[APP][Pro] Eastron - Advanced Energy Monitoring with DIN Rail Meters over Modbus TCP
I assume because the new version is available now: Eastron | Homey
With new Eastron devices and support for many languages :slight_smile:
Let me know if it works for you.
Hi, I have the latest version of the app 1.3.2, but as you can see, it doesn’t show L1-3 Volt. Could it be related to the fact that I have an IT network 230 V?
fre. 16. okt. 2026 kl. 15:11 skrev Rob Hagemann <notifications@athom.discoursemail.com>:
De app shows the values received over de Modbus interface, do you see the values on the meter?
Do you have Modbus register information for your device? It should be same as SDM630, but maybe there are some changes introduced
When I use PowerHud, 04-Rea input register 0-20
Yes, that’s caused by the IT network. Without a neutral the meter runs in 3-phase 3-wire mode and doesn’t measure phase-to-neutral voltage, so L1/L2/L3 show 0 V.
Your device looks like it was added with the “Eastron SDM630” driver. Please remove it and add it again with the “Eastron SDM630MCT-RC” driver: that one also shows the line-to-line voltages (L1-L2, L2-L3, L3-L1), which are the relevant voltages on an IT network. Per-phase power isn’t reliable in 3-wire mode either; total power, currents and energy are correct.
Hi.
Sorry that I entered the wrong meter; thanks for all the help.
