[APP][Pro] ID Lock App (v2.0.0)
@ja.nei.johan That explains it. Thanks. By the way, I see that Athom have released a new firmware today. Can’t see anything regarding z-wave in the description, but I will anyway give it another try tonight.
I gave it another go with v3.1.1. Reset everything to factory and tried English instead of Swedish.
Didn’t work for me… Same as before.
Talked to a guy with a Vera he also have problems. Another controller same problem.
He also have the 01B module fw 1,6.
Made a support request a couple of weeks ago to id lock. They replied talk to homey. Homey support replied talk to the app developer.
Hope @TedTolboom can work something out :+1:t2:
I also gave it another go with v.3.1.1. Same result as @Olle_Friskopps; it didn’t resolve the problem.
It’s a pretty frustrating issue - So yes, let’s hope @TedTolboom can look into our log’s and figure out if this is an App related issue.
Tomorrow i will reach out again to my supplier and ID Lock.
Just tried installing my first ID lock today, got same issues as mentioned above, “already added” etc.
Got my id lock the other day and i ended up with the same problems like above… funny thing when i did a local zwave reset it reset my mastercode as well for some reason. Had some minor issues getting the fw updated but that i solved.
“What you mention with the locks resetting at local reset is as designed. SiLabs, the owner of Z-Wave, added this as a requirement when our module was certified this summer. At a local reset, if associated with a gateway, the lock must also be reset.”
I got this from ID Lock when I contacted them about the same thing a couple of weeks ago. :slight_smile:
ID lock released a new firmware today:
Unfortunately, I can’t see anything regarding the issue we’re facing in the new version.
I have not tried to include my own - but after owning a Homey for 4 days and moving severalt units from another system - I believe its neither an app-issue or an iDlock-issue. I had a lot of problems including z-wave thermostats and dimmers.
When I try to include i get an error: No z-wave device found. Don’t know if thats the same problem as you guys have, but my solution were to go into homey settings - z-wave, exlude device, and run exclude-procedure on the device. Then I try to add the device again. On some devices I needed to do this maybe 10 times before it include in Homey correctly.
@silode
Well, i have not had any problems when including most of my 25+ devices (Heatit therm’s, Fibaro Smoke’s/Flood/Plug’s, Telldus plug’s, Qubino Flush Shutters DC’s and a Aeotec Siren Gen5).
The only issue i’m stuck with is the ID Lock 150 (and a Sensative Comfort strip constantly triggering heat and water alarm)
To minimize issues when including devices, make sure you’re close to the Homey while including (if not possible, connect a powerbank to Homey and move around).
If you experience poor zwave performance to some devices, then disconnect power from Homey for at least 10 minutes, then reconnect power and Homey will rebuild node routes on startup.
Reported the issue to Athom and got this feedback:
"Thank you for reporting this issue!
Unfortunately, this issue concerns an app that is not developed by us, but by a developer in our community.
You can contact the developer of this app via the Appstore. Please report this issue to this developer so he is aware of this issue.
If you have any issues regarding the Homey software or mobile app, feel free to contact us again."
So if some of you haven’t reported the issue to the app-developer, please do this to @TedTolboom here or Github: https://github.com/TedTolboom/no.IDLock/issues/27
Maby this could help him troubleshoot the issue.
Got my iDlock included in Homey on first try today.
What versions are you running? (Homey, Id lock and Z wave module)
Homey Pro - 3.1.1
iDlock updated just before inclusion, 1.5.0 id guess.
Z-wave says 01B written on it, not sure what version this uses.
Are you able to set all parameters, and remotely open and close the lock? I also got it included on one of the first tries, but only some commands worked. After removing it, I haven’t been able to include it again.
Yes, everything seems to work properly.
I got mine included the icon is there but nothing works in term off getting data from the lock or triggering events to it. I run 3.1.1 homey fw and 1.5 fw on the lock and the B version on the z-wave card. I sent a app diag log to Ted. Dont know if it will help him. But i hope it does.
@TedTolboom
Any progress here?
@All
Anyone at all who managed to include the lock after v3.x.x?
Also experiencing the same issue. I bought ID Lock 150 yesterday, installed the newest firmware 1.5.0. I have Z-wave chip “B” as far as I can tell. Running Homey 3.1.1, and ID Lock app v1.2.2, language is norwegian. I have tried factory reset of ID Lock 150 twice. When I try to add to z-wave the process seemingly works fine on ID Lock 150, in the app it’s just searching forever, distance to homey is around 5cm. If I try once more, I get the message “already added”. There is no ID Lock in the homey app. In the homey app under settings and z-wave, I can successfully remove the node, and repeat the whole process. Done it about 15-20 times so far.
Interestingly, under developer.athom.com, I see that I get an unknown node with a higher number. Right now it also tries to connect through node 16, which does not exist on my network. I have seen the same behaviour on Heatit Z-trm2fx thermostats a while back, had to factory reset several times, now one of these is also trying to connect through node 16, as well as a lamp (which I turn off the wrong way by cutting of electricity to the device, different floor). I included a log, this time the app didn’t even show the instructions how to add, but I presume that’s a different bug. Hopefully this is something that can be fixed, thanks for trying!
The log is: (Node 39 is a heatit thermostat, node 6 and 8 fibaro outlets. Node 63 is probably the ID Lock.
