Hey,
I send a report. 51ab28a5-c6a5-403e-ba1a-1212139b4baf
Thanks
Hey,
Thanks
@JWB got it.
Its a issue which i fixed in the test version already but thats not live yet.
Will push it immediately… hopefully it gets approved by Athom soon!
@martijnpoppen Thanks for the quick shift. Much appreciated.
Changelog:
NEW:
1: NEW: add alarm motion sensor text (generic motion alarm)FIXES:
1: FIX: S220 events
2: FIX: Camera alarm
3: FIX: security mode selected without interaction (was caused by a check in background)
4: FIX: Parameter parsing - Security mode issue
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Hi @martijnpoppen,
I noticed that since a few days the start trigger “when security mode changes” does not work anymore.
Weirdly enough it works when I manually change the security mode, but when the security mode is changed by another flow, the “when security mode changes” does not start.
Any ideas on how to fix this? I sent the diagnostic report ![]()
Hey @martijnpoppen
Unfortunately. The latest version doesn’t work. I uninstalled and reinstalled the entire app. I even created a separate account with Eufy.
When I change the status, I don’t see it reflected in the Eufy app.
In an earlier app, you could see the status change immediately.
I created a new report. Maybe it will help you way. Thanks for the effort.
Regards
2657081f-1318-44fc-a0bc-1719f975b2e5
@maxnuij please follow this ![]()
@maxnuij make sure your Homebase notifications are enabled in the Eufy app in your phone
@JWB logs look good.
Do you refresh the page when you check it in the Eufy app?
Hey @martijnpoppen ,
A refresh doesn’t matter.
I did a little research. It seems that from Homey the status is not updated, when I change it in Homey. When I change the status in the Eufy app, I see the status in Homey changing to the correct setting almost in real time. It looks like one-way traffic.
Could it be that your app is sending the wrong status code to Eufy. At least the status code received from Eufy works. Maybe there is a mismatch between the equations.
@JWB its definitely sending the correct data. I tested it. Are your Homey and Homebase in the same network?
If not that might be the issue.
@martijnpoppen Yes. Both Homey and eufy are in the same network.
@JWB can you restart the app and send a report after that?
@martijnpoppen done. 0041fcda-5845-4f16-b557-8ae2a98011ac
@JWB maybe not related. but can you disable Loitering detectection on your Dual doorbell?
Looks like it gives an error and my guess is that it breaks the Homebase.
Changelog:
NEW:
1: -FIXES:
1: FIX: non parsable param - Eufy cam dual
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
@JWB can you check the above release to the test channel?
Hi @martijnpoppen,
Yes all notifications are turned on. And it did work for the past few months. Weird thing is that when the security mode is changed by a person via the key pad or the app. The trigger does work. Only when the security mode is changed by a homey flow, the trigger doesn’t work.
I have the exact same problem:
ebe43cb8-ee64-4d56-9827-3c0a77c9ff97
Homey 2023 with Eufy v3.16.8, Homebase 2.
(I have migrated to HP2023 during the past weeks, so a bit unsure when this stopped working.)
