[APP][Pro] MCP AI Bridge: talk to your Homey with Claude, ChatGPT, Gemini, Copilot, Cursor, Mistral, Ollama, LM Studio, n8n, Home Assistant or any AI, also from Telegram and WhatsApp
@Dominik
Hi Dominik, sorry about that, and thanks for the screenshots. The store page was wrong, not your Homey.
The bridge only runs on Homey Pro (Early 2023), Homey Pro (2026), Homey Pro mini and Homey Self-Hosted Server. There is no setting to get around it on the 2019. You can safely uninstall it: it never started, so it left nothing behind.
Why not the 2019? The bridge talks to Homey through the newer local Homey API. A Homey Pro (Early 2019) offers the older version of that API, which is what the “platformVersion 1” in the message means. Devices, flows and settings come back in a different shape there, so every one of the 173 tools would need its own translation layer. The flow tools differ the most, and those are exactly the ones you were after. On top of that I don’t own a 2019, so I couldn’t test any of it properly. I’d rather not ship something I can only guess works.
The “Works on” list showed every model because the app only stated a firmware range, and your 2019 runs the same firmware numbers as the newer models. Version 4.20.3 fixes that: the store now only offers the app to the Homeys that can actually run it, so nobody else on a 2019 or older installs it for nothing.
For what you were after, on a supported Homey: the bridge runs on the Homey itself, so the cloud limits of Athom’s own MCP do not apply, and it can create an Advanced Flow straight into a folder (and create the folder first if needed). Sadly that doesn’t help on the 2019.
@weide43
I’ve been testing the new Telegram chat feature in MCP AI Bridge. Really nice addition! :grinning_face_with_smiling_eyes:
I’ve successfully connected a Telegram bot, but when using gpt-5.6-luna with Allow the model to act enabled, I receive the following error:
Function tools with reasoning_effort are not supported for gpt-5.6-luna in /v1/chat/completions. To use function tools, use /v1/responses or set reasoning_effort to ‘none’.
Would it be possible to add support for the OpenAI Responses API, allowing newer GPT models to use function calling and reasoning together?
I’d especially love to use GPT-6 with the Telegram integration to interact with and control my Homey devices.
Is this something you’re planning to support in a future update, or is there currently a workaround?
Thanks for your continued work on this app!
Also nice if the telegram bot can join my household group so all family members can ask things in the chat
@Mariomark1541
@Mariomark1541 thanks for testing it, and for the exact error, that made it quick to find.
Newer OpenAI models such as gpt-5.6-luna reason by default, and OpenAI no longer allows reasoning and function calling together on the older chat completions endpoint, which the bridge still used for Ask a model with tools. 5.0.1 switches that to OpenAI’s Responses API, so tools and reasoning work together. Your Telegram bot, WhatsApp and the widget all go through the same path, so they all benefit.
Until 5.0.1 reaches the test channel, two workarounds: pick an OpenAI model that does not reason (gpt-4.1 or gpt-4.1-mini, for example), or switch the provider on the Ask a model tab to Anthropic, Gemini or Mistral.
Any newer OpenAI model that supports function calling in the Responses API will work the same way once you have 5.0.1, so give GPT-6 a try then and let me know how it goes.
@weide43 Thanks for the quick response and for fixing this in 5.0.1! Really appreciate it! :grinning_face_with_smiling_eyes:
I’ll definitely give GPT-6 a try once the update is available and let you know how it goes. Tested and it’s working already with 5.6 Luna
I also have one more question about the Telegram integration.
Would it be possible to support Telegram group chats in the future? I’d love to add my AI bot to our family group so other family members can ask questions and interact with Homey as well.
Ideally, the bot would only respond when mentioned by its username (e.g. @BotNameBotName), so it doesn’t interfere with normal group conversations.
It would be great if group access could also be approved and managed separately for security reasons.
Is there a technical limitation preventing this, or could it be considered for a future update?
