[APP][Pro] Elekeeper / SAJ eSolar Inverters
Almost everything is working fine, many thanks! The only issue remaining as I see it are the refresh issue, the app stops updating and you need to restart the app in order to see the correct figures again.
Hallo Steven, sinds vandaag beschik ik over de Elekeeper app, waarmee mijn SAJ / Bliq thuisbatterij is gekoppeld. Ik gebruik vooralsnog een aparte omvormer van een ander merk. Maar ik heb wel inzage in mijn batterij
Door de koppeling met de Elekeeper app zou er toch meer data beschikbaar moeten kunnen komen voor de Homey? Zelf zou ik heel graag de capaciteit van de accu op enig moment willen weten zodat ik actiec kan ondernemen als deze te vol loopt.
Heb jij zelf nog intenties om jouw app uit te breiden?
Vriendelijke groet, Henk Slootweg
I only use the inverter for my solar panels. For me, it is working quite well at the moment, though I do have to restart it every now and then. I will fix this in a future update.
Additions for batteries can always be made by others, preferably those who actually own a battery themselves. I do not have one, so I cannot test it.
The code is public and customizable. You can achieve a lot with AI, and it is relatively simple.
Modbus over IP only works for the battery I guess, not for the Solar inverter.
This app was created for the solar inverter.
As told before, feel free do edit/copy/clone the code: GitHub - telenut/be.telenut.elekeeper: Homey app for the SAJ inverters using elekeeper app (cloud) · GitHub
Please write in English here, don’t think you want me to write in Swedish​:wink:
I am glad that someone build an app for the SAJ inverters for Homey!
I have installed the and logd in to the app with my login. But I don’t get any data from the inverter and the dos not show any data.
Does anybody know what is wrong?
Greetings Michel
Feel free to run a diagonistic test… I can have look
How many inverters do you have?
Be sure, that in the advanched settings the inverter index for inverter number 1 is on 0 and for inverter nr 2 is on1.
Also check if the inverters can be reached by the homey.
Rgs Rob
Hoi Rob,
Ik heb in de advanced settings geen mogelijkheid om iets in te vullen. Onderstaande is het enige dat ik zie.
Welke heb je geïnstalleerd? Wellicht ligt het daaraan.
Ik had inderdaad een andere versie. Deze gedownload en nu werkt het. Bedankt!
New test version 1.3.6 is now available.
This update improves reliability of the connection with the SAJ eSolar cloud:
  • Added request timeouts, so a stalled SAJ API response can no longer block updates indefinitely.
  • Prevented overlapping polling cycles.
  • Improved automatic recovery when an SAJ session expires: the app now clears the invalid session, signs in again, and retries the update automatically.
Recent additions also include battery SoC and charge/discharge power support for installations where the API incorrectly reports no battery (such as some SAJ CH2 cabinets), plus per-string PV power and voltage where the inverter provides those values.
Please let me know how it behaves over the next few days—especially if values previously stopped updating after a longer period.
Many thanks for the update​:+1:. Will monitor and come back if any issues.
There stills seems to be an issue with the refresh. Had to restart the app today in order to get the correct SOC%.
Hi!
The app doesn’t work at all. It just displays a value and the battery percentage for a while, then it freezes. Right now, it’s completely useless.
Homey doesn’t recognize it as a battery either, so it doesn’t work under the energy tab.
The battery power value just disappeared during the night, any idea what’s going on? The app have been working very well (except for the freezes that happens now and then) so please have a look if possible.
Hej Per Rydell! Vad har du för batteri? Mitt SAJ HS3 visar bara SOC i % samt Battery Power. Den funkar inte i fliken Energy för där dyker den upp som “solceller” och inte som ett batteri. Så för min del och vad det verka många med mig så verkar inte appen funka så bra. Hur funkar den för dig och vad har du för batteri? Jag har lagt flera ärenden till SAJ och elekeeper att de ska göra en officiell app i stället så det bli en som funkar som den ska. Hoppas att du kan göra det samma.
Mvh
Fredrik
Hi! Did a Pull Request where I added a dedicated battery device and at the same time upgraded the API to V2. Tested with SAJ HS3 installation.
I created a first test version of Modbus app for SAJ HS3 if someone would like to write to their HS3 (maybe HS2 as well?).
Mine is HS3. I could see power, eg charging and discharging and SOC%. Suddenly just over one night did the power figure disappear. I will also try to push, I like this app, it’s a good start but need some improvements. I myself do no have the knowledge so I can only try to ask polite and gentle for some help.
