Thanks the idea, I also installed the NetHome Plus, registered the AC there, after added in Homey - after I filled out the username and password, I got the key+token (automaticly), and on the end SUCCESS. ![]()
This is my diagnostic code: e7076107-feda-48bb-86c5-fd12dfcc8bb0
I am trying to add a Midea MAP10HS1WBL. But it only says “Error while adding device”. Any more ideas? I would be happy to diagnose if I could see the log file.
I used the NetHome Plus app. It filled in my credentials automatically, it just errors at the last stage.
In the console, it says this: Connectivities: [‘lan’]
It tried it with both the default creds and my own credentials from NetHome Plus.
Hi Marc,
I have a Midea Cube dehumidifier that I would like to add to your Midea HVAC Solutions – Smart Climate Controls app.
Device details:
Model: Midea MAD20S1QWT
Device type in Midea SmartHome app: Dehumidifier
SN: available if needed
Plugin Version: 2.2.2604242
My setup:
Homey Pro 2026
Firmware: 13.4.0
Midea HVAC Solutions – Smart Climate Controls app: v1.0.18
The dehumidifier is fully functional in the Midea SmartHome app. I can read status and change settings without any issues.
When I try to add a device through your Homey app, the pairing process immediately only offers “Air Conditioner”. It does not discover or offer a dehumidifier device type.
Would it be possible to add support for Midea dehumidifiers, or is there any additional information you need from me to help with adding support?
Here is how the SmartHome shows the dehumidifier
And here is what is shown when trying to add a device in the homey app.
Thanks for your work on the app!
Hello, this app previously worked for me back in January when I first set up my Homey 2026. However I am trying to re-add my Midea A/C. And it errors out adding the device.
I have added the device successfully to Midea App, NetHome Plus, and the migrated mSmartHome. But unable to add to Homey as none of them connect after it pulls token/key.
I am also using the python script to gather token info, which only seems to return data when in Midea/NetHome ecosystem. However there is now Token/Key data in the results.
Is there a way to pull the token data from mSmartHome app? I just get an error when trying to use the --app msmarthome argument.
I have problems adding my Midea Porta Split to Homey Pro 2026.
It can not be found while I try to add it as a new device.
The PortaSplit is already added to the MSmartHome app and can be controlled there without any problems.
I have verified that the issue is not network connectivity:
Homey Pro and the PortaSplit are on the same local network.
The PortaSplit has a reserved DHCP address.
I can successfully discover and communicate with the unit locally using
msmart-ng. -
The unit responds on TCP port 6444.
Local authentication succeeds and the device state/capabilities can be read successfully.
The local query shows that the unit is online and controllable.
In the Homey Midea pairing flow, I do not see any fields to enter the IP address, device ID, token, or key manually. I can only run the automatic discovery, which finds no devices.
Could you please advise:
Is the Midea PortaSplit supported by the current Homey Midea app?
Is there a manual pairing method for devices that are reachable locally but not detected by Homey discovery?
Is there a beta/test version with manual IP / device ID / token / key entry?
Would a diagnostics report help, and if so, where should I submit the report ID?
Thank you for your help.
I tried PR#19 as well, thank you for all the hard work, however it did not resolve my issue.
After some research it seems my problem is that I have older V2 wifi dongles for the 3 Midea AC units that were not recognized by the app which do not need token and key on the LAN. The newest one that worked initially returned both when checked via msmart-ng.
So I made some changes to the drivers.ts which helped with the discovery, however when I tried controlling them I was still getting errors so I also had to update the LanConnection.js to handle messages with no token and key.
I have not tried creating a NetHome-Plus account.
Edit: since V2 devices do not require Cloud for LAN control I asked Gemini to help me create a simple Homey Python app based on msmart-ng. So now I use the community app that was last updated in 2025 for the V3 device and my own app for the 3 older V2 devices.
14707352-65ec-4fbc-b289-2915f8daea86
Im purchasing 2x Midea 3.5kw Athena air conditioners and having them installed in a few weeks. Just reading the recent posts and reading up on the smart app it appears there are 2 apps Midea has for air conditioners msmarthome and nethome. Has anyone set up Midea Athena air conditioners with homey? From what I’m reading it appears either the msmarthome app or the nethome works better depending on the model. I assume the msmarthome app will provide firmware updates versus the older nethome app? But what would work better for the model I’m about to have installed?
I have 2 Qlima, i.e. Midea ACs. I can control them from the NetHome Plus app.
I want to control them from my Homey Pro as well.
The Midea app discovers 1 of my ACs and trying to add it I get error adding device, irrespective of whether I use the default account or my own.
As proposed in earlier posts I installed GitHub - nbogojevic/midea-beautiful-air: Python client for accessing Midea air conditioners and dehumidifiers (Midea, Comfee, Inventor EVO) via local network · GitHub and run:
midea-beautiful-air-cli --log DEBUG discover --account <myaccount> --password <mypassword> --credentials, with account and password from NetHome Plus.
In the output I see it discover both ACs, crash on getting device capabilities for one AC.
The other AC I see:
DEBUG:urllib3.connectionpool:https://mapp.appsmb.com:443 "POST /v1/iot/secure/getToken HTTP/1.1" 200 None
DEBUG:midea_beautiful.cloud:HTTP response: *** REDACTED ***
DEBUG:midea_beautiful.cloud:Ignored error: '9999' - 'system error'
DEBUG:midea_beautiful.lan:Error identifying appliance Too many retries while calling /v1/iot/secure/getToken, last error system error (9999)
How to debug? Get either the Midea app to install, or get the token and key for my AC’s?
Thanks, Onno
Hello Marc,
I’m trying to add a Kältebringer KB35-QC (12,000 BTU / 3.5 kW) air conditioner to Homey Pro 2026 using your Midea HVAC Solutions app.
The device is successfully discovered as AirCon_713E.
It is configured and working correctly in the NetHome Plus app. I leave Token and Key empty and use my own valid NetHome Plus credentials. The app then retrieves the information, but at the final step I always get:
Device firmware: V.092122
Homey: Homey Pro 2026
Midea app: v1.0.18
NetHome Plus: used successfully
Diagnostic report ID: 6D460A54
Could you please check the diagnostic report and let me know whether this Kältebringer model is supported, or whether there is a problem retrieving/using the token and key for this device?
Thank you!