Thanks again for all your work on this app! :+1:
If you point the MCP AI Bridge at cloud models with your own keys, the daily bill is mostly prompt size: Claude Haiku 5.5 is $0.10 / $0.50 per million input/output under 100K prompts (cache reads $0.01/M; 5× above that band), Sonnet 5.5 is $2 / $10, and Grok 4.7 is $2 / $6 with $0.50/M cache reads — so a short “is the back door open?” turn stays under a cent, while pasting a week of power stats is what burns money. Cap max tokens on the Homey side, prefer Haiku or a cheaper Grok card for routine yes/no branches, and keep a prepaid balance so a runaway Flow cannot surprise you overnight. I keep a small public list-price table at https://aicost.tools/llm-cost/anthropic/claude-haiku-5-5/ (disclosure: I work on AICost) when I need to sanity-check a Flow before leaving it on.
@Mariomark1541 5.0.2 is on the test channel now, with Telegram groups: MCP AI Bridge | Homey
To set it up:
  1. Add your bot to the family group.
  2. Mention it once in the group, for example “@YourBotName hello”. The group then shows up on the Chat tab, marked as a group, waiting for approval.
  3. Click Approve next to the group.
  4. From then on, anyone in the group can ask it something by mentioning it or replying to one of its messages. The rest of the group conversation it leaves alone.
Each family member gets their own conversation with the bot, and the model is told who asked, so “turn off my lights” knows whose lights. /new@YourBotName starts a fresh conversation for just you.
Two things to keep in mind:
  • Everyone in an approved group, including people added later, acts under the same API key. Give the bot a key with Control only on the Security tab: it can switch things, but not rename, delete or change settings.
  • If the bot does not react to a mention, switch off its privacy mode at @BotFather (/setprivacy, pick your bot, Disable), then remove the bot from the group and add it again.
5.0.2 also has the Responses API change from 5.0.1, so GPT-6 should work there too. Let me know how it goes with the family!
Great I’m gonna test so it’s safe enough ?
@Mariomark1541 Safe enough for a family group, yes, if you set it up with a bit of care. What protects you:
  • Nothing reaches the model until you approve the group, and in the group the bot only reacts to messages that mention it or reply to it.
  • The bot acts under the API key you choose, through the same checks as Claude or ChatGPT: the key’s permission and tool selection, the access mode, your guardrails and the limits. Irreversible actions (deleting devices, uninstalling apps, rebooting) are refused for this route altogether.
  • Everything it does is logged on the Diagnostics tab, with the tool and the result.
The one thing to be aware of: anyone in an approved group can operate the house, including someone added to the group later. So:
  1. Give the bot a key with Control only. It can switch and set devices, but not rename, delete or change your setup.
  2. If there are things only you should control, such as a door lock or the alarm, block them with a guardrail on the Security tab. The bot then cannot touch them, whoever asks.
  3. In the Telegram group settings, let only admins add members.
  4. Set a daily question limit on the Ask a model tab, so a chatty afternoon cannot run up your OpenAI bill.
And it is a test version: if anything feels off, you can go back to the store version at any time. Let me know what you run into!
It’s working great!
I have a questions about this app. Last week I played a bit with chatgpt in combination with Homey. Its very easy to connect them, but I was not very impressed with building flows. Complex flows where a bit hit and mis.
I was wondering if its working better with this app in combination with gemeni.
And, are the payd AI subscriptions for gemeni, chatgpt or others working a lot better with this?
@Marcel_Visser
Hi Marcel,
Yes, for flows this is where the bridge makes the biggest difference compared to the standard Homey MCP. Complex Advanced Flows are what I built most of it for, so the model gets a lot more help than just “create a flow”:
  • every card is looked up in your own Homey’s card list, so the model only uses cards that really exist, with the right ids and arguments
  • advanced_flows_validate catches a broken flow before it is saved, and flows_simulate walks through it without switching anything
  • the model can read a skill on Advanced Flows first: how cards connect, how tokens and variables work, and how to lay out the cards so they don’t land on top of each other
  • a copy is kept before every flow edit, so a flow that went wrong can be put back
  • in Claude and ChatGPT you see the flow as a panel before it is created
That takes most of the hit and miss out. The model still has to understand what you want, so which one you use matters too.
