@Rammstein not a stupid question at all. Athom’s Homey MCP is a good way in, and if switching things and asking questions is all you need, it does the job. Where the bridge goes further is exactly what you use it for: building and checking Advanced Flows.
Flows
every card is looked up on your own Homey, so the model only uses cards that exist, with the right ids and arguments
advanced_flows_diff shows card by card what an edit would change before anything happens, and a copy of the flow is kept before every edit
flows_repair_suggest looks at a broken flow and proposes the card that most likely replaces the missing one, with how sure it is
flows it builds are laid out in columns (when, and, then), not stacked on top of each other
in ChatGPT and Claude you can see the flow as a drawing before it is created (ask for panel_flow_preview)
Control over what the AI may do
Permission levels per key, so ChatGPT can for example switch things but not change flows. Guardrails, like “never unlock the doors”, confirmation for irreversible actions, a log of everything it did, and undo for the last change.
Beyond the chat
A model can answer inside your flows (choose an option, give a number, decide which flow to start), you can talk to the house from Telegram or WhatsApp, it can speak on your speakers, and there is a dashboard for a tablet.
One honest note for your setup: ChatGPT only takes your own MCP server with Plus or Pro and developer mode on, and the bridge then needs a public HTTPS address. The Remote tab sets that up with a free DuckDNS name and one port forward. If you’d rather start simple, Claude Desktop on a computer connects on your own network in five minutes, and with the same Remote setup the free Claude plan also allows one connector for the phone app.
So the step forward I’d suggest: install it, connect one assistant, and ask it to check one of your existing Advanced Flows. You’ll see the difference there first.
@weide43…many thx for your great reply and your time which you invest to explain some details i really appreciate it!..now its more clear for me and the rest i will see during my tests, i had already installed the bridge …
To whoever sent a diagnostics report about rooms and “Missing Scopes”
Thanks for the report, it showed exactly what went wrong. Tack för rapporten, svaret står nedan på engelska.
Creating a room needs a Personal Access Token with the Zones scope; the app’s own key cannot do that. You did set a token, but Homey refused it (“Invalid Session”), so the bridge never used it. That usually means one of these:
the token was made for another Homey
it was deleted again on my.homey.app
it was not copied whole
it is the MCP AI Bridge API key from the Status tab, which is a different kind of key
How to fix it:
Go to my.homey.app, choose this Homey, then Settings, API keys, New API key.
Tick Zones, and Flows if your assistant should also build flows.
Copy the whole token and paste it on the Status tab of the app.
The Status tab then says whether Homey accepted it. 5.2.2, live now, also says this in the answer itself: an action that needs a token names the scope it is missing, and a token Homey refused is called refused, with the reason, instead of the bare “Missing Scopes”.
To whoever sent a diagnostics report about editing dashboards
Thanks for the report. Takk for rapporten, svaret står nedenfor på engelsk.
You were right. Up to 5.2.3 the bridge kept only the finished page of a dashboard, not the layout it was built from. ChatGPT could list your dashboards and see their name and address, but there was nothing to edit.
5.2.4, live now, keeps that layout. dashboard_get gives it back, ChatGPT changes what you ask for and saves it again with dashboard_generate under the same name, so the address stays the same.
One thing to do once: a dashboard made before 5.2.4 has no saved layout yet. Ask ChatGPT to build each one again, or give it the config you used if you still have it. After that you can change them a card at a time.
Your message was cut off after “cannot retrieve or edit their existing”. If you meant Homey’s own dashboards, the ones in the Homey app: those can be read and changed with homey_dashboards_get and homey_dashboards_update. If it was something else, reply here.
I’m using MCP AI Bridge with ChatGPT to build and maintain several custom dashboards on my Homey Pro.
The integration works well for creating dashboards, but I’ve encountered a limitation: ChatGPT can list dashboards and retrieve their metadata, but cannot retrieve or edit their existing configurations.
This means that even a small change, such as fixing a sensor history widget, requires rebuilding an entire dashboard or creating another one.
Would it be possible to add two MCP tools?
dashboard_get_config: Retrieve the complete configuration of an existing dashboard.
dashboard_update_config: Update an existing dashboard while preserving its other widgets, layout and settings.
