[APP][Pro] Huawei Solar - Smart energy for a better life
If you can enable the MODBUS-TCP on you Huawei inverter, then you can use the SolarEdge + Growatt-TCP-Modbus app
Another MODBUS alternative, if you’re up for some tinkering is to create you own devices using a combination of the Device Capabilities and Modbus apps
EDIT: Enabling the MODBUS-TCP might need to be done by your installer. I gave mine the following link as he wasn’t sure where to apply the setting :slight_smile: https://uni002eu5.fusionsolar.huawei.com/hedex/hedex.do?lib=DP_en&pidid=pid_neteco_faq&topicid=TOPIC_0000001543186965&locale=en-us&hdxsrc=original&keyword=MODBUS&keyword=modbus
The same for me, why this problem? Now I’m using solaredge growath tcp modus app, is better this app or app only for huawei?
It seems like there has been some updating in the meantime - at least for the test version. But the problems stay the same (null is not an object). Any updates (app- or user-associated problem)?
Maybe developer is dead…
Hello. I’m new to the Homey community.
Yes, indeed I can’t integrate the Huawei inverter into Homey Pro either.
But… I use a simple version to see the current production and use it in flows.
I use an Energy Meter + 2 pieces of 50A Clamps. In this case I can read the energy produced and the energy exported / imported into the network.
no update -.-
This app is dead, go checkout:
