Hi all, I’ve submitted an app for GlueLock. Feedback can be provided here.
Looking forward to constructive feedback. A new version with links are in app-submisson.
Good day.
Good day.
Hi, Iam probably doing something wrong, but iam struggling to get my Auth key. Can you explain the steps i need to do, to require the key?
Hi @SBLL are you by chance familar with Curl / Postman?
Hi, Cant figure out how to get the API or Auth key, Br, Stefan
See PM.
And I have the same problem. I don’t not get the API or the key, also a little noob with curl/postman
Hi. I am also struggeling to understand how to get the auth key. Have no knowledge on Curl / Postman🙉. Any chance you could give a step by step procedure on how to obtain it?
Thanks
Hi, I will need your credentials for doing so. PM me and I will try and help yout.
Update: new maintainer + new version available for testing
Hi all,
Kim has handed the GlueLock app over to me (Johan), and I’d like to say a big thank you to Kim for building it and for passing it on so smoothly. Kim’s work is the foundation this app stands on, and he is still credited as a contributor in the app.
I’ve rewritten the app against Glue’s current API, mainly to fix the crashes that the earlier version had.
Version 1.1.2 is available in the Test channel.
What’s new**
Good to know
If you try it, please post here with your Homey model and what worked or didn’t.
Never post your API key.
Thanks!
