[APP][Pro] Huawei FusionSolar Manager
Good evening, I am receiving this code to pass on to you.
E211CAB9
Thanks
The previous code is for the entire Homey, I think. This code is only for the Homey Fusion app.
24dae1d9-4a26-4b8a-bc73-823d1f370b00
thanks
To give an example, the battery has been at 97% all evening (a few hours).
Thanks
Thanks for the log. The app itself starts without errors, and all 4 devices initialise correctly.
The log shows no activity from the Modbus devices after startup, which usually means the connection to the SDongle/inverter is failing silently.
Can you reach the SDongle on the network? (check if the IP address in the device settings is still correct — routers sometimes reassign IPs after a reboot)
If the IP changed, go to the device settings in Homey and update the IP address. That’s the most common cause of this symptom.
Please update app to 1.1.47 - let it run for at least 15 minutes - send another Diagnostic Report
Although mine was already working fine I did install the test version 1.4.7. All ok still. Thanks
Good morning.
Here are the IP addresses of the devices. It is the same as with the dongle, for example; could there be something else causing this not to work?
(attachments)
Reboot the inverter / Dongle?
I will do this this evening. If I reboot the dongle, will the battery and inverter in Homey be fixed as well?
What is the best way to restart it?
I deleted the app and reinstalled everything, and it is working so far. The IP address was not the problem. Does this tell you more about the possible problem?
If I can help you with anything, just let me know.
Thank you in advance for the quick and pleasant responses.
Peter
Has anyone else run into this problem as well?
Nope, none of that - all is working just fine here!
A little feedback after testing the new battery storage work mode trigger I can conclude that it works as anticipated, perhaps with a bit of lag at times when changing modes and the event triggering - but nothing conclusive, tried changing modes via FusionSolar cloud as well as mobile app - and it might just be lag in the SDongle.. So a great addition to an already awesome app @Andi!
Good afternoon,
My Huawei battery has been stuck at 7W all day. The Huawei inverter is set to 0. Sometimes the setting automatically switches to Fixed charging/discharging. The settings are correct now, but the inverter isn’t generating any power and the battery isn’t charging. You will see that the SMA inverter is actually generating power. I have already restarted the app, but it remains the same. Could you take a look at what the solution for this is?
If you need an error code, how can I fix it?
Thank you in advance.
83945aa3-7259-4622-905e-6f8c07ec0542
Here is the error message code
I have called Huawei and they say the battery is calibrating. So, there is no problem.
Thanks
Peter
I have had the same problem. No updates in the Homey app.
I logged on to the Huawei inverter and updated it. (Scan the qr on the inverter to log on. You will need the password. My inverter, installed by Sveasolar in Spain, has the password svea1234)
Contact your installer to get your password if you don’t have it.
After the update finished (1-2 hours) the battery started to calibrate. It took 3 days then everything was back to normal.
My dongle has been failing for 2 weeks, what’s going on?
Just found your app, and finally my Homey Energy is working! HOLY MOLY you made my day!
Looks like an issue with your plant - what have you tried already? Restart inverter? Restart Dongle? Check IP address? Etc.
