Same here, no color changing possible and no dimming. This does work with the Google Home app, but not with Homey.
New app update (test: 3.3.26):
- FIX: issue after latest update
@Futero @Jan_Willem_Visser @Bulletcather Can you check if this fixes it. Please note it’s the test version of the app.
It requires a install from this link: Magic Home WiFi LED | Homey
Thanks a lot for the verry quick update… It works great again.
@Jan_Willem_Visser awesome! will push it to the live version
New app update (live: 3.3.28):
- FIX: library to support AK001-ZJ200 again
@Futero @Jan_Willem_Visser @Bulletcather if you installed the test version make sure to install the live version again so you won’t get any test updates if you don’t want to ![]()
New app update (test: 3.3.30):
Note: this is the test version of the app.
Changelog:
- FIX: adapt library to support both types of Color commands
Dimming and colors are working again!!
Ak001-zj210 colors effects are not working. No hurry
New app update (test: 3.3.31):
Changelog:
- FIX: AK001-ZJ210
@Bulletcather can you check? ![]()
Looks like it’s working here again!
@DidierVU Awesome!
Also the AK001-ZJ200?
It is the ZJ200 indeed! Did not test it with a RGBW strip yet, but when connecting an RGB to it I can fully control it again
@martijnpoppen: Don’t think I can dim my White channel. But I have to investigate further (now only the white channel is connected to the controller)
Everting was working yesterday evening.
Sinds today morning I can’t change color and brightness
Can you fix this please?
New app update (test: 3.3.32):
Changelog:
- FIX: AK001-ZJ210 @Bulletcather
- NEW: add custom addressable function to support old and new addressable ledstrips @Stan
@Stan fixed in 3.3.32 can you check?
The effects still not working.
If i can do something let me no
@Bulletcather is the AK001-ZJ210 a addressable ledstrip?
Yes. Spi
