I’ve contacted them but they experience no problems.
Any other ideas of suggestions to get the app working again?
is there a way that i can use wind directions in the AND cards?
i see the current wind drection in the device when i click it, but i cant use the specific directions in my flows
kind regards
Did you use the confirmation link in the e-mail you received from Weerlive when creating your account? If not, then your account has not been activated and you cannot use the API key.
I did. And in my account state two api key requests
Maybe try the other API key?
This morning it suddenly worked ![]()
But I can’t use it like the other KNMI ap on HDashboard because it has no capabilities.
Yes I did. Now I deleted the app and went back to an other weather app.
No update unless restarting app
I had a simple flow triggered every few hours to update the KNMI data
No data is getting updated though unless I restart the app
Now I just made a flow that restarts the app every few hours
Any thing I should check?
It’s a known issue. The developer is working on it.
Thanks for the quick anwser
No worries, I will keep a look out in this topic
Cheers
Is this app still maintained/developed or is this becoming abandon ware ?
I tried to install it and it doesn’t accept mu weerlive.nl api key at all.
just to know If i could/should remove the app from my homey if its not working/useful anymore.
A little spring cleanup.
As the update history shows, last update 23 apr 2022.
You might want to consider the alternative KNMI app, which is operational and for which you don’t need an API key.
@SunBeech Thank you. I have already installed the other KNMI app and using it already a couple of months. But I just saw today that many of my (older) flows still somehow use this one and I was just wondering if this is still available/working or I have to change about 17+ flows to the other app before removing this one from my Homey Pro 23.
