Login keeps on turning
@Snellie1972 can you send a new report?
Hi
Here’s the code
3cb6401a-77ab-4273-acfa-7e2db0798ffb
@Snellie1972 according to the logs: Email address or password incorrect.
Ok i will check thanks
Strange I have copy paste the password and now it works !!!
Thank very much
@Snellie1972 Glad that it works! ![]()
If you have any questions let me know.
Also there’s a FAQ available here: [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum
Changelog:
NEW:
1: NEW: ADD S220 Solocam
2: NEW: ADD wall light S100 & S120
3: NEW: Update libraryFIXES:
1: FIX: Try to fetch battery on init
2: FIX: S220 events
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Security | Homey
@Philip_Gunkel can you check this release? ![]()
Thank you so much ![]()
Hi @martijnpoppen,
Great app, very good job!
Is it possible to start a recording from the Homey app and save it locally on the HomeBase 3 unit?
For example a flow like this:
Every 30 min
Start 30 second recording on Eufy Cam
Many thanks in advance!
Hey @Alexander_Redin
Thanks!
no unfortunately not possible. I have been trying that a couple of times but I can’t make that work ![]()
@martijnpoppen, got it. Thanks anyway and thanks for the swift reply! Have a great evening!
Good evening, I happened to note that the generic alarm card for my Eufy 2C Pro cameras have stopped working. I know for sure that this card has worked before. For example:
The Homebase alarm is triggered instead, not the camera alarm.
Can you pls have a look at this when you’ve time? Thanks so much!
Diag ID: 1e4ca62c-1a19-41f0-8f33-d8db351d864d
@Peter_Kalrsson sure will have a look. Homebase 2 or 3?
Thanks! Homebase 2.
Hey hey, unfortunately still behaves the same, also tried to delete it from both homey and the eufy app and then re-add it, with the same result. Here is the log from today: c33822db-7b01-491b-a069-28c2b2d0d135
@Philip_Gunkel what is missing at the moment? Just to see what works and what doesn’t ![]()
edit: see fix below
Changelog:
NEW:
2: FIX: S220 events
3: FIX: Non-parsable parameter value received from eufy cloud
Just curious @martijnpoppen - has the problem with the generic camera alarm been fixed in the new test version? ![]()
