN, TCP, or Sony SDCP) and the command to send. If you use wake on lan the command (field) will need to have the MAC Address of the device.
That is basically it. I was thinking to make the button labels also custom so you could use it for something else as well but not sure if the is a desire/need for that. (For myself not so much).
Hope this was helpful.
I’m trying to automate: the SR-201 relay controller powers an “On Air” studio sign that toggles between RED and GREEN using simple ASCII commands (e.g., 11, 12, 21, 22). It expects multiple commands to be sent in sequence, within the same TCP socket session, and without any terminator characters like *.
At the moment, Net Connect opens and closes a new socket for each command, which causes the SR-201 to ignore or reset part of the sequence. Through testing and packet analysis, I’ve confirmed that the Windows application which successfully controls this relay:
  • Sends plain ASCII commands like 11 and 12 (no *)
  • Keeps the TCP connection open for both commands
  • Gets stable results this way (e.g., 11 powers the sign, 12 sets it RED)
    Would it be possible to add options to:
  • Send multiple TCP commands in one socket session
  • Optionally disable the * terminator
  • Or include a raw mode that lets us define the exact ASCII payload?
    I’m happy to share packet captures or provide any further details. This would make a huge difference to hobbyists integrating older or fussier gear like the SR-201.
Hi there,
Can your Net Connect app open up a telnet session and send a command strings to a unit over LAN from a flow within Homey Pro? I need to send this command “DEVICE recallPreset 1007” after establishing the Telnet session to an audio digital processor manufatured by the renown www.biamp.com company.
Hi! Would it be possible to include the option to send a WOL outside of the home network? I have this working with a Wake on LAN app on my phone. This app does not have an internal IP configured but instead, the Hostname/IP/Broadcast Adress is the external IP
Hello! Thank you for this app, it really helped me out! I couldn’t switch my Epson beamer on and off with ESC/VP21 commands, but PJLink works. Just in case someone else struggles with the same issue, I wanted to share my settings.
Use port 4352 for PJLink and %1POWR 1 for Power ON and %1POWR 0 for Power Off.
Hope that helps!
Hi I have a Emotiva RMC-1.This device apparently uses UDP to recieve commands.
Is it possible to add this to Net Connect?
I’ve been trying to add this app to my Self Hosted Server. After clicking the Install button, a window pops up saying that the app will install shortly, but then never does. Am I missing something?
I found that you can’t install via the Web App, you must do it through the phone app.
Hi!
I’m trying to control a Sony VPL-VW500ES projector using Net Connect through SDCP, but I keep getting a “Timed out” message.
  • TCP connectivity to the port works from my Mac.
  • An SDCP GET power-status command works from my Mac:
    020A534F4E5901010200
  • The same command sent through the Net Connect custom-command Flow card times out.
  • The SDCP power ON command also times out:
    020A534F4E59000130020001
What do I do wrong? Is there any specific other command I should send, or are my settings wrong?
Hi JC,
Below is what I’m sending (Created as Device / Button). Hope that helps:
Kr,
Jeroen
Thanks for the quick reply Jeroen! Now I got a reply, but still not functioning Power ON/OFF.. Which Projector model do you have?
//Cave
I have the VPL-XW7000
It has been quite a while since I did this, the projector settings itself are important.
Did you activate remote control. I think you need PJTalk and maybe another one:
