[App][Pro] Homey Easy Logger
It’s google or you dns
2024-02-09T22:16:24.650Z [err] [EasyLoggerApp] Error: This did not go well, FetchError: request to https://www.googleapis.com/oauth2/v4/token failed, reason: getaddrinfo EAI_AGAIN www.googleapis.com
I will keep an eye on this, thank you very much :slight_smile:
I was trying to save an advanced flow and got this network error again.
What can I do to improve my network, any ideas?
send another diag, I can see if it’s same error
Got the the diag. Shows no error, so the problem must be local at your homey
I will try to contact Athom and see what they say. Could be something wrong with my Wifi.
@bwa When I configure a non existing sheet, and send a message, there is an error written to the timeline:
Uuups, statuscode 400 occured: Error: Unable to parse range: non_existing_sheet doAppendMultiCelldelimitedValue with {“spreadsheet-id”:"1cWe…
but the error output of the card is not activated:
can this be fixed please?
This morning I found this error:
This did not go well, FetchError: request to https://www.googleapis.com/oauth2/v4/token failed, reason: undefined
apr. 15 2024 08:40:56
not sure if this would activate the error-output of the card, had no flow for that yet.
As I recall setting fire and forget to true or false, will determine the behavior of this.
https://wiki.bwa.no/display/HEL/11.+Fire+and+forget
Fire and forget is set to ‘true’.
Does this mean I have to set it to ‘false’ to get the error out of the error-output?
Yes, and be aware that the rate limiting may occur if you log too much
I’m in the process of testing this app and once I managed to set it up, thanks to the extensive documentation, it works great!
Is it possible to set a row/column/cell with character color or background color from the following card and how do I do it if so?
Thnx!
Not possible, but I may fix this in future.
I added this app, created the api key and started to create a flow to store data into a spreadsheet. I get this error:
“Flow Card not registered (type: action, id: append-multicell-delimited-value)”
Any idea?
Wich version ? And where is this error message showing up ?
Its the latest version (v1.9.6), i already installed it.
Im trying to create a flow and the error apperars while testing the corresponding part of my flow:
The spreadsheet value does not seem correct
This is how I use it
and setting the id in app config
note: you ispreadsheet d is not same as mine
i have no clue, where this random sting comes from, so i used a name.
Documentation does not tell, what “Default spreadsheet-id” means:
it’s explained here
the id is from your url
Thank you! Now ist running… i also missed to restart the app after changing the properties :wink:
works great now! Exactly what i was searching for :slight_smile:
