Hi!
I have been using the new setting for a few days now and noticed a big difference.
Since the setting for Authentication is now ‘off’ the moment I plug the car in, the loading starts. This sometimes fails, due to the car not being ready, but it is tried nonetheless. This never happened before.
Last year, I think I had the authentication setting also to ‘is required’ but I could control it via the ‘Set allow charging’ card to ‘Yes’, but this no longer worked this year.
So I get that this setting changes that, but not in the way I intended it, it should not auto-start on connecting the car.
I checked if I had any enabled flow which works on connecting the car, but that was not the case.
Hope you can shed more light on this.
Thanks again for all the work you are doing.
Let me know if there is any more testing I can do to help find the issue. I am a web developer myself so if you want me to use tools on this, let me know how and I can probably do that too.
Best,
Ruud
