Do you need me too? For me It is no problem if It is like this.
When I try to login I get “Network request failed”.
Live version works.
Yes for me as well
New app update (TEST: 3.18.13):
Changelog:
NEW:
1: noneFIXES:
1: FIX: enforce notifiactions for Homebase error
2: FIX: propertyName error for Wall Light Cam
3: FIX: homebase error
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
Fixed Thnx
Today something strange happen, Eufy switched to Away when my wife left and I was still at home.
I have buttons to change the modes, those didn’t work. Had to change in the Eufy app. When I left the mode didn’t change. I got home again and downloaded the test app. Now when I left home, the mode didn’t change.
@ExtraKim I don’t really get the issue. Not sure how you setup your flows
I use Smart Presence or a button to change modes in Eufy. None of them worked earlier today. I have noticed that it have changed now the my wife got home (I’m at work), so maybe it works again.
Let me know when it doesn’t ![]()
Won’t be home until late this evening.
I’m not sure that I should write this…
I or maybe my daughter, had turned off wifi on my phone. ![]()
Hello martjinpoppen,
at first, amazing work from you. Hands up ![]()
am a new Homey user and am currently trying to integrate my five 1080p/2K indoor cameras (HomeKit version) into Homey. Unfortunately, without success. Adding the application to Homey works. Signing in with the Eufy login details (shared account and also admin account) works flawlessly. I can add five cameras, but no image is visible. Do you have any idea what could be the cause?
Maybe that helps: a75bbdc3-0333-4fe4-a578-c0934363aaff
Thank you ![]()
@SMR what do you mean with no image? There’s no live view on Homey. Only when you had a event. see [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum Q1 and Q3
Hello there,
Im a bit off a nuub at dis type of thing bud i like playing with it. Can somebody help me please?
I have a Homey pro and a Eufy Home base 3 with two Eufy cam 3. I cant get a simple if cam detect something licht up led-ring. Bud there seems to be some sort off a connection. When i press licht on in homey the cam flash one time. I already login with an admin account in homey, scrolled for an hour i dint now it anymore.
I want to switch between home and away thro Homey.
Big thanx in advance
Hi
I dont see that in your report
Can you make sure to do the actions and send a new report that
@martijnpoppen later I will share again debug logs…while temp and battery works perfectly, also picture seems to be updated, seems it’s not the case for alerts (person/car etc.)