[2019-12-10T11:51:46.520Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:51:46.521Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[115,237,206,160,253,163,151,69]}
[2019-12-10T11:51:46.521Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x8073edcea0fda39745
[2019-12-10T11:51:46.523Z] Command[903] start: sendData
[2019-12-10T11:51:46.534Z] ProcessSendData[809]: To node: 39 with data: 0x988073edcea0fda39745 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:51:46.614Z] Command[903] end: sendData
[2019-12-10T11:51:50.108Z] Node[8]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x0131050422000079db
[2019-12-10T11:51:50.109Z] Node[8]: [COMMAND_CLASS_CRC_16_ENCAP] {"Command Class (Raw)":{"type":"Buffer","data":[49]},"Command Class":49,"Command (Raw)":{"type":"Buffer","data":[5]},"Command":5,"Data":{"type":"Buffer","data":[4,34,0,0]},"Checksum (Raw)":{"type":"Buffer","data":[121,219]},"Checksum":31195}
[2019-12-10T11:51:50.119Z] Node[8]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_SENSOR_MULTILEVEL, data 0x0504220000
[2019-12-10T11:51:50.120Z] Node[8]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value":{"type":"Buffer","data":[0,0]},"Sensor Value (Parsed)":0}
[2019-12-10T11:51:56.521Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:51:56.521Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:51:56.521Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[116,144,144,103,49,234,222,209]}
[2019-12-10T11:51:56.522Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x807490906731eaded1
[2019-12-10T11:51:56.524Z] Command[904] start: sendData
[2019-12-10T11:51:56.524Z] ProcessSendData[810]: To node: 39 with data: 0x98807490906731eaded1 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:51:56.614Z] Command[904] end: sendData
[2019-12-10T11:52:06.522Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:06.523Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:06.523Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[117,102,183,245,44,140,201,250]}
[2019-12-10T11:52:06.524Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x807566b7f52c8cc9fa
[2019-12-10T11:52:06.525Z] Command[905] start: sendData
[2019-12-10T11:52:06.526Z] ProcessSendData[811]: To node: 39 with data: 0x98807566b7f52c8cc9fa and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:06.614Z] Command[905] end: sendData
[2019-12-10T11:52:16.526Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:16.526Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:16.526Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[118,106,249,34,127,216,243,225]}
[2019-12-10T11:52:16.526Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x80766af9227fd8f3e1
[2019-12-10T11:52:16.528Z] Command[906] start: sendData
[2019-12-10T11:52:16.529Z] ProcessSendData[812]: To node: 39 with data: 0x9880766af9227fd8f3e1 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:16.613Z] Command[906] end: sendData
[2019-12-10T11:52:26.527Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:26.528Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:26.528Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[119,105,32,66,244,8,63,71]}
[2019-12-10T11:52:26.528Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x8077692042f4083f47
[2019-12-10T11:52:26.530Z] Command[907] start: sendData
[2019-12-10T11:52:26.531Z] ProcessSendData[813]: To node: 39 with data: 0x988077692042f4083f47 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:26.613Z] Command[907] end: sendData
[2019-12-10T11:52:27.847Z] Command[908] start: addNode
[2019-12-10T11:52:27.875Z] Command[908] status: addNode, status: ADD_NODE_STATUS_LEARN_READY
[2019-12-10T11:52:29.922Z] Command[908] status: addNode, status: ADD_NODE_STATUS_NODE_FOUND
[2019-12-10T11:52:30.303Z] Command[908] status: addNode, status: ADD_NODE_STATUS_ADDING_SLAVE
[2019-12-10T11:52:31.695Z] Command[908] status: addNode, status: ADD_NODE_STATUS_PROTOCOL_DONE
[2019-12-10T11:52:31.757Z] Command[908] status: addNode, status: ADD_NODE_STATUS_DONE
[2019-12-10T11:52:32.337Z] Command[908] status: addNode, status: INTERVIEW_SECURITY
[2019-12-10T11:52:32.337Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_SCHEME_GET] {"type":"Buffer","data":[0]}
[2019-12-10T11:52:32.338Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x0400
[2019-12-10T11:52:32.339Z] Command[909] start: sendData
[2019-12-10T11:52:32.339Z] ProcessSendData[815]: To node: 63 with data: 0x980400 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:32.383Z] Command[909] end: sendData
[2019-12-10T11:52:32.394Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x0500
[2019-12-10T11:52:32.395Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Supported Security Schemes (Raw)":{"type":"Buffer","data":[0]},"Supported Security Schemes":0}
[2019-12-10T11:52:32.400Z] Node[63]: [COMMAND_CLASS_SECURITY] [NETWORK_KEY_SET] {"type":"Buffer","data":[147,154,189,11,10,225,133,51,162,152,216,134,134,197,106,245]}
[2019-12-10T11:52:32.400Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:32.411Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:32.412Z] Command[910] start: sendData
[2019-12-10T11:52:32.412Z] ProcessSendData[816]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:32.451Z] Command[910] end: sendData
[2019-12-10T11:52:32.495Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80319de2911462201c
[2019-12-10T11:52:32.496Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[49,157,226,145,20,98,32,28]}}
[2019-12-10T11:52:32.498Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[105,108,117,91,211,52,214,104,250,23,90,201,153,112,118,228,145,105,18,205,79,144,251,217,205,172,176,49,97,80,80,254,43,187,86,245]}
[2019-12-10T11:52:32.498Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x81696c755bd334d668fa175ac9997076e4916912cd4f90fbd9cdacb031615050fe2bbb56f5
[2019-12-10T11:52:32.499Z] Command[911] start: sendData
[2019-12-10T11:52:32.499Z] ProcessSendData[817]: To node: 63 with data: 0x9881696c755bd334d668fa175ac9997076e4916912cd4f90fbd9cdacb031615050fe2bbb56f5 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:32.543Z] Command[911] end: sendData
[2019-12-10T11:52:32.577Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:32.577Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:32.577Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[120,14,243,88,45,109,163,203]}
[2019-12-10T11:52:32.578Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x80780ef3582d6da3cb
[2019-12-10T11:52:32.578Z] Command[912] start: sendData
[2019-12-10T11:52:32.578Z] ProcessSendData[818]: To node: 63 with data: 0x9880780ef3582d6da3cb and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:32.600Z] Command[912] end: sendData
[2019-12-10T11:52:32.630Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x8124b1dc6f85be733ffc39c678880dc987348dd107
[2019-12-10T11:52:32.631Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[36,177,220,111,133,190,115,63]},"Properties1 (Raw)":{"type":"Buffer","data":[252]},"Properties1":{"Sequence Counter":12,"Sequenced":true,"Second Frame":true},"Command byte":{"type":"Buffer","data":[57,198]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[120]},"Receivers nonce Identifier":120,"Message Authentication Code byte":{"type":"Buffer","data":[136,13,201,135,52,141,209,7]}}
[2019-12-10T11:52:32.644Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_SECURITY, data 0x07
[2019-12-10T11:52:32.644Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:32.648Z] Command[908] status: addNode, status: INTERVIEW_SECURITY_CC
[2019-12-10T11:52:32.649Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:32.649Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:32.649Z] Command[913] start: sendData
[2019-12-10T11:52:32.651Z] ProcessSendData[819]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:32.681Z] Command[913] end: sendData
[2019-12-10T11:52:32.707Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x8089ccf88b7acd3828
[2019-12-10T11:52:32.708Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[137,204,248,139,122,205,56,40]}}
[2019-12-10T11:52:32.709Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[10,133,105,211,94,61,132,121,118,66,208,137,210,233,122,149,122,229,181,106]}
[2019-12-10T11:52:32.710Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x810a8569d35e3d84797642d089d2e97a957ae5b56a
[2019-12-10T11:52:32.710Z] Command[914] start: sendData
[2019-12-10T11:52:32.710Z] ProcessSendData[820]: To node: 63 with data: 0x98810a8569d35e3d84797642d089d2e97a957ae5b56a and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:32.747Z] Command[914] end: sendData
[2019-12-10T11:52:32.763Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:32.763Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:32.763Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[121,188,113,115,13,197,201,249]}
[2019-12-10T11:52:32.764Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8079bc71730dc5c9f9
[2019-12-10T11:52:32.764Z] Command[915] start: sendData
[2019-12-10T11:52:32.764Z] ProcessSendData[821]: To node: 63 with data: 0x988079bc71730dc5c9f9 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:32.786Z] Command[915] end: sendData
[2019-12-10T11:52:32.821Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x818d7ef33b93ec51eeec57cf41621cccf13f26bb0451798ddbd3b7e662efc9
[2019-12-10T11:52:32.822Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[141,126,243,59,147,236,81,238]},"Properties1 (Raw)":{"type":"Buffer","data":[236]},"Properties1":{"Sequence Counter":12,"Sequenced":false,"Second Frame":true},"Command byte":{"type":"Buffer","data":[87,207,65,98,28,204,241,63,38,187,4,81]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[121]},"Receivers nonce Identifier":121,"Message Authentication Code byte":{"type":"Buffer","data":[141,219,211,183,230,98,239,201]}}
[2019-12-10T11:52:32.833Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_SECURITY, data 0x03008662638559717a80ef
[2019-12-10T11:52:32.834Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Reports to follow (Raw)":{"type":"Buffer","data":[0]},"Reports to follow":0,"Command Class support":{"type":"Buffer","data":[134,98,99,133,89,113,122,128]},"COMMAND_CLASS_MARK (Raw)":{"type":"Buffer","data":[239]},"COMMAND_CLASS_MARK":"COMMAND_CLASS_MARK"}
[2019-12-10T11:52:33.019Z] Command[908] status: addNode, status: INTERVIEW_CC
[2019-12-10T11:52:33.029Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x135e
[2019-12-10T11:52:33.029Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:33.029Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:33.030Z] Command[916] start: sendData
[2019-12-10T11:52:33.030Z] ProcessSendData[822]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.060Z] Command[916] end: sendData
[2019-12-10T11:52:33.078Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80f6ed16830943d7ae
[2019-12-10T11:52:33.078Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[246,237,22,131,9,67,215,174]}}
[2019-12-10T11:52:33.080Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[26,139,228,45,243,124,87,218,183,83,73,42,246,82,105,215,200,180,166,254,228]}
[2019-12-10T11:52:33.080Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x811a8be42df37c57dab753492af65269d7c8b4a6fee4
[2019-12-10T11:52:33.081Z] Command[917] start: sendData
[2019-12-10T11:52:33.081Z] ProcessSendData[823]: To node: 63 with data: 0x98811a8be42df37c57dab753492af65269d7c8b4a6fee4 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.118Z] Command[917] end: sendData
[2019-12-10T11:52:33.134Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:33.134Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:33.134Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[122,134,242,213,242,20,230,174]}
[2019-12-10T11:52:33.135Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x807a86f2d5f214e6ae
[2019-12-10T11:52:33.135Z] Command[918] start: sendData
[2019-12-10T11:52:33.135Z] ProcessSendData[824]: To node: 63 with data: 0x98807a86f2d5f214e6ae and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:33.158Z] Command[918] end: sendData
[2019-12-10T11:52:33.188Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x81185de59c17cf0eee3d2eb3e3317a27916f9bae35e40d
[2019-12-10T11:52:33.189Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[24,93,229,156,23,207,14,238]},"Properties1 (Raw)":{"type":"Buffer","data":[61]},"Properties1":{"Sequence Counter":13,"Sequenced":true,"Second Frame":true},"Command byte":{"type":"Buffer","data":[46,179,227,49]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[122]},"Receivers nonce Identifier":122,"Message Authentication Code byte":{"type":"Buffer","data":[39,145,111,155,174,53,228,13]}}
[2019-12-10T11:52:33.216Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x145e02
[2019-12-10T11:52:33.217Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[94]},"Requested Command Class":94,"Command Class Version (Raw)":{"type":"Buffer","data":[2]},"Command Class Version":2}
[2019-12-10T11:52:33.220Z] Command[908] status: addNode, status: INTERVIEW_CC_1_OF_15
[2019-12-10T11:52:33.221Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1372
[2019-12-10T11:52:33.221Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:33.221Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:33.222Z] Command[919] start: sendData
[2019-12-10T11:52:33.222Z] ProcessSendData[825]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.252Z] Command[919] end: sendData
[2019-12-10T11:52:33.270Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x800b57e2bac1a2ace5
[2019-12-10T11:52:33.270Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[11,87,226,186,193,162,172,229]}}
[2019-12-10T11:52:33.272Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[98,167,129,96,158,57,99,162,170,56,237,92,11,136,193,192,128,213,73,228,36]}
[2019-12-10T11:52:33.272Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8162a781609e3963a2aa38ed5c0b88c1c080d549e424
[2019-12-10T11:52:33.273Z] Command[920] start: sendData
[2019-12-10T11:52:33.273Z] ProcessSendData[826]: To node: 63 with data: 0x988162a781609e3963a2aa38ed5c0b88c1c080d549e424 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.310Z] Command[920] end: sendData
[2019-12-10T11:52:33.326Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:33.326Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:33.326Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[123,18,150,87,89,119,246,140]}
[2019-12-10T11:52:33.326Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x807b1296575977f68c
[2019-12-10T11:52:33.327Z] Command[921] start: sendData
[2019-12-10T11:52:33.327Z] ProcessSendData[827]: To node: 63 with data: 0x98807b1296575977f68c and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:33.349Z] Command[921] end: sendData
[2019-12-10T11:52:33.380Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x8187dddd89d2c56a3c063978d3d27b3aa15581fae5d6f6
[2019-12-10T11:52:33.381Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[135,221,221,137,210,197,106,60]},"Properties1 (Raw)":{"type":"Buffer","data":[6]},"Properties1":{"Sequence Counter":6,"Sequenced":false,"Second Frame":false},"Command byte":{"type":"Buffer","data":[57,120,211,210]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[123]},"Receivers nonce Identifier":123,"Message Authentication Code byte":{"type":"Buffer","data":[58,161,85,129,250,229,214,246]}}
[2019-12-10T11:52:33.392Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x147202
[2019-12-10T11:52:33.392Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[114]},"Requested Command Class":114,"Command Class Version (Raw)":{"type":"Buffer","data":[2]},"Command Class Version":2}
[2019-12-10T11:52:33.395Z] Command[908] status: addNode, status: INTERVIEW_CC_2_OF_15
[2019-12-10T11:52:33.396Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1398
[2019-12-10T11:52:33.396Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:33.396Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:33.397Z] Command[922] start: sendData
[2019-12-10T11:52:33.397Z] ProcessSendData[828]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.427Z] Command[922] end: sendData
[2019-12-10T11:52:33.445Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80d310a1dcd6911b12
[2019-12-10T11:52:33.445Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[211,16,161,220,214,145,27,18]}}
[2019-12-10T11:52:33.447Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[49,18,204,190,241,41,178,47,92,197,99,19,211,228,119,150,47,4,114,252,153]}
[2019-12-10T11:52:33.447Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x813112ccbef129b22f5cc56313d3e477962f0472fc99
[2019-12-10T11:52:33.448Z] Command[923] start: sendData
[2019-12-10T11:52:33.448Z] ProcessSendData[829]: To node: 63 with data: 0x98813112ccbef129b22f5cc56313d3e477962f0472fc99 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.485Z] Command[923] end: sendData
[2019-12-10T11:52:33.500Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:33.500Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:33.501Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[124,69,150,198,180,156,113,17]}
[2019-12-10T11:52:33.501Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x807c4596c6b49c7111
[2019-12-10T11:52:33.501Z] Command[924] start: sendData
[2019-12-10T11:52:33.502Z] ProcessSendData[830]: To node: 63 with data: 0x98807c4596c6b49c7111 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:33.524Z] Command[924] end: sendData```
Log part 2:
[2019-12-10T11:52:33.555Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[44,127,129,248,89,175,229,206]},"Properties1 (Raw)":{"type":"Buffer","data":[84]},"Properties1":{"Sequence Counter":4,"Sequenced":true,"Second Frame":false},"Command byte":{"type":"Buffer","data":[3,17,15,166]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[124]},"Receivers nonce Identifier":124,"Message Authentication Code byte":{"type":"Buffer","data":[31,242,124,221,233,103,244,40]}}
[2019-12-10T11:52:33.566Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x149801
[2019-12-10T11:52:33.567Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[152]},"Requested Command Class":152,"Command Class Version (Raw)":{"type":"Buffer","data":[1]},"Command Class Version":1}
[2019-12-10T11:52:33.581Z] Command[908] status: addNode, status: INTERVIEW_CC_3_OF_15
[2019-12-10T11:52:33.582Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x135a
[2019-12-10T11:52:33.582Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:33.582Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:33.583Z] Command[925] start: sendData
[2019-12-10T11:52:33.583Z] ProcessSendData[831]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.618Z] Command[925] end: sendData
[2019-12-10T11:52:33.636Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80d5a4d71ff2c7a941
[2019-12-10T11:52:33.636Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[213,164,215,31,242,199,169,65]}}
[2019-12-10T11:52:33.638Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[42,3,154,17,138,116,219,70,185,125,104,157,213,47,138,244,145,224,44,95,210]}
[2019-12-10T11:52:33.638Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x812a039a118a74db46b97d689dd52f8af491e02c5fd2
[2019-12-10T11:52:33.638Z] Command[926] start: sendData
[2019-12-10T11:52:33.639Z] ProcessSendData[832]: To node: 63 with data: 0x98812a039a118a74db46b97d689dd52f8af491e02c5fd2 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.675Z] Command[926] end: sendData
[2019-12-10T11:52:33.691Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:33.691Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:33.692Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[125,25,3,39,106,91,183,63]}
[2019-12-10T11:52:33.692Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x807d1903276a5bb73f
[2019-12-10T11:52:33.692Z] Command[927] start: sendData
[2019-12-10T11:52:33.693Z] ProcessSendData[833]: To node: 63 with data: 0x98807d1903276a5bb73f and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:33.714Z] Command[927] end: sendData
[2019-12-10T11:52:33.745Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x811b96480ebf99bfc5eb52c529757ddc5b62ef67841bd4
[2019-12-10T11:52:33.746Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[27,150,72,14,191,153,191,197]},"Properties1 (Raw)":{"type":"Buffer","data":[235]},"Properties1":{"Sequence Counter":11,"Sequenced":false,"Second Frame":true},"Command byte":{"type":"Buffer","data":[82,197,41,117]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[125]},"Receivers nonce Identifier":125,"Message Authentication Code byte":{"type":"Buffer","data":[220,91,98,239,103,132,27,212]}}
[2019-12-10T11:52:33.757Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x145a01
[2019-12-10T11:52:33.757Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[90]},"Requested Command Class":90,"Command Class Version (Raw)":{"type":"Buffer","data":[1]},"Command Class Version":1}
[2019-12-10T11:52:33.761Z] Command[908] status: addNode, status: INTERVIEW_CC_4_OF_15
[2019-12-10T11:52:33.762Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1373
[2019-12-10T11:52:33.762Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:33.762Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:33.763Z] Command[928] start: sendData
[2019-12-10T11:52:33.763Z] ProcessSendData[834]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.793Z] Command[928] end: sendData
[2019-12-10T11:52:33.811Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80bc423d062938184e
[2019-12-10T11:52:33.811Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[188,66,61,6,41,56,24,78]}}
[2019-12-10T11:52:33.813Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[136,113,158,240,170,59,179,203,173,93,232,29,188,100,129,123,217,27,2,9,207]}
[2019-12-10T11:52:33.813Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8188719ef0aa3bb3cbad5de81dbc64817bd91b0209cf
[2019-12-10T11:52:33.814Z] Command[929] start: sendData
[2019-12-10T11:52:33.814Z] ProcessSendData[835]: To node: 63 with data: 0x988188719ef0aa3bb3cbad5de81dbc64817bd91b0209cf and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.851Z] Command[929] end: sendData
[2019-12-10T11:52:33.866Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:33.866Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:33.867Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[126,144,49,255,76,164,62,64]}
[2019-12-10T11:52:33.867Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x807e9031ff4ca43e40
[2019-12-10T11:52:33.868Z] Command[930] start: sendData
[2019-12-10T11:52:33.868Z] ProcessSendData[836]: To node: 63 with data: 0x98807e9031ff4ca43e40 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:33.890Z] Command[930] end: sendData
[2019-12-10T11:52:33.921Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x81b796141c00a9f728fa75f116f87eadd1206376a9b242
[2019-12-10T11:52:33.921Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[183,150,20,28,0,169,247,40]},"Properties1 (Raw)":{"type":"Buffer","data":[250]},"Properties1":{"Sequence Counter":10,"Sequenced":true,"Second Frame":true},"Command byte":{"type":"Buffer","data":[117,241,22,248]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[126]},"Receivers nonce Identifier":126,"Message Authentication Code byte":{"type":"Buffer","data":[173,209,32,99,118,169,178,66]}}
[2019-12-10T11:52:33.939Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x147301
[2019-12-10T11:52:33.940Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[115]},"Requested Command Class":115,"Command Class Version (Raw)":{"type":"Buffer","data":[1]},"Command Class Version":1}
[2019-12-10T11:52:33.943Z] Command[908] status: addNode, status: INTERVIEW_CC_5_OF_15
[2019-12-10T11:52:33.943Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1370
[2019-12-10T11:52:33.943Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:33.944Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:33.944Z] Command[931] start: sendData
[2019-12-10T11:52:33.944Z] ProcessSendData[837]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:33.975Z] Command[931] end: sendData
[2019-12-10T11:52:33.992Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x8048299875882a67fb
[2019-12-10T11:52:33.993Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[72,41,152,117,136,42,103,251]}}
[2019-12-10T11:52:33.994Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[96,111,100,44,137,240,185,28,98,168,52,213,72,122,223,5,149,94,100,70,39]}
[2019-12-10T11:52:33.995Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x81606f642c89f0b91c62a834d5487adf05955e644627
[2019-12-10T11:52:33.995Z] Command[932] start: sendData
[2019-12-10T11:52:33.995Z] ProcessSendData[838]: To node: 63 with data: 0x9881606f642c89f0b91c62a834d5487adf05955e644627 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.032Z] Command[932] end: sendData
[2019-12-10T11:52:34.048Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:34.048Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:34.048Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[127,84,89,42,180,169,175,51]}
[2019-12-10T11:52:34.048Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x807f54592ab4a9af33
[2019-12-10T11:52:34.049Z] Command[933] start: sendData
[2019-12-10T11:52:34.049Z] ProcessSendData[839]: To node: 63 with data: 0x98807f54592ab4a9af33 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:34.071Z] Command[933] end: sendData
[2019-12-10T11:52:34.102Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x81fa022b1b383d60a2793ec702b47fc16bedf045dd196a
