You should be able to add a gateway and 2 soil moisture sensors according to the log.
Yep, it worked now. Thanks man!
Hello, my device has stopped working 6 days ago: It is an Ecowitt WS90 with the GW1100A gateway. It worked like a charm, but for the last 6 days it has stopped working. They are no longer receiving data . The Station is online and the own App is working seamless.
Any ideas?
P.S: Both Devices are showing in the App!
All I can suggest is to check the IP address of Homey hasnāt changed and the gateway is reporting to the correct one.
Okay, thanks for the quick reply! I will give it a try.
It seems that I could not change the Ecowitt settings - do you know this problem?
Iām not aware of any issues with changing settings. I presume you mean the settings in the Ecowitt hub?
I installed the Ecowitt app on my old Samsung 52s, and now I see, and put all the needed information in the app. Itās working great!!!
Yes exactly
Seems like a great app. Iām in the search for a proper weather station and the WS90 with a WS39xx gateway caught my eye. Can you confirm this will work with this app? I see itās not listed as supported.
It would appear to be compatible looking at the specifications.
Hello Adrian,
The Misol / Ecowitt app in Homey Pro is working great, Thank you for this great app. I have made a Dashboard for my garden. Its amazing.
Good evening, since 4 days it works like a charm again - I guess, that the device had a few updates⦠thx for the support !
@Adrian_Rockall @TK1 Have you found a solution for the āWhen it starts rainingā trigger? I have the same problem: I want the awning to close immediately when it starts to rain. I canāt get it to work.
I found this documentation: "The WS90 and WS85 now have a rain start detection (detection of first raindrops) implemented. The GW2000 is the first console where this feature is implemented with firmware 3.1.5 - other IoT-enabled consoles to follow. In the customized server post string, the observation will show as srain_piezo
it can have the status ā1ā - raining or ā0ā - no rain
status 1 will be reset to 0
- once the top is dry
- after the amount of water on the top has remained unchanged for two hours"
I think you have to update the app to use this, right?
@Adrian_Rockall Iāve some trouble adding a device to my homey. might be doing something wrong.
Homey Pro 2023. GW2000 gateway LAN to same switch as Homey and WS90 as sensors
I installed the Ecowitt app on my phone and run the installation process
I installed your app to the Homey
When I try to add a device and sellect gateway it wonāt find any
Am I missing a step?
Have you setup the gateway to send data to Homey as described in the first post of this topic?
Can you send the Diagnostics Log.
Thereās no guarantee the Auto will work if Homey doesnāt get an acknowledgement to the broadcast.
So if you can manually setup the gateway to see if it works then.
got it working now.
It was not clear that I also needed the WS view pro appā¦
After setting that on up it worked
