@Robert_Szilagyi see FAQ Q1 [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum
Yeah everything is on
@Robert_Szilagyi For motion and or person detection. Make sure to use the correct flow cards.
Next to that the Eufy app has settings for indoor cameras where you can set which notifications you want
Yeah its my settings, but still got this yellow circle with a ! In it and nothing happens
@Robert_Szilagyi what do you mean with “nothing happens” ?
Sorry, forgot to send the details. So when for example waving in front of the camera and get a notification from eufy i havent got notification from homey. Made a flow with motion event like when motion alert > turn on the lights.
And somehow i need to restart the app every time to get picture update for the devices.
@Robert_Szilagyi motion alert is not the same as person alert.
My guess is that you get person detections. you can see that on the timeline tab of your device:
For me it says motion detection when i restard and after person. Will see tomorrow. Thanks for the help anyway. Tomorrow i will look into it again
@Robert_Szilagyi keep in mind that restarting the app often will lock you out eventually
(Eufy rate limits their API)
Can’t connect or repair the S120.
Tried both 3.21.0 & 3.21.1 test versions.
Diagnostics: 960679d8-e3c8-4fd4-a433-5b5ffb3b798c
@molensky why repair? You can just install the new version right
@molensky Ah small error will fix ![]()
Did you already release the update? Do I have to update manually? In the version I have currently running on/off does not work…
Regards
Not yet. Will do when im home
Received the latest version 43 minutes ago. All nodes are dead. Tried to restart app, did not help.
Pls let me know if you want a report.
@Peter_Kalrsson See posts above yours
New app update (
TEST: 3.21.2):
Changelog:
NEW:
1: NEW: add MiniBase Chime (T8023)
2: NEW: Add Doorbell E340 (T8214)
3: NEW: Add preparation for Indoor Cam S350 (T8416) (hardware access required)
4: NEW: Add eufyCam E330 Professional (T8600)
5: NEW: Add eufyCam S340 Pan and Tilt (T8170)
6: NEW: Add support for device which can be stand-alone and connected to Homebases
7: NEW: Migrate app to HomeyCompose
8: NEW: add flowcards to new cameras
8: NEW: prepare for Homey CloudFIXES:
1: FIX: Repair not working for some devices
2: FIX: T81A0 - S120 (implement missing types)
3: FIX: Country code for EU
4: FIX: deprecate stream cards
5: FIX: remove persistent data in userdata
6: FIX: energy saving for battery devices
7: FIX: Security mode for Homebase
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
Tnx, camera is working again. Will recharge device and monitor power consumption.
@Jonas_Hartvig which app version? Did it work before? Are the Homebase push notifications enabled?