Ideally, the update tool would also support validation, dry-run and backups.
This would make it possible to maintain and improve existing dashboards without constantly creating new ones.
Reading the config:dashboard_get gives back the full config a dashboard was made from (since 5.2.4).
Changing part of it:dashboard_update takes a list of changes as paths into that config: set a field, remove one, or insert a card. Only what you name changes, the other cards, the layout and the settings stay as they are. It is all or nothing: if one change does not fit, nothing is saved and the answer says which one and why.
Validation: every save is checked the same way dashboard_generate already was, so an unknown card type, an empty tab or a card that would stay blank comes back as a warning.
Dry run:dry_run: true on dashboard_update, dashboard_generate and dashboard_restore checks and renders the result and lists what would change, without saving anything.
Backups: every save keeps the three versions before it. dashboard_get lists them and dashboard_restore puts one back, and a restore can be undone the same way. A removed dashboard can be brought back for a month.
Two things to do once:
Refresh the connector in ChatGPT’s connector settings, so it sees dashboard_update and dashboard_restore. ChatGPT keeps the tool list from when the connector was added.
A dashboard made before 5.2.4 has no stored config yet, so let ChatGPT build each one again once. After that, fixing a history card is one small call.
Thanks for the quick response and the improvements in 5.2.5! Really appreciate the work you’re putting into this.
I’ve been troubleshooting the ChatGPT integration quite extensively, but unfortunately the new dashboard tools still aren’t available.
Current status:
MCP AI Bridge 5.2.5 is installed and running successfully on my Homey Pro.
ChatGPT can connect to the bridge and use existing tools without issues.
dashboard_get works, but ChatGPT still has the old tool description and schema.
dashboard_update and dashboard_restore are completely missing from ChatGPT’s available tools.
Troubleshooting I’ve already completed:
Updated MCP AI Bridge to 5.2.5.
Checked the connector settings in ChatGPT, but couldn’t find any refresh/update option.
Reauthorized the MCP connection.
Updated the ChatGPT iOS app to the latest available version.
Completely removed the MCP AI Bridge plugin from ChatGPT.
Reinstalled and reconnected the plugin using a newly generated API key.
Verified the connection again. Existing tools work, but the two new tools are still missing.
I’ve also noticed that the 5.2.5 changelog was published today, so perhaps these features are very new and something still needs to be updated or synchronized on the ChatGPT side?
Could you check whether dashboard_update and dashboard_restore are actually being advertised in the MCP server’s tools/list response?
It would also be useful to confirm whether the updated dashboard_get schema is being advertised correctly.
If everything looks correct on the MCP server side, do you know whether ChatGPT requires any additional steps to discover newly added tools?
I have to say, this is one of the best apps out there. It’s really fun to experiment with AI. I never could have created such advanced flows on my own without it! Thanks for that!
However, I’m running into an issue with the new version 5.2.4, 5.2.5 of the app. I had a dashboard set up with Claude using a previous version. When I tried to delete something, it prompted me to recreate the dashboard. I did so, but now many of the specialized cards—such as the round thermostat displays—are no longer available according to Claude. A lot of things look different now. I’ve reverted to my old dashboard.
@Laffen999 I checked the bridge itself: on 5.2.5 the tool list it hands out has dashboard_update and dashboard_restore in it, both with dry_run, and dashboard_get with its new description. So the server side advertises them.
That leaves two places where they can drop out on the way.
The key on the bridge. In the app settings, Security tab, under Scoped API keys:
The permission of the key that ChatGPT uses. Update and restore count as changing something, the same as dashboard_generate. If ChatGPT has dashboard_generate, the permission is fine.
The line under the key. “Every tool this permission allows” is what you want. If it says “N tools selected”, that key has a tool selection, and the two new tools are not in it until you tick them under Tools.
The Blocked tools list on the same tab, which applies to every key.
ChatGPT. It does not pick up new tools by itself; it keeps the list from the moment it last read it. Open chatgpt.com in a browser, go to Settings, then Apps & Connectors, open the connector and press Refresh. As far as I know the iOS app does not have that button, which would explain why you could not find it. If the connector page lists the tools one by one, check that the two new ones are switched on. Then start a new chat, not the one you were in.
