[APP][Pro] Glue Lock - Control your Glue smart locks from Homey
Hi all! I built a new Homey app for Glue smart locks and would like some testers before I submit it for certification.
What it does:
  • One Homey device per lock: lock/unlock, battery, last event and a live status line while a command is on its way
  • Log in with your Glue account directly in the app. The password is used once to create an API key and is never stored
  • Flow action “Lock all doors” with a verification step, and a trigger “A lock could not be locked” with the door name and reason as tags
Test link: Glue Lock | Homey
Source and issues: GitHub - Bendify/homey-glue-lock: Homey app for Glue smart locks · GitHub
I have tested it with four locks (GL04A and GL05A). What I especially want feedback on: the login step on other accounts, locks that show as offline or disconnected, and battery readings.
There is already a GlueLock app from 2023. This is a separate app built from scratch, with in-app login, a status line while commands run, and a ‘Lock all doors’ flow card with verification.
Svenska: Appen är byggd för Glue-lås och går att testa via länken ovan. Hör gärna av dig med erfarenheter eller buggar.
Update: Glue Lock 1.0.3 (test build)
A new test build is out. What’s new since the first release:
  • New app icon and app images
  • Automatic retries when Glue’s cloud returns a temporary server error (5xx)
  • Clearer messages when the Glue hub has lost its wifi, with a hint to restart the hub or use Bluetooth in the Glue app
  • New flow trigger “A lock lost its connection” (tokens: door, status). It fires after two minutes without a connection, so a short wifi blip won’t spam you
  • Locks are now only marked unavailable when Glue reports them as offline
Tested on GL04A and GL05A. I’d especially like feedback from owners of other Glue models.
Test version: Glue Lock | Homey
Thanks for testing!
