Could you restart the app and see if that solves the issues? I have filed a bug report, but restarting the app would solve the issue that the sensor ID is not set.
After restarting the app the sensor-id is read and updated fine for every plant.
So it’s working now with test-version 1.1.1.
I found another small bug: if I try to add a new device, but there is not new device registered at Fyta, it run into this failure:
I would expect to get a “no new devices” message.
Small Update:
I added a new Fyta sensor (gen 1) to the Fyta app and the same happen. It won’t find the new sensor. The new sensor can be found using the API.
And another hint: I added new plants without sensor to the Fyta app. This plants are listed too, but you get this:
"sensor": null,
"hub": null,
"sensors": [],
"isNoBeam": true
Maybe this helps.
Thanks! That certainly helps.
