Not sure on what exact settings you need for the Eastrom SDM630, but the baud rate seems a bit high, I suggest starting with 9600 and see what happens.
Also, I see port 26 and 23 used, did you set those values? I would expect to see 502 there.
These are my settings for a similar waveshare device connected to a Growatt inverter:
(Suggestion: set the IP type to DHCP and add a reservation to your router if possible)
Thanks @DaneedeKruyff, not yet successful… changed baud rate, port (router is limited with these settings)also changed work mode:
Well, let’s take a closer look. What are the other options/combinations for Work mode?
Ok, TCP Server with Modbus TCP seems the right combintion to me, but what I only see just now in your screenshot, you’re using port 520 instead of 502.
Could you change that and try again?
good catch, but also not fixed it …Feel like a newbie here on this matter ![]()
Is there a way to see if the data is flowing, access in other mac tool or so?
Hi! Are there any ambitions to support Eastron SDM630 Modbus TCP?
From my understanding there is no need for a TCP gateway for this as it is already directly connected to the local network. I am still a novice in this area so I am eager to hear from you.
BR
Mathias
Hi Mathias, Yes, the “SDM630 Modbus TCP” should be able to connect directly with Homey using the Eastron App, I haven’t been able to test or check registers. I you have one test or sent the register list.
Type: Ethernet
Protocol: Modbus-TCP
Modbus address range: 1-247
IP: 192.168.1.200 (default)
Port: 502
Hi Wout, this is what I found, hope it helps.
- Hardware Connection
Eastron SDM (RS485): Connect the A/T+ and B/T- terminals of the meter to the corresponding RS485 terminals on the converter.
Grounding: While RS485 can work without ground, it is recommended to connect the GND terminal of the meter to the converter for stability.
Ethernet: Connect the Converter to your network switch or router using a standard RJ45 cable.
Power: Power the converter (usually 6–36V) and ensure the Eastron meter is powered by the mains.
2. Converter Configuration (Web Interface)
Connect the converter to your network, find its IP address (default is often 192.168.11.121 or similar), and enter it into a web browser.
Work Mode: TCP Server.
Protocol: Modbus TCP to RTU (if available) or Transparent Transmission.
Baud Rate: 9600 bps (default for most Eastron meters).
Data Bits: 8.
Parity: None (or Even, depending on your meter’s setting).
Stop Bits: 1.
Local Port: 502 (standard for Modbus) or 8888.
3. Eastron Meter Setup
Ensure the meter’s internal settings match the converter’s serial parameters (Baud rate, parity).
- Modbus Address (Unit ID): Ensure each meter has a unique address if multiple are on the same bus (default is usually 1).
4. Troubleshooting
No Data: Check if A and B wires are swapped.
Parity Mismatch: Verify if your meter is set to “None” or “Even” parity.
Address Conflict: If you have multiple meters, ensure they have unique addresses (e.g., 1, 2, 3).
Connection Timeout: Set the converter mode to
TCP Serverand ensure your firewall allows port 502
Thanks All, not yet successful, a bit further… Found my eastron settings and applied them…
Set Baud 19.2
Set PArl NONE
Set StoP 2
SET rLY
SET rATE dFT
SET PULS 100
SET dlt 60
SET LP 60
SYS 3P4
SET Addr 005
Continue tonight…
Great!
I have ordered but not yet received them.
Will try during April.
Br
Mathias
Thanks!
I have two of those. My issue is that only one of them work at a time. Is this a known issue?
Br
Mathias
Hi Mathias,
To support you, I need to understand your setup.
Are the meters on the same modbus?
Do they have different modbus ID’s?
What TCP gateway are you using?
What type of meters do you have?
What Eastron device do you have and what modbus gateway is used?
Do you see the Voltage on your Eastron device?
ons. 14. okt. 2026, 20:16 skrev Rob Hagemann <notifications@athom.discoursemail.com>:
Someone replied to your post.
| Rob_Hagemann
October 14 |
SDM630NCT-RC
L 1-2= 245
L 2-3=0
L 3-1=245
I have made an update with new devices support, please check:
Verify the CT connections / configuration, data in your meter should flow into Homey.
let me know the result.
Happy to see >100 installs of this app ![]()
I have updated the app with support for new devices en many languages.
(soon live)
Let me have your feedback!
Hi
Why is the intall app disable?
tor. 15. okt. 2026 kl. 19:06 skrev Rob Hagemann <notifications@athom.discoursemail.com>:
