[APP][Pro] HomeDeck – your whole home on one screen, in 3D and as a live floor plan
Thank you for the detailed feedback, R3M0N, and welcome. Version 0.2.10 is on the test channel now, with most of what you asked for.
The dormer can go on the front or the back of the roof, and be normal, wide, or as wide as the roof, which is the ridge raise. The chimney can be switched off. The dormer, the chimney and the neighbours are under House, and the neighbours can get their own roof, width, depth and position. The grid connection with its meter cupboard can be put on the left or right of the front, so it no longer has to come in at your neighbours. The outdoor unit of the air conditioner can go on the front, left or right, or on a side wall. Both are under On and around the house.
A plug that measures energy, such as the HomeWizard Energy Socket, is no longer taken for a lamp just because it has a dim value, and the same goes for an air conditioner with a target temperature. So the Energy Socket should now show as a socket and the Toshiba as a climate device. I could only try this with made-up devices, so please check them on yours. If one still shows as a lamp, send a diagnosis so I can see what it reports.
Not done yet: a sloped roof on an extension, the drawn garden in 3D, a mirror button for the neighbours, and the Hue Dial Switch as one device with its four buttons. I have noted them and will say here when they are in. Thank you for the ideas.
Thanks for 0.2.10! Tested on my house:
Works: dormer front/back + 3 sizes, chimney off, AC shows as climate device.
Socket still shows as lamp (diagnostic ce100398-ac26-4802-b633-258cb624f94f): deviceKind needs cls === 'socket' and meter_power, but the dashboard’s device list only has onoff, dim, locked, measure_power, so it never matches. Maybe check measure_power, or add a per-device “show as socket”.
Follow-ups:
  1. Grid connection: it always goes on a front wall. Mine enters through a side wall. Could it follow the “Meterkast” room, or allow a side wall?
  2. AC unit on a side wall: it picks the outermost ground-floor wall (my shed), at first-floor height. Could it use the wall of the floor it hangs on, or follow the AC’s position in the plan? Or, could we be enabled to manually place it, like the lamps, AC, etc?
  3. Dormer: “normal”/”wide” sit fixed at the left quarter. Manual position and size would be great. Also, and option for raised ridge dormer (nokverhoging) would be great - now it shows only as a dormer (flat roofing). It would be awesome if you could manually select the measurements of the roof and then also manually the raised ridge dormer/dormer, to be able to get the view as close to the actuals as possible.
  4. Front door in a side wall (my point 6) still needs the doorAt workaround. If have 3 doors in the front, two of them on the side of the L-shape and one in the attached storage room. It now takes the door in the Storage room as the main one and adds the light there. Could the lighting also be uncoupled from this door and placed manually?
  5. Temperature step is fixed at 0.5°. My Toshiba AC only takes whole degrees. Could it use the capability’s step, or a per-device setting?
  6. Outdoor lamps in 3D: drawn at 4 fixed spots by name, not where they are in the plan (my strip “…Garage” disappears without a carport). Would be great to be able to place these on the outside of the house manually, same as lamps inside.
Additionally, I know also added the iCal calendar. It syncs great, but it shows the agendapoints an hour late.
Also, an idea (I don’t know if this is possible) is to add more tabs where different Dashboards could be shown, such as widgets provided by the applications which are available in the owners Homey, Flows etc and then make what is shown on the ‘Main Menu’ (with the House) selectable. Now, a lot is shown in the main menu and there is a need to scroll
Again, just positive feedback, I’m very enthusiastic about the app!
Thanks for testing so thoroughly, and for the diagnosis. Version 0.2.12 is on the test channel now, and 0.2.11 is part of it. First what 0.2.11 brought from your earlier list:
Sloped roof on an extension: under House, set Roof of lower parts to Sloping. The roof of a lower part falls away from the building it leans against, with the pitch you give and an optional flat strip at the low end, like your former garage.
Mirrored neighbours: tick Neighbours look like the house, mirrored. They get the front door, windows, chimney and dormer of your house.
Your drawn garden: the rooms, plants, things and walls of the garden level now appear in the 3D house (lawn, pond, border, gravel and paving by name). It works with Shape of the house set to Follows the floor plan.
Then your new points, all in 0.2.12:
Socket as lamp: you were right. HomeDeck does not watch meter_power, so the check never matched. The app now remembers that a device meters its energy, so your Energy Socket shows as a socket. It also has a child lock (locked), which would have made it look like a door lock; a switched device with a lock now stays a plug.
Grid connection: Grid connection now also has the left and right side wall, and By the room called Meter cupboard: the meter cupboard then sits on the outer wall nearest to your room named Meterkast, with the grid cabinet a few metres out.
AC unit: on a side wall it now uses the walls of the upper storey, not the outermost ground floor wall. And when you place the air conditioner in the plan, the outdoor unit hangs on the outer wall nearest to it, on that storey (the first choice, Where it is in the plan, else on the front).
Dormer: a normal or wide dormer has a width and a place from the middle in metres. There is also Ridge raise (higher ridge) as a size: that roof slope goes up from the eaves to a ridge higher than the old one, with an upright wall above the old ridge, closed cheeks and roof windows. You set how much higher. A fully free roof size is not there yet.
Front door: with more doors drawn in the outer walls of the ground floor, you choose at Front door which one it is, also one in a side wall. The lamp above the front door goes with it, and the path runs along that side.
Temperature step: it now uses the step of the capability, and a whole degree when the device has no decimals. If your Toshiba still steps by 0.5, send a diagnosis and I will look at what it reports.
Outdoor lamps: with Follows the floor plan, an outdoor lamp you place on the garden level stands at that spot as a garden light, and one on the ground floor by an outer wall hangs on that wall. Each switches on its own. Your Garage strip no longer disappears without a carport: driveway lamps then stand along the free side of the house.
Calendar an hour late: I think your calendar uses a Windows time zone name, such as W. Europe Standard Time from Outlook. Those were read as UTC, which is exactly an hour late in winter. They are now translated, and an unknown zone falls back to the zone of your Homey. If it is still off, tell me which calendar app the link comes from.
More tabs and choosing what the main screen shows: a good idea, I have noted it. It is a bigger change, so not in this version.
One question about the Hue Dial Switch: what should its four buttons do on the dashboard? Show which button was pressed last, or switch something per button?
A question for everyone using HomeDeck: would you like to show your dashboard?
I am curious what you have built with it so far. A screenshot of your 3D house, your floor plan or the widget is enough, or how it hangs on a tablet on the wall. Feel free to post it here in the topic. Do remove names or anything else you would rather not share first.
It helps me too: I see what real houses look like and where the editor still falls short.
By the way, version 0.2.13 is on the test channel: on a garden level the ground floor shows dashed so you can draw the garden around the house, a room called Shed on the garden level becomes a small building with walls and a flat roof, a garage or shed level can have a gable or flat roof, doors and windows that no longer stand in a wall go onto the nearest wall, and an air conditioner whose app only has capability variants (such as Daikin) works as a thermostat.
Thanks for 0.2.12! Tested on my house:
Works
  • Socket: shows as a socket now. One catch: one socket had TV as its connected-device class in Homey, and it only worked after I changed that to Other. Might be worth handling sockets with another class too.
  • “I’m leaving”: sockets no longer count as lamps.
  • Front door in the side wall, and the calendar time is correct now.
  • AC unit hangs on the right wall with Where it is in the plan.
  • Drawn garden in 3D works great!
Some further ideas/points/feedback
  1. Flow buttons don’t work: every Flow button (standard and advanced) only gives a red flash, while the same Flows run fine with Start in Homey. The diagnosis shows /api/actions/run: Missing Scopes (10×). Idea: a HomeDeck trigger card “Button pressed” (argument: button name), so users build “When HomeDeck button X → …” themselves. That runs locally without extra scopes. A clear error message instead of the short red flash would also help. Or, maybe easier, make sure the selection of the Flow in Homedeck enables the ‘Start’-argument in the Homey Flow.
  2. Deleted Flows stay on the dashboard after I delete them in Homey.
  3. Temperature step: my Toshiba still steps by 0.5°.
  4. Sloped roof of lower parts: it applies to all lower parts, so my flat-roofed shed slopes too. Suggestion: a roof setting per lower part (Auto / Flat / Sloping, plus pitch and flat strip). Auto could slope away from the wall a part shares with a higher storey, but a per-part override is still needed, because my shed shares a wall too and is flat.
  5. Ridge raise: it doesn’t match my house yet. I’ve sent a photo and a screenshot by PM, which is easier than describing it.
  6. Mirrored neighbours: a lot better! The sizes don’t match ours yet (one neighbour narrow and deep, the other wide, heights don’t match)
  7. Doors of the shed are no longer visible since the front-door change.
  8. Outdoor lamps: placing them on the ground floor by an outer wall works. A few wishes:
    • Garden level by a wall: I’d rather keep them in my Front Garden area. A lamp on the garden level that stands against an outer wall could hang on that wall, or a per-lamp mount option Wall / Standing.
    • Lamp kind Strip: my Hue lightstrip shows as a wall lamp. A Strip kind that runs along a wall or the edge of a roof, with a length, would match it.
    • Light direction: the light now spreads round and outwards. My strip faces down, so its light should only go down. My Hue Resonate shines up and down, not to the sides. Maybe a per-lamp setting Light direction: all / down / up / up & down?
  9. Grid connection and AC cables: By the room called Meter cupboard works, but the grid cabinet ends up in the front garden, and the cables to it and to the AC unit run criss-cross through the garden and the house.
  10. Old automatic garden: with the drawn garden, the automatic hedges at the sides still show. When a Garden level exists, maybe switch the automatic garden off.
Ideas
  • Drag parts like furniture: grid connection, gas connection, AC outdoor unit and so on. That could fix the “almost in the right spot” cases.
  • Cables on/off: a setting to hide the cable lines.
  • Choose which apps and devices show: I linked PlayStation/PSN to Homey but don’t need them in HomeDeck.
  • Tabs: +1, for example a tab with Moods for the lights, with the house as the main screen. Would be nice to manually create extra tabs to add widgets etc (now a little too much is shown in the main tab)
Hue Dial Switch: show which button was pressed last, and let me give each button a label (for example “Scene: evening”). Homey doesn’t know what the buttons do in the Hue app, so a label is the next best thing.
Again, great progress in such a short time. I’m really enjoying it!
Thanks again for such a thorough test, and good to hear the socket, side front door, calendar, AC unit and drawn garden work. Version 0.2.15 is on the test channel now; 0.2.13 and 0.2.14 came in between (see my post above about 0.2.13).
Flow buttons: your diagnosis found the cause. Homey does not let an app start a Flow (“Missing Scopes”), so these buttons could not work this way. Your idea is now in: there is a trigger card “A HomeDeck button is pressed” (under HomeDeck), where you pick one of your buttons. Start the Flow with that card (an advanced Flow can simply get it as an extra start card) and the button runs it, locally. When HomeDeck cannot start a Flow, the dashboard now shows a message that says what to do, instead of the short red flash.
Deleted Flows: buttons whose Flow or mood no longer exists in Homey are removed from the plan, at start and every ten minutes.
Socket with class TV: a plug whose connected device is set to TV or another class now stays a plug. Only Light makes it a lamp.
Sloped roof per part: each room now has “Roof over this room in the 3D house”: Like Roof of lower parts, Flat or Sloping (in the room panel, with Shape of the house following the floor plan). So your shed can stay flat while the rest slopes. I left out an automatic choice by shared wall, because your own shed shows it would guess wrong.
Outdoor lamps: a lamp on the garden level within half a metre of an outer wall now hangs on that wall; further out it stands as a garden light. A Strip kind and a light direction per lamp are good ideas, but not built yet.
Cables: under House you can now switch off “Cables between the parts”. The place of the grid cabinet and the routes of the cables are not fixed yet. Dragging parts like furniture would solve the “almost right” cases best, so that is on the list.
Old automatic garden: since 0.2.13 the hedges go round the drawn garden instead of through it. In 0.2.15, when you draw fences or walls of your own on the garden level, the made-up hedges, trees and shrubs go entirely.
Not solved yet:
  • Temperature step: could you send a diagnosis (Report a problem) and say so here? Then I can see which step your Toshiba reports.
  • Shed doors: I have not found the cause yet. Is your shed part of the ground floor or a level of its own, and are its doors in the same wall as the front door?
  • Ridge raise: thanks for the photo and screenshot by PM, I will look at them for the next version.
  • Neighbours: one size for both neighbours for now; a size per neighbour is on the list.
  • Choosing which apps and devices show, extra tabs of your own, and labels plus the last pressed button for the Hue Dial: all on the list.
Thanks for 0.2.15! I tested it on my house (the app shows 0.2.17 by now). Here are the results, point by point.
Works:
  1. Flow buttons: the trigger card A HomeDeck button is pressed is there, and a test Flow with it runs from the dashboard. A button without the card now shows a clear message instead of the red flash.
  2. Deleted Flows disappear from the dashboard.
  3. Socket with class TV stays a plug.
  4. Roof per room: works!
  5. Cables can be switched off.
  6. Drawn garden: with my own fences, the made-up hedges are gone.
  7. Outdoor lamps on the garden level now hang on the wall.
Some feedback
  1. Temperature step: still 0.5° for my Toshiba (whole degrees only) and also for my Tado X (Tado itself can do 0.1°). In /api/plan both report target_temperature with decimals: 1, so I guess HomeDeck can’t tell them apart. Maybe use the capability’s step option when a device has one, or a step setting per device? I’ve sent a diagnosis via pm.
  2. Shed doors: my shed is a room on the ground floor, not a level of its own. Its doors are in its front and back wall, not in the wall of the front door (that one is in the side wall of the hall). The doors show on the Ground floor tab, but not in the House view. In front of and behind the shed I drew two canopies as rooms without walls (Overkapping voor and Overkapping achter). Possinly that’s the cause?
  3. Garden lamp height: the lamps hang on the wall now, but not at the height I set in the plan (strip at 2.55 m, wall lamp at 1.70 m). Also, strip does not show as a strip.
  4. Grid connection: with On the front wall the grid cabinet ends up at my neighbours’ house.
  5. Car: in the House view my car is a red block; in the Garden view it looks fine. I do not use a carport - could that be the cause?
Thanks again!
@R3M0N Thank you for testing so carefully, and for the clear points. Version 0.2.19 is on the test channel now.
Temperature step: each room now has Step of the target temperature (0.1°, 0.5° or 1°), under the climate device. HomeDeck cannot tell your Toshiba and your Tado apart, so you choose it per room.
Shed doors: I think your two canopies are the cause. A room without walls counted as part of the block of the house, so the front and back wall of the shed were no outer walls and its doors had no wall to stand in. Now a room with Walls around this room off and a side that nothing stands against is outside the block, so the doors of the shed should show in the House view. I could only try this with made-up plans, so please tell me if they are still missing.
Garden lamp height: a lamp on the wall now hangs at the height you gave it in the plan, and the LED strip is drawn as a strip, as long as you drew it.
Grid connection: beside a neighbour (semi-detached, terraced or corner house) the grid cabinet now stands in front of the meter cupboard instead of beside the house, so it no longer lands at your neighbours.
Car: you were right that it is not the carport. The car you placed on the garden level was drawn as a plain block in the House view. It is now drawn as a real car, in the colours you chose.
