[APP][Pro] Flow Checker
Hey @Adrian_Rockall ,
Thanks!
Yes sure! I’ll add that.
There is already a flow card to check it.
I let you know once I have a update :slight_smile:
New app update (test: 1.6.4.):
  • NEW: Add action flow card - Update flows and variables
  • NEW: Add action flow card - Set interval
  • ADD: interval checkbox (enable/disable) (@Adrian_Rockall)
Great idea @Adrian_Rockall !
And thanks again for the quick implementation, Martijn! Really nice feature.
A small thingy, when opening the config, the interval update fields are hidden.
Disabling and then enabling “Automatic Flows Check” makes them visible again :grin:
New app update (test: 1.6.5.):
  • FIX: hidden fields in settings page
Hidden fields are fixed indeed!
You’re just too quick. There’s more complaints about that :sweat_smile::grin:
I didn’t even have the time to zip from my coffee :laughing:
Two little suggestions regarding the “Clear all” and “Save” button.
At first I thought the first one clears all flows from the overviews somehow, but it disables all options.
Is it an idea to rename it to “Disable all”?
And while having quite a bunch of flows in my overview, those buttons are somewhat hidden, and hitting the “Save” button after changes, can be forgotten.
Is it possible to position the buttons right below the settings, above the totals overview?
Muchos gracias
Yes nice idea,
I’ll call the clear all → revert to default
Thanks. And yes, it reverts to default instead of clearing all boxes😁
New app update (test: 1.6.7.):
  • FIX: Move buttons in settings page
  • FIX: German language (thanks @DirkG)
  • FIX: layout settings page
:joy::joy::joy::+1::+1::+1::+1::+1:
I can now clearly see what is happening and when flows are turned off. Super beautiful. is it also possible to integrate Better logic variable ?
Hey @HuisCHovens
Thanks!
I’ll have a look at that.
Not using better logic my self so have to dive into it :slight_smile:
New app update (test: 1.7.0.):
  • NEW: add APP variables check
  • Improve logic handling
Different trigger cards are now included. (Date or App triggers).
Within this triggers the following broken variables can be found:
  • Logic variables
  • Device variables
  • App variables
For example:
New app update (test: 1.7.1.):
  • NEW: extend settings with variable breakdown
Added amount off different variables below the All Variables line
Thanks Martijn! :+1::beers:
New app update (test: 1.8.1.):
  • NEW: add Better Logic support - (variable and flowcards check)
When Better Logic is installed Flow Checker will search for the variables and include them in the checks. Also the Better Logic flowcards are included in this check.
CC: @Martijn_Hoogenbosch @HuisCHovens
Currently in test:
1.8.0.
  • CHANGE: readme
1.7.1.
1.7.0
:racing_car: @martijnpoppen, known as Max Verstappen :netherlands: of the developer, is on the track again :dash:
Very cool! it shows the vars in better logic! cool!
:joy::joy::+1::+1::+1::+1::+1::+1::+1::+1:
:+1::+1: thanks Martijn, another few broken flows and broken vars were found. And BL vars specified is :white_check_mark:.
This app is really a must-have for Homey flow & logics diagnostics.
And, it doesn’t crash with these kind of numbers :grin::innocent:
Yes! nice. I improved it so variables in flowcards of other apps are also found. Was quite a challenge :stuck_out_tongue:
