Just dit;-)
@Patrick_Neeleman strange
Do you have any blockers in your network causing Tuya servers to fail?
Not that I know⌠how could I check that? I have a TP link Deco BE65
@Patrick_Neeleman you could try to reach http://iot.tuya.com/ and see if that opens
Hi, yes itâs opening but do i need to set up a account? Thanks
@Patrick_Neeleman no you donât have to, just to check if the domain was available.
Would you be able to share your robovac with me so i can check if i can get it to work in the API?
Yes domain was available. Do you send me a dm for your email?
@Patrick_Neeleman DM-ed you ![]()
hey Martijn, thx for your great work on this app! I, however, experience a few challenges: my vacuum (L35 hybrid) often is unavailable in Homey. Restarting the app solves the problem after a little while, but since Homey doesnât support flows to trigger restarting of apps, i am a bit baffled about a solution. Could you help?
Hi Martijn,
I have the same problem as @Nikito .
I have to restart the app 2 times last week because the robot vavuum was not availlable, after the restart it works for a few days.
This is the diagnostic report code:
823c744c-aff8-4138-9ce3-c1b708dfa816
Hope you can help.
@Nikito
Please send a report next time this happens. I canât help you with just a screenshot.
Also Homey does support flowcards to restart apps, make sure to enable power user ![]()
@Rembo038 will have a look!
New app update (
TEST: 2.3.5):
Changelog:
NEW
1. NoneFIXES
1. FIX: failing api call breaks app.See supported device list: [APP][Pro] Eufy Clean - #3 by martijnpoppen
More - apps - Eufy Clean - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Donât want to be part of this test version? Install the live version â Eufy Clean | Homey
done! will keep you posted! thanks for the quick reply/test
I installed the test version, thanks for the quick respons!
so far so good, no crashes/unavailable devices so far
@Rembo038 please send a report.
I restarted the app and the vacuum worked again.
This is the report code:
3be03189-d0a1-4361-bd83-6a8997af84b9