If dashboard_update is still missing after that, let me know the permission of the key and what the line under it says, and I will look further.
@RudolfT thank you, good to hear it is fun to work with.
What happened: a dashboard made before 5.2.4 was stored only as the finished page, not what it was made from. So when you asked for a change, Claude was told to build it again, and with nothing to start from it built a new one instead of the same one. Nothing was taken out of the app: the round thermostat (the thermostat card) and the round gauge (the dial card) are both still there. Claude just did not know your old dashboard had them.
5.2.6 fixes this:
A dashboard Claude drew in html itself gives that html back, so it is changed as it is.
A dashboard made from a config gives an outline: its tabs and, per card, the type, the title and the devices. Claude is told to build the same dashboard again from that, with the same cards, and then make the change.
So keep your old dashboard. Once 5.2.6 is on your Homey, ask Claude again for the change you wanted. After that one save it can be changed in place, and every save keeps the three versions before it, so a change you do not like can be undone with dashboard_restore.
The old dashboard its HTML-based I think, with many small modifications; it wasn’t possible to convert everything at once. However, I’ve created a new dashboard and was able to migrate it tab by tab, page by page and even tile by tile individually. Everything works, and it all looks just like the old dashboard.
First of all, thank you for developing MCP AI Bridge. I’m testing version 5.2.6 on Homey Pro 2026, connected locally to Claude Desktop, and the MCP integration is working correctly.
I’m currently working on a customized dashboard for my home. I’ve successfully used dashboard_get and dashboard_update to modify the existing auto dashboard, including its layout, weather widget and theme.
However, I’ve encountered an issue with the Calendar component.
Problem
I’ve added two calendar cards to the Overview page: one for waste collection and one for my personal calendar. Both consistently display “Nessun calendario” (No calendar), although their ICS sources contain events.
What I’ve verified:
The calendars are already working in the official Homey Dashboard through the IcalCalendar app (no.runely.calendar).
The Calendar cards in MCP AI Bridge contain the original ICS feed URLs.
Claude Desktop confirmed that their configuration is valid and dashboard_update reports no schema errors.
I downloaded one of the ICS files directly from Google Calendar. It contains valid VCALENDAR and VEVENT structures, including upcoming all-day events using DTSTART;VALUE=DATE.
The weather widget and other live Homey information work correctly.
Chrome DevTools shows no relevant JavaScript errors. I couldn’t identify a calendar-related network request, although the feed may be fetched server-side.
My questions:
Does the dashboard Calendar component fetch and parse ICS feeds directly on Homey Pro, or does it rely on another mechanism?
Is there a way to inspect the feed-fetching or parsing errors?
Are Google Calendar ICS feeds and all-day events supported?
Could the issue be related to the number of events, mixed historical and future entries, or the feed format?
Is there any recommended way to integrate the calendars already managed by IcalCalendar?
My goal is to reproduce a family dashboard with agenda, weather, home status and a few interactive control panels, without recreating the original Homey Dashboard.
I can provide a diagnostic report and screenshots if useful. I would prefer not to share private ICS URLs publicly.
Thank you for your help and for the ongoing development of the app.
@Luca_Tucci thank you for the clear report, and for keeping the addresses out of it. I found it.
What went wrong. When a dashboard is saved, the bridge takes the .ics address out of a calendar card, keeps it in the app and gives the card a short id instead. That step only looked at the cards directly on a page, not at the cards inside a stack (cards under each other in one spot). The Overview of the auto dashboard is built with stacks, so a calendar added there kept its address, never got its id, and the card shows “Nessun calendario”. That is also why the cards still contain the original addresses: on a card that works, the address is gone from the config. If your two cards are not in a stack, check that the address is in a field called ics; any other name is not read.
5.2.7 fixes it. Once it is on your Homey, ask Claude for any small change to that dashboard with dashboard_update. That save stores the addresses, and the cards fill within a few seconds. I tried it with a Google feed in a stack: today, tomorrow and the days after, all-day events included.
Your questions:
The bridge fetches the feed itself, on the Homey, every 15 minutes, and hands the page only the coming events. The address never reaches the browser, so DevTools shows no request for it.
Since 5.2.7, a feed that cannot be fetched writes the reason in the app log, for example “The calendar answered 404” or “larger than 2 MB”, and never the address. A diagnostics report then shows it.
Yes. The secret address in iCal format from Google works, and so do all-day events (DTSTART;VALUE=DATE), times in a time zone and repeating events.
The number of events and old entries do not matter, as long as the file stays under 2 MB. A Google calendar used for many years can get there; the limit protects the Homey’s memory.
The bridge cannot read the calendars inside IcalCalendar. Give the card the same .ics address you gave that app. days (up to 31) and max (up to 30) set how far ahead and how many events it shows.
Someone asked through a diagnostics report where to set up the AI connection. Those reports come without a name, so I cannot answer them directly. Here it is for anyone looking for the same thing.
The settings are in the Homey app under More, Apps, MCP AI Bridge, Configure app.
Connection is where you link an AI assistant such as Claude or ChatGPT.
Ask a model is where you set up a model for your flows.
In het Nederlands: open in de Homey-app MCP AI Bridge onder Apps en kies de instellingen. Je AI-assistent koppel je op het tabblad Verbinding, een model voor je flows stel je in op Model vragen.
If this is not what you were looking for, post here and I will look further.
@Torgeir_Gullesen done, in 5.2.8. The whitelist now takes subnets next to single addresses, so 10.0.0.0/22, 192.168.1.10 works, and IPv6 subnets too.
This also fixes a trap: until now a subnet in that field matched nobody, so it shut out every client without saying why. If you tried it and got locked out, that was the reason. An entry that is not valid, such as /33, lets nobody in, and the other entries on the list keep working.
@RudolfT good to hear, and tab by tab is a good way to move a dashboard that grew through many small changes.
You will not run into this again with the new one. It is stored with what it was made from, so Claude can read it back and change it as it is, and every save keeps the three versions before it for dashboard_restore.
I’ve encountered an issue with the MCP AI Bridge guardrail system.
I have a custom guardrail rule called “Sloten” (Locks), configured to protect my smart locks.
The rule is configured to block:
Capabilities: locked, open_lock, lock_mode
Devices: Two specific smart lock device IDs
Strict mode: enabled
However, when ChatGPT tries to perform unrelated actions, the bridge blocks them with the following error:
Blocked by a guardrail rule: Sloten. The owner set this rule deliberately. Do not retry.
What I was trying to do:
Update two existing Homey flows (washing machine and dryer).
Replace outdated ImgBB image URLs with local NAS image URLs.
Send test images to Telegram using flowcards_run_action.
Test NAS accessibility using homeyscript_run in dry-run mode.
The Telegram and HomeyScript actions were blocked even though neither action involves my smart locks or their capabilities.
Expected behavior:
The “Sloten” guardrail should only block operations involving the explicitly protected lock devices or capabilities.
Unrelated actions, such as sending Telegram notifications or accessing local NAS images, should remain permitted.
Question:
Could this be a bug in how strict guardrail rules are evaluated? Is strict mode unintentionally applying the rule globally instead of only to the configured devices and capabilities?
@Mariomark1541 thanks for the clear report. Part of it was a real gap, and part of it is what strict is there for.
The Telegram card (flowcards_run_action). Strict also closes the indirect ways to reach your locks: a flow, a mood, an action card, a script. For flows and moods the bridge already read what they would do, and only refused when they could reach a lock. A single action card was not read; it was refused whatever it did. 5.2.9 reads it the same way as a card in a flow. Your Telegram card now runs, and a card that acts on one of your locks, names one in its arguments or runs code is still refused.
HomeyScript (homeyscript_run). This one stays blocked under strict, in 5.2.9 too, and a dry run counts the same. A script can reach any device through Homey’s API, and the bridge cannot see beforehand what it will do, so it cannot promise your locks stay out of it. What changed is that the refusal now says this, instead of only naming the rule. If ChatGPT needs to run scripts, you can switch strict off on the Sloten rule: direct commands to the locks are then still blocked, the indirect paths no longer are.
Updating the two flows was not affected: editing a flow is not one of the paths strict watches.