[2019-12-10T11:52:34.103Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[250,2,43,27,56,61,96,162]},"Properties1 (Raw)":{"type":"Buffer","data":[121]},"Properties1":{"Sequence Counter":9,"Sequenced":true,"Second Frame":true},"Command byte":{"type":"Buffer","data":[62,199,2,180]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[127]},"Receivers nonce Identifier":127,"Message Authentication Code byte":{"type":"Buffer","data":[193,107,237,240,69,221,25,106]}}
[2019-12-10T11:52:34.113Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x147001
[2019-12-10T11:52:34.114Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[112]},"Requested Command Class":112,"Command Class Version (Raw)":{"type":"Buffer","data":[1]},"Command Class Version":1}
[2019-12-10T11:52:34.116Z] Command[908] status: addNode, status: INTERVIEW_CC_6_OF_15
[2019-12-10T11:52:34.117Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1320
[2019-12-10T11:52:34.117Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:34.117Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:34.118Z] Command[934] start: sendData
[2019-12-10T11:52:34.118Z] ProcessSendData[840]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.148Z] Command[934] end: sendData
[2019-12-10T11:52:34.166Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80921490c726b1b454
[2019-12-10T11:52:34.166Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[146,20,144,199,38,177,180,84]}}
[2019-12-10T11:52:34.168Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[122,231,218,15,237,228,192,165,133,113,147,8,146,65,193,155,32,62,167,186,117]}
[2019-12-10T11:52:34.169Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x817ae7da0fede4c0a5857193089241c19b203ea7ba75
[2019-12-10T11:52:34.169Z] Command[935] start: sendData
[2019-12-10T11:52:34.170Z] ProcessSendData[841]: To node: 63 with data: 0x98817ae7da0fede4c0a5857193089241c19b203ea7ba75 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.207Z] Command[935] end: sendData
[2019-12-10T11:52:34.223Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:34.223Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:34.223Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[128,214,45,248,99,93,192,196]}
[2019-12-10T11:52:34.224Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8080d62df8635dc0c4
[2019-12-10T11:52:34.224Z] Command[936] start: sendData
[2019-12-10T11:52:34.224Z] ProcessSendData[842]: To node: 63 with data: 0x988080d62df8635dc0c4 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:34.246Z] Command[936] end: sendData
[2019-12-10T11:52:34.277Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x81fae9e6529fb5e8f48e41446dd380e01ed2b45f50692a
[2019-12-10T11:52:34.278Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[250,233,230,82,159,181,232,244]},"Properties1 (Raw)":{"type":"Buffer","data":[142]},"Properties1":{"Sequence Counter":14,"Sequenced":false,"Second Frame":false},"Command byte":{"type":"Buffer","data":[65,68,109,211]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[128]},"Receivers nonce Identifier":128,"Message Authentication Code byte":{"type":"Buffer","data":[224,30,210,180,95,80,105,42]}}
[2019-12-10T11:52:34.296Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x142000
[2019-12-10T11:52:34.296Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[32]},"Requested Command Class":32,"Command Class Version (Raw)":{"type":"Buffer","data":[0]},"Command Class Version":0}
[2019-12-10T11:52:34.299Z] Command[908] status: addNode, status: INTERVIEW_CC_7_OF_15
[2019-12-10T11:52:34.300Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1386
[2019-12-10T11:52:34.300Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:34.300Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:34.301Z] Command[937] start: sendData
[2019-12-10T11:52:34.301Z] ProcessSendData[843]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.331Z] Command[937] end: sendData
[2019-12-10T11:52:34.349Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80cde68c72ad5ecc2b
[2019-12-10T11:52:34.349Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[205,230,140,114,173,94,204,43]}}
[2019-12-10T11:52:34.351Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[254,43,150,68,88,224,54,130,229,111,48,223,205,18,58,243,207,16,13,25,227]}
[2019-12-10T11:52:34.351Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x81fe2b964458e03682e56f30dfcd123af3cf100d19e3
[2019-12-10T11:52:34.351Z] Command[938] start: sendData
[2019-12-10T11:52:34.352Z] ProcessSendData[844]: To node: 63 with data: 0x9881fe2b964458e03682e56f30dfcd123af3cf100d19e3 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.395Z] Command[938] end: sendData
[2019-12-10T11:52:34.411Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:34.411Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:34.411Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[129,9,66,217,182,61,68,31]}
[2019-12-10T11:52:34.411Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x80810942d9b63d441f
[2019-12-10T11:52:34.412Z] Command[939] start: sendData
[2019-12-10T11:52:34.412Z] ProcessSendData[845]: To node: 63 with data: 0x9880810942d9b63d441f and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:34.434Z] Command[939] end: sendData
[2019-12-10T11:52:34.465Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x81c90fe20bb42244123b5ddeef5681df880f5545b345e2
[2019-12-10T11:52:34.466Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[201,15,226,11,180,34,68,18]},"Properties1 (Raw)":{"type":"Buffer","data":[59]},"Properties1":{"Sequence Counter":11,"Sequenced":true,"Second Frame":true},"Command byte":{"type":"Buffer","data":[93,222,239,86]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[129]},"Receivers nonce Identifier":129,"Message Authentication Code byte":{"type":"Buffer","data":[223,136,15,85,69,179,69,226]}}
[2019-12-10T11:52:34.476Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x148602
[2019-12-10T11:52:34.476Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[134]},"Requested Command Class":134,"Command Class Version (Raw)":{"type":"Buffer","data":[2]},"Command Class Version":2}
[2019-12-10T11:52:34.479Z] Command[908] status: addNode, status: INTERVIEW_CC_8_OF_15
[2019-12-10T11:52:34.480Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1362
[2019-12-10T11:52:34.480Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:34.480Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:34.481Z] Command[940] start: sendData
[2019-12-10T11:52:34.481Z] ProcessSendData[846]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.511Z] Command[940] end: sendData
[2019-12-10T11:52:34.529Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80866de4fcd12c69f0
[2019-12-10T11:52:34.530Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[134,109,228,252,209,44,105,240]}}
[2019-12-10T11:52:34.531Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[14,182,71,159,7,17,56,236,43,115,123,231,134,148,192,252,10,24,57,244,45]}
[2019-12-10T11:52:34.531Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x810eb6479f071138ec2b737be78694c0fc0a1839f42d
[2019-12-10T11:52:34.532Z] Command[941] start: sendData
[2019-12-10T11:52:34.532Z] ProcessSendData[847]: To node: 63 with data: 0x98810eb6479f071138ec2b737be78694c0fc0a1839f42d and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.569Z] Command[941] end: sendData
[2019-12-10T11:52:34.584Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:34.585Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:34.585Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[130,140,44,76,231,209,87,53]}
[2019-12-10T11:52:34.585Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x80828c2c4ce7d15735
[2019-12-10T11:52:34.585Z] Command[942] start: sendData
[2019-12-10T11:52:34.586Z] ProcessSendData[848]: To node: 63 with data: 0x9880828c2c4ce7d15735 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:34.608Z] Command[942] end: sendData
[2019-12-10T11:52:34.638Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x811f11106aca2e9bdddef79d1b53821ce499ac334b2ba9
[2019-12-10T11:52:34.639Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[31,17,16,106,202,46,155,221]},"Properties1 (Raw)":{"type":"Buffer","data":[222]},"Properties1":{"Sequence Counter":14,"Sequenced":true,"Second Frame":false},"Command byte":{"type":"Buffer","data":[247,157,27,83]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[130]},"Receivers nonce Identifier":130,"Message Authentication Code byte":{"type":"Buffer","data":[28,228,153,172,51,75,43,169]}}
[2019-12-10T11:52:34.649Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x146202
[2019-12-10T11:52:34.650Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[98]},"Requested Command Class":98,"Command Class Version (Raw)":{"type":"Buffer","data":[2]},"Command Class Version":2}
[2019-12-10T11:52:34.653Z] Command[908] status: addNode, status: INTERVIEW_CC_9_OF_15
[2019-12-10T11:52:34.653Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1363
[2019-12-10T11:52:34.654Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:34.654Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:34.654Z] Command[943] start: sendData
[2019-12-10T11:52:34.656Z] ProcessSendData[849]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.686Z] Command[943] end: sendData
[2019-12-10T11:52:34.703Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x802d5be4507d5ac5c6
[2019-12-10T11:52:34.704Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[45,91,228,80,125,90,197,198]}}
[2019-12-10T11:52:34.705Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[194,243,243,174,62,109,85,163,132,27,254,182,45,75,62,6,66,41,97,157,175]}
[2019-12-10T11:52:34.706Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x81c2f3f3ae3e6d55a3841bfeb62d4b3e064229619daf
[2019-12-10T11:52:34.706Z] Command[944] start: sendData
[2019-12-10T11:52:34.706Z] ProcessSendData[850]: To node: 63 with data: 0x9881c2f3f3ae3e6d55a3841bfeb62d4b3e064229619daf and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.743Z] Command[944] end: sendData
[2019-12-10T11:52:34.758Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:34.759Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:34.759Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[131,229,177,91,171,127,69,129]}
[2019-12-10T11:52:34.760Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8083e5b15bab7f4581
[2019-12-10T11:52:34.760Z] Command[945] start: sendData
[2019-12-10T11:52:34.760Z] ProcessSendData[851]: To node: 63 with data: 0x988083e5b15bab7f4581 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:34.782Z] Command[945] end: sendData
[2019-12-10T11:52:34.813Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x816d131960ac0270449ef97cc86f8368d4641e56346423
[2019-12-10T11:52:34.814Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[109,19,25,96,172,2,112,68]},"Properties1 (Raw)":{"type":"Buffer","data":[158]},"Properties1":{"Sequence Counter":14,"Sequenced":true,"Second Frame":false},"Command byte":{"type":"Buffer","data":[249,124,200,111]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[131]},"Receivers nonce Identifier":131,"Message Authentication Code byte":{"type":"Buffer","data":[104,212,100,30,86,52,100,35]}}
[2019-12-10T11:52:34.824Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x146301
[2019-12-10T11:52:34.825Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[99]},"Requested Command Class":99,"Command Class Version (Raw)":{"type":"Buffer","data":[1]},"Command Class Version":1}
[2019-12-10T11:52:34.828Z] Command[908] status: addNode, status: INTERVIEW_CC_10_OF_15
[2019-12-10T11:52:34.829Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1385
[2019-12-10T11:52:34.829Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:34.829Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:34.830Z] Command[946] start: sendData
[2019-12-10T11:52:34.830Z] ProcessSendData[852]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.860Z] Command[946] end: sendData
[2019-12-10T11:52:34.878Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80e81efe1e516b8aa9
[2019-12-10T11:52:34.878Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[232,30,254,30,81,107,138,169]}}
[2019-12-10T11:52:34.880Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[120,239,169,137,98,47,179,130,16,40,16,248,232,78,106,92,174,213,160,249,51]}
[2019-12-10T11:52:34.880Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8178efa989622fb382102810f8e84e6a5caed5a0f933
[2019-12-10T11:52:34.880Z] Command[947] start: sendData
[2019-12-10T11:52:34.881Z] ProcessSendData[853]: To node: 63 with data: 0x988178efa989622fb382102810f8e84e6a5caed5a0f933 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:34.917Z] Command[947] end: sendData
[2019-12-10T11:52:34.933Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:34.933Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:34.934Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[132,203,249,147,17,166,198,97]}
[2019-12-10T11:52:34.934Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8084cbf99311a6c661
[2019-12-10T11:52:34.934Z] Command[948] start: sendData
[2019-12-10T11:52:34.934Z] ProcessSendData[854]: To node: 63 with data: 0x988084cbf99311a6c661 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:34.957Z] Command[948] end: sendData
[2019-12-10T11:52:34.987Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x81aff568e3a63c4bddf384a939aa841419a7978741a89e
[2019-12-10T11:52:34.988Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[175,245,104,227,166,60,75,221]},"Properties1 (Raw)":{"type":"Buffer","data":[243]},"Properties1":{"Sequence Counter":3,"Sequenced":true,"Second Frame":true},"Command byte":{"type":"Buffer","data":[132,169,57,170]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[132]},"Receivers nonce Identifier":132,"Message Authentication Code byte":{"type":"Buffer","data":[20,25,167,151,135,65,168,158]}}
[2019-12-10T11:52:34.999Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x148502
[2019-12-10T11:52:34.999Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[133]},"Requested Command Class":133,"Command Class Version (Raw)":{"type":"Buffer","data":[2]},"Command Class Version":2}
[2019-12-10T11:52:35.002Z] Command[908] status: addNode, status: INTERVIEW_CC_11_OF_15
[2019-12-10T11:52:35.002Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1359
[2019-12-10T11:52:35.003Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:35.003Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:35.003Z] Command[949] start: sendData
[2019-12-10T11:52:35.004Z] ProcessSendData[855]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:35.034Z] Command[949] end: sendData
[2019-12-10T11:52:35.044Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x808845ad26a1425451
[2019-12-10T11:52:35.044Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[136,69,173,38,161,66,84,81]}}
[2019-12-10T11:52:35.046Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[76,211,63,45,202,248,64,189,58,26,252,26,136,51,117,160,69,248,238,184,38]}
[2019-12-10T11:52:35.046Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x814cd33f2dcaf840bd3a1afc1a883375a045f8eeb826
[2019-12-10T11:52:35.046Z] Command[950] start: sendData
[2019-12-10T11:52:35.047Z] ProcessSendData[856]: To node: 63 with data: 0x98814cd33f2dcaf840bd3a1afc1a883375a045f8eeb826 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:35.189Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40```
Log part 3:
[2019-12-10T11:52:35.189Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[133,141,120,202,138,20,44,7]}
[2019-12-10T11:52:35.190Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x80858d78ca8a142c07
[2019-12-10T11:52:35.191Z] Command[950] end: sendData
[2019-12-10T11:52:35.200Z] Command[951] start: sendData
[2019-12-10T11:52:35.200Z] ProcessSendData[857]: To node: 63 with data: 0x9880858d78ca8a142c07 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:35.230Z] Command[951] end: sendData
[2019-12-10T11:52:35.253Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x81c9ceaec21fda377523b5c283038589bef789599d90e5
[2019-12-10T11:52:35.254Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[201,206,174,194,31,218,55,117]},"Properties1 (Raw)":{"type":"Buffer","data":[35]},"Properties1":{"Sequence Counter":3,"Sequenced":false,"Second Frame":true},"Command byte":{"type":"Buffer","data":[181,194,131,3]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[133]},"Receivers nonce Identifier":133,"Message Authentication Code byte":{"type":"Buffer","data":[137,190,247,137,89,157,144,229]}}
[2019-12-10T11:52:35.265Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x145901
[2019-12-10T11:52:35.265Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[89]},"Requested Command Class":89,"Command Class Version (Raw)":{"type":"Buffer","data":[1]},"Command Class Version":1}
[2019-12-10T11:52:35.268Z] Command[908] status: addNode, status: INTERVIEW_CC_12_OF_15
[2019-12-10T11:52:35.268Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1371
[2019-12-10T11:52:35.269Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:35.269Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:35.269Z] Command[952] start: sendData
[2019-12-10T11:52:35.270Z] ProcessSendData[858]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:35.300Z] Command[952] end: sendData
[2019-12-10T11:52:35.318Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80990956a35a939c6c
[2019-12-10T11:52:35.318Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[153,9,86,163,90,147,156,108]}}
[2019-12-10T11:52:35.320Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[15,165,97,243,60,187,183,46,25,185,10,119,153,217,199,46,72,182,172,236,99]}
[2019-12-10T11:52:35.320Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x810fa561f33cbbb72e19b90a7799d9c72e48b6acec63
[2019-12-10T11:52:35.320Z] Command[953] start: sendData
[2019-12-10T11:52:35.320Z] ProcessSendData[859]: To node: 63 with data: 0x98810fa561f33cbbb72e19b90a7799d9c72e48b6acec63 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:35.359Z] Command[953] end: sendData
[2019-12-10T11:52:35.375Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:35.375Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:35.376Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[134,157,58,227,62,159,198,236]}
[2019-12-10T11:52:35.376Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x80869d3ae33e9fc6ec
[2019-12-10T11:52:35.376Z] Command[954] start: sendData
[2019-12-10T11:52:35.377Z] ProcessSendData[860]: To node: 63 with data: 0x9880869d3ae33e9fc6ec and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:35.398Z] Command[954] end: sendData
[2019-12-10T11:52:35.429Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x81891b390e6888b4482de4d81155866d9e71926ce3b0ce
[2019-12-10T11:52:35.430Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[137,27,57,14,104,136,180,72]},"Properties1 (Raw)":{"type":"Buffer","data":[45]},"Properties1":{"Sequence Counter":13,"Sequenced":false,"Second Frame":true},"Command byte":{"type":"Buffer","data":[228,216,17,85]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[134]},"Receivers nonce Identifier":134,"Message Authentication Code byte":{"type":"Buffer","data":[109,158,113,146,108,227,176,206]}}
[2019-12-10T11:52:35.445Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x147104
[2019-12-10T11:52:35.445Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[113]},"Requested Command Class":113,"Command Class Version (Raw)":{"type":"Buffer","data":[4]},"Command Class Version":4}
[2019-12-10T11:52:35.448Z] Command[908] status: addNode, status: INTERVIEW_CC_13_OF_15
[2019-12-10T11:52:35.448Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x137a
[2019-12-10T11:52:35.449Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:35.449Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:35.449Z] Command[955] start: sendData
[2019-12-10T11:52:35.450Z] ProcessSendData[861]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:35.480Z] Command[955] end: sendData
[2019-12-10T11:52:35.498Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x80962f40857ed5b797
[2019-12-10T11:52:35.498Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[150,47,64,133,126,213,183,151]}}
[2019-12-10T11:52:35.500Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[7,232,199,158,45,12,152,107,90,112,195,110,150,117,205,3,253,15,55,73,4]}
[2019-12-10T11:52:35.500Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8107e8c79e2d0c986b5a70c36e9675cd03fd0f374904
[2019-12-10T11:52:35.500Z] Command[956] start: sendData
[2019-12-10T11:52:35.501Z] ProcessSendData[862]: To node: 63 with data: 0x988107e8c79e2d0c986b5a70c36e9675cd03fd0f374904 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:35.537Z] Command[956] end: sendData
[2019-12-10T11:52:35.545Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:35.545Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:35.546Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[135,184,7,72,246,209,165,4]}
[2019-12-10T11:52:35.546Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8087b80748f6d1a504
[2019-12-10T11:52:35.546Z] Command[957] start: sendData
[2019-12-10T11:52:35.547Z] ProcessSendData[863]: To node: 63 with data: 0x988087b80748f6d1a504 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:35.570Z] Command[957] end: sendData
[2019-12-10T11:52:35.600Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x815682925b6c1992f02c4e988d7b879dc8473c02cf9b10
[2019-12-10T11:52:35.601Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[86,130,146,91,108,25,146,240]},"Properties1 (Raw)":{"type":"Buffer","data":[44]},"Properties1":{"Sequence Counter":12,"Sequenced":false,"Second Frame":true},"Command byte":{"type":"Buffer","data":[78,152,141,123]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[135]},"Receivers nonce Identifier":135,"Message Authentication Code byte":{"type":"Buffer","data":[157,200,71,60,2,207,155,16]}}
[2019-12-10T11:52:35.612Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x147a02
[2019-12-10T11:52:35.612Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[122]},"Requested Command Class":122,"Command Class Version (Raw)":{"type":"Buffer","data":[2]},"Command Class Version":2}
[2019-12-10T11:52:35.615Z] Command[908] status: addNode, status: INTERVIEW_CC_14_OF_15
[2019-12-10T11:52:35.616Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x1380
[2019-12-10T11:52:35.616Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:35.616Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:35.616Z] Command[958] start: sendData
[2019-12-10T11:52:35.617Z] ProcessSendData[864]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:35.647Z] Command[958] end: sendData
[2019-12-10T11:52:35.665Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x801486399a0af64513
[2019-12-10T11:52:35.665Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[20,134,57,154,10,246,69,19]}}
[2019-12-10T11:52:35.667Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[185,4,214,117,185,87,66,9,252,215,23,234,20,68,140,247,66,187,1,97,144]}
[2019-12-10T11:52:35.667Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x81b904d675b9574209fcd717ea14448cf742bb016190
[2019-12-10T11:52:35.667Z] Command[959] start: sendData
[2019-12-10T11:52:35.668Z] ProcessSendData[865]: To node: 63 with data: 0x9881b904d675b9574209fcd717ea14448cf742bb016190 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:35.708Z] Command[959] end: sendData
[2019-12-10T11:52:35.720Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:35.720Z] Node[63]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:35.720Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[136,150,243,12,167,16,109,91]}
[2019-12-10T11:52:35.721Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x808896f30ca7106d5b
[2019-12-10T11:52:35.721Z] Command[960] start: sendData
[2019-12-10T11:52:35.721Z] ProcessSendData[866]: To node: 63 with data: 0x98808896f30ca7106d5b and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:35.743Z] Command[960] end: sendData
[2019-12-10T11:52:35.774Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x81891b8d2660a5aa8c8943d2d2cd882de697af94c76d42
[2019-12-10T11:52:35.775Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[137,27,141,38,96,165,170,140]},"Properties1 (Raw)":{"type":"Buffer","data":[137]},"Properties1":{"Sequence Counter":9,"Sequenced":false,"Second Frame":false},"Command byte":{"type":"Buffer","data":[67,210,210,205]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[136]},"Receivers nonce Identifier":136,"Message Authentication Code byte":{"type":"Buffer","data":[45,230,151,175,148,199,109,66]}}
[2019-12-10T11:52:35.785Z] Node[63]: Decapsulated frame from COMMAND_CLASS_SECURITY to COMMAND_CLASS_VERSION, data 0x148001
[2019-12-10T11:52:35.785Z] Node[63]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[128]},"Requested Command Class":128,"Command Class Version (Raw)":{"type":"Buffer","data":[1]},"Command Class Version":1}
[2019-12-10T11:52:35.788Z] Command[908] status: addNode, status: INTERVIEW_CC_15_OF_15
[2019-12-10T11:52:36.255Z] Command[908] status: addNode, status: INTERVIEW_MANUFACTURER_SPECIFIC
[2019-12-10T11:52:36.267Z] Node[63]: sendData to COMMAND_CLASS_MANUFACTURER_SPECIFIC, params 0x04
[2019-12-10T11:52:36.268Z] Command[961] start: sendData
[2019-12-10T11:52:36.268Z] ProcessSendData[867]: To node: 63 with data: 0x7204 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:36.298Z] Command[961] end: sendData
[2019-12-10T11:52:36.315Z] Node[63]: Received application command for COMMAND_CLASS_MANUFACTURER_SPECIFIC, data: 0x05037300030001
[2019-12-10T11:52:36.336Z] Node[63]: [COMMAND_CLASS_MANUFACTURER_SPECIFIC] {"Manufacturer ID":{"value":883},"Product Type ID":{"value":3},"Product ID":{"value":1}}
