Hi Martijn, I don’t even want anything from you, I wanted eufy to act. Maybe they can tell you how it can work or give you some hints. I am patient and wait till you can do something to make the situation better but I thought that eufy can do something for you so you can do it quicker.
@Rudiger this integration is not official. Therefore the current setup is reversed engineered. So Eufy should first come up with a API before they can help me out. So until then it is reverse engineering.
Also check the link i shared. I already have contacts at Eufy and Athom and were working together to find a solution for all eufy apps
Then, apparently, I was too hasty. I thought maybe it would help. I didn’t want to stand in anyone’s way, I just wanted to help.
Thanks for the clarification and sorry I did not read the earlier response. Then I hope it will work🙏🏻
New app update (
LIVE: 1.8.8):
Changelog:
FIXES
1. FIX: device settings caused network error
2. FIX: dont show unsupported devices during pairing
More - apps - Eufy Home - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
I have my robovac set up successfully but it doesn’t seem to expose to HomeKit. I have experiments on. Not sure what I’m doing wrong.
Any thoughts?
@Elliott_Woolf I don’t think Homey exposes Vacuums to Homekit. But better to ask this to Athom. I don’t control that
Is there anything I can to do help add the eufy s1 pro?
I’m an early backer and received mine 2 days ago.
Would be awesome to at least start and return it.
Would be more awesome if I can make it auto empty on command when no one is home. And turn off auto empty when someone ís home.
@Fabian_Annequin at this moment the S1 is not on the planning. First the app should be capable of supporting a lot of other devices. Eufy recently launched a lot of robovacs which are using a new protocol. Once those are added we can start looking at new devices. but only when it is officialy launched. i’m not supporting kickstarter devices. i rather support fully working devices
New app update (
TEST: 2.0.2):
Great news! All new devices have been added to the app (excluding the new kickstarter S1).
See supported device list: [APP][Pro] Eufy Home - #3 by martijnpoppen
When installing the new version when you already had a Robovac connected to Homey. You’ll be asked to repair your device. This is due to changes from the old API to the new one.
Please not that repairing and login take a long time due to all different API’s
Changelog:
NEW
1. NEW: Add all Eufy Clean devices (except S1)
2. NEW: Cloud connection to new devices
3. BREAK: App rewrite to support all 3 API Types.
@Fabian_Annequin I added support for the new devices, can I get access to your S1 to test it out ?
Hi Martijn,
thank alot for adding the new devices! I changed to the test-version 2.0 and tried to add my X10 pro omni. But I get the answer „No new devices found“.
I tried using the wrong password and within a second got the message ‘No new devices found’.
Did you use the correct username/password combination?
@Rudiger Please:
@Robin_van_Kekem let me know if everything works as expected
Here is the numer I got:
0375a865-2e89-482a-bfda-25d916d17bad
@Rudiger looks like a invalid login. There’s no proper error handling yet, working on that, but didn’t want to wait longer with this release
@Rudiger @Robin_van_Kekem Made a fix
I’m on a US account so already using the new API. Reverted it to old api.
you can test 2.0.2
Now I restarted the app and now it says „Searching for devices…
It runs for over 15 minutes.
How long should I wait?
Did you update to 2.0.2?
