Hello @_Gesperrt
Note that there is a “missing” thing in the Modbus API (this exist in the UDP version…) - You could call/ask Keba to implement this….Same as showing on/off state and adding to set it in the P40 version (see other comment)
We can only set the Charge Power - there is no way to read it. So what the App does is to set it based on that setting when the Keba is connected and so on to make sure it is correct in Homey (if something else have set it). And then there are two more “Charge Power settings” that I have added that shows the other info.
- Charge Power (can be set in Homey) - “Runs Set Charging Current” - can not get this value from API
- Max power (Read only) - Max charging current - this is the max power the charger will give based on what is connected or not connected - it is not the result of the Charge power setting - that will cap the power of the charging in your case it shows 8 A in mine 0 A (no cable) - but when I charge it will be max 10 A as my settings are today.
- Supported power (Read only) - Max supported current - what the hardware will be able to output (mine is down graded from 16 A to not blow my fuses)
The new version vid support for P40 is now live. ( or will be later today, it is published to the app store)…
it is possible to start and stop the charging via modbus API:
Stop: Set “Charging current” to “0”
Start: Set “Charging current” to any other value between 6000 and 32000
Today i do it via homey app “Modbus TCP/IP” from Ronny Winkler and it works well!
So isn’t it possible to implement it to the keba app?
Hi @Daniel_Lenfort, I will try - I cannot completely figure out how to combine it with the Selection of charge current, combine that with setting 0 on button click and what do do when turning on again.
Also I cannot test the outcome of this, I have the P30 and that does not support setting 0, but instead supports the missing enable/disable in P40. Any help with ideas on fixing the logic and after that help with testing the P40 - and then I may be able to fix it
/Jonathan
Hello Jonathan,
now I got the Modbus TCP Programmersguide V1.02. If you need this guide please let me know, I will send it to you.
Maybe I have a solution for your logic problem. Is it possible to add a new “then”-card which is called “P40 suspend”. If you use this card in your flow, you set the value of register 5004 directly to “0”.
To Turn the P40 on angain, use the “Set Current” Card and set it to the needed value.
I tried this with the “Modbus-App”, which Daniel mentioned, and It works fine.
If you need help to test this new card, please let me know.
Hello everyone, I’m trying to add the Keba P 40 box via IP address. Unfortunately, there is always a time out. Modbus TCP is already connected to Huawei inverter. Could that be a problem?
Could you test and then send me a diagnostic report to me, and I will see if that gives any ideas of what the problem can be.
Thank you for your answer, I found the problem.
Everything works perfectly when I disconnect the Modbus connection to Huawei. Is there a way to regulate the wallbox under 6A?
@Matthias_Konenberg @_Gesperrt @Daniel_Lenfort
I have a new version that may fix the on/off and also can set the charge value to 0.
This is on test only for now. ref: Keba | Homey
If possible and you want, please test it on P40 and come back with feedback, I do only have P30 - but there it works.
