[APP][Pro] EasyLighting - Make smart home easy
Hi @Robin_Lunden @yuriestevan
Thank you for working with us on this.
We currently don’t have this specific device on hand to reproduce the issue on the Homey side. If possible, could you please try again to add the device into Homey, and after the attempt fails, generate a diagnostics report and send it to us. Here are the steps:
  1. Open the Homey mobile app or access Homey via web.
  2. Navigate to More → Apps → select the “EasyLighting App / driver” for your device.
  3. Tap the gear icon (Settings) next to the App.
  4. In the settings, select “Create Diagnostics Report”.
  5. The system will package the Homey logs + EasyLighting App logs into a report file. Please send that file or the report ID back to us.
For your reference, our current configuration is:
"zwave": {
  "security": ["none"],
  "manufacturerId": 816,
  "productTypeId": [ 512 ],
  "productId": [ 53250 ]
Additional configuration options you can also try:
If you’re comfortable with making adjustments, you could try the following two alternative configurations:
"zwave": {
  "manufacturerId": [ 816 ],
  "productId": [ 53250 ],
  "secure": [ "S0" ],
  "requireSecure": true
or
"zwave": {
  "secure": [ "S0" ],
  "requireSecure": false
These two options will attempt pairing in secure mode S0—one forcing secure, the other allowing non-secure as fallback.
Hope to hear from you @yuriestevan if you have any success?
I have the SR-ZV2833-PAC also.
Please indicate if there are plans to include this Zwave device
I understand that the SR-ZG2833PAC-DIM is a green power device which is not supported yet in Homey.
When needed I can support development of the Zwave device.
Hi @niracler and @Robin_Lunden ,
I got the following code when I generated the diagnostic report:
f62dc8de-d7dc-417e-bfdd-0cb6d1b26631
Hi @niracler
I’ve added it to homey, and your app recognised it as SR-ZG9030A-MW, light sensing and motion alert data comes like a charm. You can rename the supported device to MW/PIR
Dear @Easy_Home and @niracler
Could you please integrate SR-ZG2833PAC. There is no any other Zigbee based input modul on the market. It would be a game changer. Single, double and long press features all be needed for the community.
Thanks!
Hi @Fac3,
I’ve added support for both features you requested:
  1. ZG9030F-PS: Motion alarm timeout setting now available in device settings
  2. ZG9030A-PIR: Initial driver support added
A test version is available here: EasyLighting | Homey
For ZG9030A-PIR, I don’t have the actual device, so the Product ID might not be correct. If pairing fails, could you check the Product ID in: Settings → Device → Advanced Settings → Zigbee Device Information → Product ID
Let me know the value and I’ll update the driver.
Hi @niracler
Thanks for this update!!!
ZG9030A-PIR: I added it again, but it came up as -MW as just as before the update. Product ID is HK-DIM
ZG9030F-PS: Timeout setting appeared and works!
Hi @Easy_Home @niracler , I’ve made SR-ZG2833PAC listed in the local smart home distribution, first shipment will arrive in a few months. I hope till then you can integrate it into the EasyLighting app. As I wrote above, single, double and long press features all would be needed. I hope you can squeeze it into that time frame.
Hi @Fac3,
I’ve looked into the SR-ZG2833PAC and unfortunately it’s a Zigbee Green Power (ZGP) device. Green Power is a special subset of the Zigbee protocol
designed for ultra-low-power and energy-harvesting devices (like batteryless switches).
The issue is that Homey does not support the Green Power protocol at the platform level. I contacted Homey official support about this previously, and
they confirmed:
  1. Green Power is not currently supported
  2. There are no plans to add support in the future
I’ve addressed similar questions before:
For additional context, this has been a known platform limitation since 2019:
Zigbee Green Power (IEEE 802.15.4) support?
The issue is that both ZG9030A-PIR and ZG9030A-MW share the same Zigbee product ID (HK-DIM), so the PIR driver from v1.3.8 can’t actually match your device.
I’ve published a test version with the fix. Please try it:
https://homey.app/a/com.easyhome.easylighting/test/
After installing, re-add your device - it should pair as “ZG9030A Motion Sensor”. Let me know if it works!
Hi @niracler ,
Thanks for prompt response. Could you please check if SR-ZG9041P4 is a green power device or not? Seemengly it’s an input module too, but differs form the one we’ve dealt with.
Hi @Fac3,
We don’t have the SR-ZG9041P4 in our inventory yet. Could you share a photo of the device label? This will help us identify the exact variant and check if it’s a Green Power device.
I’ve got only a complete catalogue, at the Zigbee section I found this:
Seemingly it’s just a photoshopped image. Can you ask about it at Sunricher?
@Fac3 Yes, the SR-ZG9041P4 is a Green Power device. Feel free to share your email if you’d like us to follow up with more details.
@niracler Is there any zigbee based, non green power input module in the Sunricher offering?
Hi @Fac3,
Unfortunately, we don’t currently have a non-Green Power Zigbee input module in our product line. I’ll check with our team and let you know if there are any alternatives.
Hello. New to the Sunricher product line and purchased the SR-MT9042A module hoping it would work with Homey as it supports both Matter and Zigbee3. I tried to link it with your app using the SR-ZG version, but it doesn’t seem to work. Can you help?
Hi @Luc_Vander_Putten , SR-ZG9042A is supported (it appears as “ZG9040A-S/ZG9042A-D” due to its model ID), but we don’t have the Matter version SR-MT9042A on our side — could you confirm which one you have and share a screenshot of the pairing attempt?
Hi @niracler,
I just wanted to start by saying a huge thank you for your amazing help in post 177 and around! The On/Off controls for both channels are working absolutely flawlessly now, and I really appreciate the effort you put into making that work.
Whenever you have some time over, I noticed that the power metering seems to be stuck at a constant 5W regardless of the load. I suspect the Zigbee metering cluster might just need a little mapping adjustment for this specific profile.
There is absolutely no rush at all, but if you’d like to look into it whenever it suits you, here are the device details from my advanced settings:
  • Device Type: Socket
  • Manufacturer: Sunricher
  • Product ID: ON/OFF(2CH)
  • Device ID (IEEE): 94:de:b8:ff:fe:87:5e:ed
  • Firmware: 2.9.2_r3
  • App Version: v1.3.9 (Test)
Thank you so much once again for your kindness and for keeping this app so well-maintained for all of us!
Best regards,
Magnus
