[APP][PRO] IntesisHome
Thread for the IntesisHome app, IntesisHome App for Homey | Homey
My home has multiple split systems. Is it possible to add 8 units to this app please? I am getting a duplicate error when seeking to add more than one device.
@mholm … Is this the thread to ask questions such as the above please?
it is, I’m just super busy right now, I have a small backlog(including this issue) for the app that I was hoping to address some time during the next couple of weeks.
I think your issue might be me taking shortcuts where I should not have and should be fairly easy to fix, but since I only have one unit it might be difficult for me to test.
No stress…… I’m happy to help test when you are ready
I just pushed a new version to “test”, IntesisHome | Homey it is supposed allow multiple devices.
Nice job… I’ve been able to add and control all devices. I’ve tested all control functions, there seems to be only one UX issue
@mholm … have you made any recent changes to the app? The flows seem to no longer work. And the on/off now takes two presses on the Homey App. The early/mid April Test Version worked well.
I just replaced my Intesis module with one from Panasonic and will no longer be able to maintain this App. The source, GitHub - mattias-holm/com.mattiasholm.intesishome: Homey app for controlling AC Cloud Control (previously IntesisHome) devices is up for grabs if someone would like to continue working on it or just straight up steal it and make something new.
Hi. I know you may not be supporting this driver soon but if I could ask a quick question…
We have an application with multiple heat pumps per site. When we used the IntesisHome app with an intesis account with 2 heat pumps we observed the following:
  1. Set up by for each heat pump (in our case we have two homeys - one heat pump on each homey) adding credentials, authenticate, then select correct heat pump
  2. To start with it appeared to work (initial values on each app appeared to match heat pump) but then after a while noticed incorrect temperatures coming through (looked like temperature for the other heat pump). Also heat pumps did not reliably start / stop or change set point.
  3. After re-adding app a couple of times on each Homey to verify we had selected the correct homey. Still saw the same issues.
  4. App is IntesisHome app version 1.1.2
  5. Set up a second Intesis account for the second heat pump and the apps then functioned perfectly. So definitely something to do with having an Intesis account with multiple heat pumps.
Obviously we would like to have multiple heat pumps on one account. But is this expected behaviour?