Gemini. It works, but give it a key in compact mode (Security tab, Tools). Gemini refuses more than 128 tools and the bridge has more than 170; compact mode shows it two tools that reach all of them. Switching things and simple flows go fine. On long Advanced Flows with several branches I find it less reliable than Claude or GPT-5.
Paid or free. The bridge is free either way. A paid plan mostly buys you the stronger model and more room in one conversation, and for complex flows that is what counts: a long flow eats context, and a smaller model loses track halfway.
  • Claude: the free plan allows one custom connector, which is enough for the bridge. Pro gets you the bigger models, and that is where I get the best results with Advanced Flows.
  • ChatGPT: connecting your own server needs Plus or Pro with developer mode on.
  • Gemini: fine for everyday control in compact mode. I have less experience with it on big flows.
What helps with any model:
  • describe the flow as when / and / then, one step per line
  • use the names your devices and variables have in Homey
  • ask it to validate the flow and show it to you before it creates it
  • build a big flow in two or three rounds instead of one long prompt
If you try it and a flow still goes wrong, let me know which one. That is how the flow skill gets better.
@weide43 Hi Danny,
Yoiu wrote in Claude and ChatGPT you see the flow as a panel before it is created
I’m using MCP AI Bridge 5.1.2 with ChatGPT Plus in the web browser on Windows, with Developer Mode enabled.
I’ve tested the Advanced Flow preview twice. The advanced_flows_validate tool works correctly and returns valid: true, with no errors or warnings.
However, the interactive MCP Apps flow preview panel never appears in ChatGPT. I only receive the validation result as text.
Could you check whether the MCP Apps UI resource and its metadata are correctly exposed to ChatGPT, and whether the flow preview is supported with this connection?
I’d love to use this feature before creating Advanced Flows.
Thanks!
Hi Marcel,
Its working.
I need to refresh tools in chatgpt self.
@weide43
I’ve encountered an issue with the MCP guardrail system.
I have a strict security guardrail configured:
  • Rule: Deursloten niet bedienen (Do not operate door locks)
  • Blocked capabilities: locked, open_lock, lock_mode
  • Strict mode: Enabled
However, this guardrail also prevents me from triggering an Advanced Flow that has absolutely nothing to do with door locks.
Affected Advanced Flow:
ADVANCE FLOW ENERGY
This flow contains only:
  1. A manual start trigger.
  2. A Telegram action (send-a-image-with-message) that sends my weekly energy report.
There are no door lock devices or lock-related actions in this flow.
Steps to reproduce:
  1. Enable a strict guardrail blocking door lock capabilities.
  2. Create or use an Advanced Flow containing only a manual start and a Telegram notification action.
  3. Attempt to trigger it through the MCP tool advanced_flows_trigger.
  4. The request is blocked.
Exact error:
Blocked by a guardrail rule: Deursloten niet bedienen. The owner set this rule deliberately. Do not retry; tell the user which rule stopped the action.
Even calling advanced_flows_trigger with dry_run: true produces the same error.
Expected behavior:
The guardrail should block actions involving protected lock capabilities, without preventing unrelated Advanced Flows from running.
Ideally, the MCP should inspect the actions and capabilities referenced by a flow before deciding whether the guardrail applies.
If the flow contains protected actions, blocking it is correct. Otherwise, it should be allowed.
Impact:
My automated weekly energy report successfully generates its Excel archive and Telegram image, but the final Telegram notification cannot be sent because MCP refuses to trigger the flow.
Could you investigate whether strict guardrails are being applied too broadly to Advanced Flow triggers?
I would prefer to keep my door lock security guardrail enabled rather than disabling it as a workaround.
Thanks!
Gr MArk
Hi Mark,
You’re right, and thanks for the clear report. A strict rule blocked every flow trigger and every mood without looking inside, so your energy flow was stopped even though it never touches a lock. The dry run goes through the same check first, which is why that was refused too.