[2019-12-10T11:52:36.341Z] Command[908] status: addNode, status: INTERVIEW_FIRMWARE_INFORMATION
[2019-12-10T11:52:36.341Z] Node[63]: sendData to COMMAND_CLASS_VERSION, params 0x11
[2019-12-10T11:52:36.341Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {"type":"Buffer","data":[]}
[2019-12-10T11:52:36.342Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2019-12-10T11:52:36.342Z] Command[962] start: sendData
[2019-12-10T11:52:36.342Z] ProcessSendData[868]: To node: 63 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:36.372Z] Command[962] end: sendData
[2019-12-10T11:52:36.390Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x8024c6f700e6feb222
[2019-12-10T11:52:36.391Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Nonce byte":{"type":"Buffer","data":[36,198,247,0,230,254,178,34]}}
[2019-12-10T11:52:36.392Z] Node[63]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {"type":"Buffer","data":[105,145,112,150,163,79,117,119,62,4,136,36,125,170,45,125,129,132,79,124]}
[2019-12-10T11:52:36.392Z] Node[63]: sendData to COMMAND_CLASS_SECURITY, params 0x8169917096a34f75773e0488247daa2d7d81844f7c
[2019-12-10T11:52:36.393Z] Command[963] start: sendData
[2019-12-10T11:52:36.395Z] ProcessSendData[869]: To node: 63 with data: 0x988169917096a34f75773e0488247daa2d7d81844f7c and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2019-12-10T11:52:36.431Z] Command[963] end: sendData
[2019-12-10T11:52:36.529Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:36.530Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:36.530Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[137,136,242,139,231,117,251,109]}
[2019-12-10T11:52:36.530Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x808988f28be775fb6d
[2019-12-10T11:52:37.276Z] Node[63]: Received application command for COMMAND_CLASS_SECURITY, data: 0x8143111290519ea9abf667bf5daea81ac56009f90d88ccc52dcb0e408397
[2019-12-10T11:52:37.277Z] Node[63]: [COMMAND_CLASS_SECURITY] {"Initialization Vector byte":{"type":"Buffer","data":[67,17,18,144,81,158,169,171]},"Properties1 (Raw)":{"type":"Buffer","data":[246]},"Properties1":{"Sequence Counter":6,"Sequenced":true,"Second Frame":true},"Command byte":{"type":"Buffer","data":[103,191,93,174,168,26,197,96,9,249,13]},"Receivers nonce Identifier (Raw)":{"type":"Buffer","data":[136]},"Receivers nonce Identifier":136,"Message Authentication Code byte":{"type":"Buffer","data":[204,197,45,203,14,64,131,151]}}
[2019-12-10T11:52:46.533Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:46.533Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:46.534Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[138,32,220,132,228,16,74,67]}
[2019-12-10T11:52:46.534Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x808a20dc84e4104a43
[2019-12-10T11:52:50.222Z] Command[964] start: sendData
[2019-12-10T11:52:50.222Z] ProcessSendData[870]: To node: 39 with data: 0x98808988f28be775fb6d and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:50.232Z] Command[965] start: addNodeAbort
[2019-12-10T11:52:50.233Z] Command[965] end: addNodeAbort
[2019-12-10T11:52:50.275Z] Command[964] end: sendData
[2019-12-10T11:52:50.275Z] Command[966] start: sendData
[2019-12-10T11:52:50.276Z] ProcessSendData[871]: To node: 39 with data: 0x98808a20dc84e4104a43 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:50.295Z] Command[966] end: sendData
[2019-12-10T11:52:56.535Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:52:56.535Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:52:56.535Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[139,223,125,238,254,130,201,48]}
[2019-12-10T11:52:56.536Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x808bdf7deefe82c930
[2019-12-10T11:52:56.538Z] Command[967] start: sendData
[2019-12-10T11:52:56.539Z] ProcessSendData[872]: To node: 39 with data: 0x98808bdf7deefe82c930 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:52:56.625Z] Command[967] end: sendData
[2019-12-10T11:53:06.347Z] Command[908] end: addNode
[2019-12-10T11:53:06.574Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:53:06.574Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:53:06.578Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[140,57,104,204,55,184,142,179]}
[2019-12-10T11:53:06.579Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x808c3968cc37b88eb3
[2019-12-10T11:53:06.579Z] Command[968] start: sendData
[2019-12-10T11:53:06.580Z] ProcessSendData[873]: To node: 39 with data: 0x98808c3968cc37b88eb3 and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:53:06.623Z] Command[968] end: sendData
[2019-12-10T11:53:16.539Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:53:16.540Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:53:16.540Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[141,182,127,150,72,49,12,191]}
[2019-12-10T11:53:16.540Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x808db67f9648310cbf
[2019-12-10T11:53:16.542Z] Command[969] start: sendData
[2019-12-10T11:53:16.543Z] ProcessSendData[874]: To node: 39 with data: 0x98808db67f9648310cbf and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:53:16.623Z] Command[969] end: sendData
[2019-12-10T11:53:20.280Z] Node[6]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01320221440008bd6c0000219a
[2019-12-10T11:53:20.281Z] Node[6]: [COMMAND_CLASS_CRC_16_ENCAP] {"Command Class (Raw)":{"type":"Buffer","data":[50]},"Command Class":50,"Command (Raw)":{"type":"Buffer","data":[2]},"Command":2,"Data":{"type":"Buffer","data":[33,68,0,8,189,108,0,0]},"Checksum (Raw)":{"type":"Buffer","data":[33,154]},"Checksum":8602}
[2019-12-10T11:53:20.290Z] Node[6]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_METER, data 0x0221440008bd6c0000
[2019-12-10T11:53:20.292Z] Node[6]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Reserved":false,"Meter Type (Parsed)":{"value":1,"name":"Single-E electric meter"},"Rate Type (Parsed)":{"value":1,"name":"Import"}},"Properties2 (Raw)":{"type":"Buffer","data":[68]},"Properties2":{"Size":4,"Scale":0,"Precision":2},"Meter Value":{"type":"Buffer","data":[0,8,189,108]},"Delta Time (Raw)":{"type":"Buffer","data":[0,0]},"Delta Time":0,"Meter Value (Parsed)":5727.8}
[2019-12-10T11:53:21.697Z] Command[970] start: removeNode
[2019-12-10T11:53:21.706Z] Command[970] status: removeNode, status: REMOVE_NODE_STATUS_LEARN_READY
[2019-12-10T11:53:23.898Z] Command[970] status: removeNode, status: REMOVE_NODE_STATUS_NODE_FOUND
[2019-12-10T11:53:24.145Z] Command[970] status: removeNode, status: REMOVE_NODE_STATUS_REMOVING_SLAVE
[2019-12-10T11:53:24.149Z] Command[970] status: removeNode, status: REMOVE_NODE_STATUS_DONE
[2019-12-10T11:53:24.286Z] Command[970] end: removeNode
[2019-12-10T11:53:26.587Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:53:26.587Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:53:26.588Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[142,198,18,100,84,46,231,142]}
[2019-12-10T11:53:26.588Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x808ec61264542ee78e
[2019-12-10T11:53:26.590Z] Command[971] start: sendData
[2019-12-10T11:53:26.590Z] ProcessSendData[876]: To node: 39 with data: 0x98808ec61264542ee78e and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:53:26.673Z] Command[971] end: sendData
[2019-12-10T11:53:36.544Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:53:36.545Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:53:36.545Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[143,167,215,9,166,225,236,74]}
[2019-12-10T11:53:36.545Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x808fa7d709a6e1ec4a
[2019-12-10T11:53:36.547Z] Command[972] start: sendData
[2019-12-10T11:53:36.547Z] ProcessSendData[877]: To node: 39 with data: 0x98808fa7d709a6e1ec4a and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:53:36.633Z] Command[972] end: sendData
[2019-12-10T11:53:46.548Z] Node[39]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2019-12-10T11:53:46.548Z] Node[39]: [COMMAND_CLASS_SECURITY] {}
[2019-12-10T11:53:46.548Z] Node[39]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {"type":"Buffer","data":[144,2,49,247,11,245,49,204]}
[2019-12-10T11:53:46.548Z] Node[39]: sendData to COMMAND_CLASS_SECURITY, params 0x80900231f70bf531cc
[2019-12-10T11:53:46.550Z] Command[973] start: sendData
[2019-12-10T11:53:46.551Z] ProcessSendData[878]: To node: 39 with data: 0x9880900231f70bf531cc and txOptions: AUTO_ROUTE,EXPLORE
[2019-12-10T11:53:46.633Z] Command[973] end: sendData```
