[APP][Pro] Energy Dashboard – a live energy display for any screen in your home
Version 0.2.26 is on the test channel.
In the Circuits block, a P1 meter put in a group no longer counts as use of that group, because it measures the whole house, and the settings no longer offer it for groups. In the Battery use block, charging with no known source (sun or grid) now shows as its own grey part of the bars.
Version 0.2.28 is on the test channel. Devices with a use estimated by Homey, such as lights without a power meter of their own, count again in Devices now and Circuits. Devices now has a last grey line with what Home uses beyond all devices together: use nothing measures, or meters that did not update at the same moment. And with the app PV Forecast installed, and no Forecast.Solar set up in the settings, the dashboard shows its expected kWh for today and tomorrow. The power chart also leaves out P1 readings above what your connection can carry.
Version 0.2.33 is on the test channel. A lot was added since 0.2.29, thanks to rikadoo on Tweakers, whose own dashboard was the inspiration.
Two new blocks you switch on yourself with the pencil. Yearly bill shows whether you will pay extra or get money back against your advance payment, with a fitting advance payment and when your contract ends. Use per hour is a heat map of your use, solar or the grid over the last four weeks.
For the yearly bill, enter your advance payment and the start of your billing year in the settings. If the dashboard has not measured a year yet, also enter the use and the final readings on your last yearly bill, so the estimate is much closer.
There are also tags for Flows (surplus to the grid, solar surplus, home battery, off-peak rate now, costs today and tomorrow’s solar), Dutch public holidays count as off-peak, and a single-phase connection is recognised.
And from 0.2.29: solar yield from a counter that stays put for hours and then catches up in one step, such as the day counter of Zevercloud, counts in full.
Always happy to help as a inspiration​:wink:
Version 0.2.34 is on the test channel.
New is the Grid CO2 block. It shows how clean the electricity from the grid is right now, per quarter of an hour, with the forecast for the rest of the day, the cleanest 3 hours and how much CO2 your import caused today. The data comes from Energy-Charts (Fraunhofer ISE) and works at least for the Netherlands, Belgium, Germany, France, Denmark, Italy and Luxembourg. You add the block yourself with the pencil.
With a dynamic gas contract, today’s gas price now shows in the Electricity price block, with the price from 6:00.
There are two new tags for Flows: grid CO2 and gas price. You could for instance start the dishwasher when the grid is clean.
And in Circuits, the bars through the day are now light at a low load, and long circuit names no longer run over the bars.
Wauw, really nice work! Especially it is working after installing the app. Fine-turning with some energy contract data.
Nice that you can set it up for different devices.
The only thing I don’t understand yet, is the high amount “Einde salderen” after Jan 2027.
Thanks, glad it works for you.
Einde salderen is about the Netherlands: net metering ends on 1 January 2027. Until then every kWh you export is set off against a kWh you import, so you avoid the full price of that kWh, energy tax and VAT included. After that you pay that full price for everything you import, and for export you only get the export compensation of your contract.
The block takes last year (or this year so far) and multiplies the kWh that were netted by that difference. With 3000 kWh netted and a difference of 0.25 per kWh that is already 750 a year, so a high amount is not unusual with a lot of solar.
It depends on your contract in the settings. If the export compensation is low or zero, or your supplier charges feed-in costs, the amount goes up. The block also shows how much each kWh you use yourself instead of exporting saves.
If you are not in the Netherlands the block does not apply to you. You can remove it with the pencil (edit mode) on the dashboard.
Version 0.2.35 is on the test channel.
Use per hour now keeps yesterday, also when Homey Energy’s day report for that day does not add up. The day then comes from the meter readings, like today. For some of you a day disappeared after midnight.
Homey Energy can hold an inverter’s last value all night, so solar sometimes showed up at night. While the sun is down that now counts as 0. The days in Use per hour are read once more after the update.
The day bars in Circuits and the Hot water chart are now right on the day the clock changes; today they were an hour off.
The diagnosis (the exclamation mark button) now also shows which days in Use per hour are missing and why, and whether Homey keeps the power of the devices in your circuits.
And something nice: the app already has 400 active installs. Thanks to everyone using it and reporting what is not right, that makes it better with every version.
Many thanks as well to everyone who donated in the last few days. I really appreciate it!
I live in the Netherlands. How the savings per kWh (Besparing per kWh) calculated?
Eg. I pay the company 0,24per kWh. The savings is 0,37 per kWh which results in the high amount.
The saving per kWh is the price you avoid by using a kWh yourself, minus what that kWh would earn when you export it after 2027.
The price you avoid is the full import price, energy tax and VAT included. If the 0.24 is the supplier’s price without energy tax, the energy tax adds about 0.11 per kWh, so you get to about 0.35.
From 2027 export only earns the export compensation of your contract. Many suppliers charge a feed-in fee instead, which makes that compensation negative, and that adds to the saving. A fee of 0.02 per kWh turns 0.35 into 0.37.
If you entered 0.24 as the all-in price in the settings, the other 0.13 comes from the export side: check the export compensation and the feed-in fee of your electricity contract in the app settings.
In the next version the (i) of the block shows both parts with your own numbers, so you can see exactly where it comes from.