5.1.3 fixes this. With a strict rule, the bridge now reads the flow before it decides, and refuses only when something in it can reach the protected capability:
  • an action on a device that has that capability, so your locks
  • an action that is handed such a device, or the capability itself
  • a card that runs code, makes an HTTP call or sends raw Z-Wave
  • another flow it starts or switches on that does one of these
  • a card the bridge doesn’t know
Moods get the same check. Whatever can’t be read stays blocked, so strict mode doesn’t get any weaker. And when it does refuse, it now names the card that stopped it.
Your flow, a manual start plus the Telegram card, passes. I ran the new check against the 83 flows on my own Homey with a rule like yours: 75 may run, and the 8 that stay blocked all lock, unlock or run a script.
5.1.3 is live in the App Store now, so an update is enough. You can keep your lock rule as it is.
Thank you for the quick fix again!
:test_tube: 5.2.0 is in the test version
More providers for Ask a model. Next to Anthropic, OpenAI, Gemini, Mistral and your own address: OpenRouter, Groq, DeepSeek, xAI (Grok), Perplexity, Together AI, Cerebras, Fireworks AI and Cohere. They work for a plain question and for a conversation that operates the house. OpenRouter, Grok and Perplexity can search the web, and so can Groq on its gpt-oss models.
Ask cards in flows you can rely on. Every ask card can get a time limit and a fallback, so a slow or refusing model no longer holds a flow up. A tag tells you when the fallback was used. And four new cards:
  • let the model choose from your options
  • ask for a number between two values
  • continue only when the answer is yes with at least so much confidence
  • let the model decide which of up to five flows to start, and only those. Every start goes through your guardrails.
Building flows with an assistant, for @Marcel_Visser’s question:
  • advanced_flows_diff shows card by card what an edit would change, before anything happens, and a dry run of an edit now shows the same
  • flows_repair_suggest looks at a broken flow and proposes the card that most likely replaces the missing one, with how sure it is
  • flows the assistant builds are laid out in columns: when, and, then
The flow panel in ChatGPT, for @Mariomark1541: the panels are now also in the resource list, which is where ChatGPT looks for them. Ask for panel_flow_preview to see the drawing.
Guardrails without JSON. The Security tab has a form: pick devices, capabilities or tools, a time window, days, and strict. A rule can now protect single devices, and in strict mode your own AI commands are checked the same way as flows. The JSON is still there under Advanced.
Dashboard. The climate buttons stay on one row on a small phone, and the car’s values are no longer cut off on a tablet.
Everything is in the nine languages. If you try it, I’d like to hear how the new providers and cards behave with your setup.
5.2.1 is with Athom for review
It takes everything from 5.2.0 along (see my previous post), plus a better memory for assistants:
  • every note says who saved it and when, with the current name of the key that wrote it
  • memory_search looks through every namespace at once, so an assistant finds what another one saved
  • when an assistant connects, it hears that there are notes to look at first, never what is in them
  • passwords, tokens and keys are not remembered: every key with read access can read memory
  • all memory together stays small, so it never weighs on your Homey
  • a new flow card, “Recall a value the AI remembers”, gives a remembered value to your flow as a tag
5.2.0 never went live on its own: 5.2.1 replaces it in the review. Once Athom approves it, both are in the App Store at once.
@weide43 ore anybody else, my i ask a question please?
First thx for this great App and deployment!
Well, i have currently not so much experience regarding AI features in Homey like some other guys here in this thread, so sorry for my maybe stupid question…but what is the biggest benefit to use your app in Homey in comparison with my actual setup, ChatGPT is is directly linked mit the Homey MCP over my iOS mobile device with the ChatGPT App?
I currently use it to build / check advanced flows and take new ideas for my system and this is working really good, of course not to compare what HO delivery but this is depending of the MCP so far i understand it…to be honest as well, i don’t have tried in the moment your App maybe i should because of course there are benefits which i read already in your app description above but my question is, with which function i can made the next step forward to make it more easily and what your lovely the feature in relation with AI-MCP in the Homey World…thx!