Hi @WNijhof ,
Temperature step per room works.
The doors in the shed are available
The height of the led-strip is adjustable now, great! It only does not show a strip yet.
The Grid Connection now shows nicely in front of the house, when besides a neighbour.
The car shows as well.
Thank you again!
@R3M0N Thanks for testing again, and good to hear the shed doors, the grid connection, the car and the temperature step work.
LED strip: I found the cause. HomeDeck did not recognise your strip model (it looked for the wrong name), so it only used the height and drew an ordinary wall lamp. In 0.2.23 it is drawn as a strip, as long as you drew it. Version 0.2.23 is coming to the test channel.
@R3M0N Version 0.2.23 is on the test channel now. Let me know if the LED strip shows as a strip for you.
Hoi,
Ik heb nog een vraag over de muurhoogte in HomeDeck.
Ik heb mijn woning en tuinhuis samen op de verdieping ‘Woonkamer’ getekend. De muurhoogte staat daar op 260 cm, wat voor mijn woning correct is.
Het tuinhuis heeft echter lagere muren, ongeveer 220 cm, met een schuin dak.
Ik heb geprobeerd het tuinhuis op een aparte verdieping als ‘Een losse schuur’ te plaatsen. Maar HomeDeck zet die schuur dan automatisch ergens naast of achter mijn woning, terwijl mijn oorspronkelijke tuinhuis al precies op de juiste plek staat.
Zou het mogelijk zijn om de muurhoogte per kamer afzonderlijk in te stellen?
Dan kan ik alleen de muren van het tuinhuis verlagen van 260 naar 220 cm, zonder dat de muren van mijn woning veranderen.
Alvast bedankt voor het meedenken en de eerdere aanpassingen!
Version 0.2.24 is on the test channel.
@Twan_van_Appeven Wall height per room: you can now set it. Select the garden house room and fill in Wall height of this room (for example 220). Only the walls of that room get lower; a wall between two rooms is as high as the higher one, so the walls of your home stay at 260. A room with a gable roof of its own also has Slope of this roof now. One limit: in the 3D house view the walls of a whole storey still have the height of the level, so a lower room shows its lower walls in the room views (2D, 2.5D and the 3D room) but not yet as a lower block next to the house in the house view. What does work in the house view: a room called Shed, Garden house or Garage on a garden level is a small building that stands exactly where you drew it, and it now takes the wall height of that room. So put the garden house room on your garden level (draw it in the same place as the dashed ground floor), name it Garden house, and set 220 there. Not a separate level of its own: the room on the garden level stays where you drew it.
Hoi,
Het tuinhuis staat inmiddels op mijn tuinverdieping, op de juiste plaats en met de juiste muurhoogte van 220 cm. Dat werkt prima!
Alleen het dak blijft in de complete 3D-huisweergave plat, terwijl ik bij de kamer ‘Schuin’ heb ingesteld.
Ik lees bij ‘Garage en schuur’ dat een gebouwtje op de tuinverdieping standaard een plat dak krijgt.
Zou het mogelijk zijn om ook bij een tuinhuis op de tuinverdieping een schuin dak te tonen, met de ingestelde dakrichting?
Dan is mijn tuinhuis helemaal zoals in werkelijkheid. Bedankt weer!
Version 0.2.25 is on the test channel. A garden house or shed on a garden level now gets the roof you chose for its room: Roof over this room set to Sloping gives a lean-to roof that falls the way you chose under The roof falls towards, and a gable roof gets its ridge along the long side of the room (with Roof pitch if you set one). Without a choice it stays flat, as before. Let me know if your garden house looks right now.
Also in 0.2.25: with Panels per row set, a row on a flat roof may now run to 0.2 m from the edge, so 3 landscape panels fit next to each other on a roof of 5.8 m (you asked for that in the Dutch topic), and the railing round a roof terrace is an open railing (posts and rails) instead of a solid slab.