Version 0.2.36 is on the test channel.
Net metering in the Netherlands ends on 1 January 2027, and the app now takes that into account. In Yearly bill, the months from January are estimated without net metering, and export beyond your import no longer counts as netted. If your supplier gives you a welcome bonus, you can enter it in the settings; it is taken off the total.
End of net metering now shows what your electricity costs per month: now with net metering, from 2027, and from 2027 without your home battery if you have one. The (i) of the block shows how the saving per kWh is made up.
With a fixed contract with normal and off-peak rates, you choose in the settings how your supplier nets: against the normal rate first, or per counter.
The Home battery block now shows per hour how much was charged and discharged, and for today and yesterday the range of the charge level and the number of cycles.
These ideas came from rikadoo on Tweakers as well, thanks for that!
Thanks for making this clear. I was including tax in my tarif. Now I got good values.
Version 0.2.37 is on the test channel.
Do you have a three-way valve between your water heater and your gas boiler that a Flow switches? The Heating block can now show where your hot tap water comes from: straight from the water heater or through the gas boiler, with the last three switches and their time.
Turn it on in the app settings under Water heater, with the box Three-way valve between water heater and gas boiler. Then add the action Hot tap water comes from to your valve Flow, after the switch, and choose the source. The dashboard cannot see the valve itself, it shows what your Flow commanded.
It is off by default, so nothing changes if you have no valve. The idea and the first code came from a user on GitHub, thanks for that!
Version 0.2.38 is on the test channel.
Mail diagnosis opens your mail app again. On installed apps the mail address did not come through, so the button fell back to GitHub, which is not reachable at the moment.
Group day bars now also fill on Homeys that give no readings for today but do for the last 24 hours.
The settings now warn when the energy tax reduction looks like a monthly amount (it is a yearly amount) or when the export fee is close to your electricity price. One user’s yearly bill came out hundreds of euros off because of that.
Version 0.2.39 is on the test channel.
If you have Floor Plan Dashboard next to Energy Dashboard, the top of the dashboard now has a switch: :high_voltage: Energy | :house: Home. One tap on Home and you see your floor plan, on the same screen. Floor Plan Dashboard has the same switch back to Energy.
Handy for a wall tablet: one screen for both. If you do not have Floor Plan Dashboard, nothing changes.
Floor Plan Dashboard is my new app, still a test version. Your home as a live floor plan in 2D and 3D, with your lamps, temperatures and sensors where they really are. More in its own topic: [APP][Pro] Floor Plan Dashboard – your home as a live floor plan in 2D and 3D (test version)
Version 0.2.43 is on the test channel.
New is the block Replace appliance?. If your fridge or freezer is on a smart plug that measures kWh, the dashboard works out after 14 days what it uses per year. It puts that next to a new appliance of the same kind and size, with what replacing saves per year and after how many years a new one pays for itself.
It compares with real models. The app comes with a list of fridges, fridge-freezers and freezers on sale now, with the use on their EU energy label (from EPREL, the European energy label database) and an indicative price. The block picks the models that fit your appliance: same kind, freestanding or built-in, about the same size, and for built-in, fitting the niche. You see the most efficient model and the one that pays back first. Tap the name to open the official energy label.
The verdict is simple. If a new one pays back within 8 years, replacing is worth it. Up to 15 years: replace only when it breaks. Longer than that: keep it. If your appliance uses not much more than an efficient new one, it says Already efficient.
The label use is for a room of 24 degrees on average. If your freezer is in a cool garage, a new one would use less there too. So the block scales the new appliance to the temperature of the room, using the temperature sensor in the same room as the plug, or a sensor you choose.
You set it up in the app settings, under Replace appliance?. Choose the plug, the kind, freestanding or built-in, and enter the size or the height. For a fridge-freezer the size is the fridge and freezer together, as on the energy label. For built-in, enter the height of the niche. Then add the block with the pencil. If you already have a new appliance in mind, enter its price and label use yourself, and the block calculates with that one.
The list is updated with each new version; the app itself fetches nothing. It is not complete yet: there are no models yet for American fridges, table-top models and a few niche heights. Then the block uses usual values for a new appliance. If your kind of appliance is missing, let me know.
The settings are also clearer now. They are in cards, in four groups: Basics, Costs, Per block, and Data and help. Buttons at the top jump to a group, and Save stays in view at the bottom.
Also new since 0.2.39: the Heating block shows the temperature of the other rooms with a thermostat or radiator valve too. The app keeps its own history per hour, which you can export and restore as a backup. And if you have a water heater next to a gas boiler, the water heater settings under Extra functions can check whether the gas boiler fires for hot tap water.
Version 0.2.44 is on the test channel.
The Replace appliance? block now also shows what a new appliance is and what it costs. Below the name of each model you see the kind, freestanding or built-in, the size, the height and the energy label. Below that the price, the use per year and after how many years it pays for itself.
If no model from the list fits, the block uses usual values for an efficient new appliance. Then too you now see which kind that is and roughly what it costs.
If you have not entered a size or height in the settings yet, the block tells you to do so to see real models.
The prices of the models were checked again for this version.
