[APP][Pro] Eufy Security
@Peter_Kalrsson no didn’t have time yet. Have to charge my 2C first :wink:
OK :slight_smile: Thanks again!
I have now installed a brand new HP23 and the only app installed is Eufy
I have shared all devices (3 cam) one by one in eufy app to e-mail that is not a member to my home in eufy app with admin rights
Then I add the devices in home (first hombase 2 with the credentials above, then the 3 cam)
It seems that the devices works BUT it does not update any values (since I add them 10 hours ago) and no temp, battery value
What can be my problem?
/Regards Per
Hey @Krosso for event values check [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum Q1
And for battery check Q5
It was pretty much the same like last time, notifications didnt come through and I could not change anything through the homey platform, turn it of/on etc…
Just wanted to inform you that I have sent it back, not only because I could not use it yet but mainly because I wasnt quite happy with the quality of the stream and also the battery was kind of acting up and drained way too fast… I am sure though its a capable camera and you will integrate it just fine soon.
Best regards and thanks again for the quick help!
@Philip_Gunkel Thanks for letting me know! :slight_smile:
New app update (LIVE: 3.16.1):
Changelog:
NEW:
1: NEW: ADD S220 Solocam
2: NEW: ADD wall light S100 & S120
3: NEW: Update library
FIXES:
1: FIX: Try to fetch battery on init
2: FIX: S220 events
3: FIX: Non-parsable parameter value received from eufy cloud
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Ok, it seems solved the problem :slight_smile:
What is “motion detected” ?
That value does not update…
Skickat från Outlook för iOS
@Krosso
Motion detected is motion only
Person detected is person only
Generic motion is any detection. (i still need to change the title :wink: )
Hello
It is the one in the yellow circle I wonder what it is. What is the difference between that and the value above (Rörelselarm)?
/Regards Per
@Krosso thats what i explained in my previous post…
Rörelselarm is the generic one.
Was just about to ask the status but added some seconds to read the change log - and there it was :smiley:
Now I just need to get the “person token” to work as intended… but I’ll post a question about that when I get to the end of the thread :wink:
New app update (TEST: 3.16.6):
Changelog:
NEW:
1: NEW: add alarm motion sensor text (generic motion alarm)
FIXES:
1: FIX: S220 events
2: FIX: Camera alarm
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
@Peter_Kalrsson Can you check the camera alarm in the test version? :smiley: :point_up:
@martijnpoppen
Thanks for remembering me!
Installed, but I get this weird error message:
forum
The time is defined for sure :slight_smile:
@Peter_Kalrsson oh interesting :stuck_out_tongue:
will check
@Peter_Kalrsson fixed in 3.16.6 :smiley:
@martijnpoppen - there we go! The camera alarm is now working again in v3.16.6.
You’re a true star - as always, thank you so much for all the effort you’re putting into this :star_struck:
Thanks! :smiley:
