Hi Mark,
I recently installed your Kodi app on my Homey Pro (2023) and now want to add my two Kodi systems. Unfortunately, it only recognizes one at a time. Even when they are both on. When I want to add the second one, the Kodi app says it has not found any new devices.
Is it actually possible to install two Kodi devices?
Thanks,
Martin
Hi Mark -
If you get a chance, a THEN card to suspend/sleep Kodi would be great. When turning off my LG G5 it suspends Kodi using CEC (but doesn’t seem to wake it up when it turns on). Perhaps also an AND card for “Is Kodi suspended ?”
Something seems to be stuck, even though Homey and the Kodi (osmc) box have been restarted multiple times. It seems to insist that it’s only a music player ?
These are the only when: cards available
and clicking on the osmc device only shows a play button for music.
The only thing I can think of is that the osmc kodi box is on the main vlan (so it can access the media server) while Homey is on the IoT vlan. There is an explicit rule to allow Homey access to the internal main vlan though.
Even when playing music it seemed to lag behind and forget things. For example, a recently played track would be there for days as if it was still playing.
Hi! In the old KODI app, which is only compatible with older Homeys, there was an option to send a notification to KODI.
It will be nice if you can include this feature also to this app.
Hello thanks for your app!
I have one kodi on my tv connected,Homey finds it directly.My second Kody is on my computer but it doesn’t find these one,I try to modify all the settings i can think of but it won’t find my 2nd kody
In the old app Kodi(2016-2019),it was possible to find a kody system by typing the ip adress
It this possible to do thesame with your app?
Thanks a lot
I use this kodi app too, and i believe the app only can have 1 kodi on the network, probably why you won’t see the 2 instance when you try to search for it
