[APP][PRO] Dyson Fans
It might be that they’ve fundamentally changed the mqtt protocol messages if it’s a new model. If that’s the case you could definitely help. Let me get back to you on that.
Hi all,
I managed to spend a lot of time last weekend on some significant code improvements which will hopefully help most of you with your connection issues. And if it doesn’t work for you yet we should now have a better chance of finding out why not.
New features:
  • Improved pairing process that will now:
    • Test the connection and provide information on issues
    • Allow you to manually set ip/port if connection fails for whatever reason
    • Allow you to manually test these settings and get feedback about connection issues.
  • New Repair method
    • Shows the currently configured ip/port
    • Allows you to change ip/port
    • Allows you to test the connection and get feedback about connection issues.
  • Improved logging and error handling
  • A LOT of smaller code improvements, Q/A and automated testing to improve quality and stability.
I would really appreciate it if some of you would test the new version. It will have to be installed manually until i publish the app to Live.
Especially those of you who have connection issues, please try if this version helps you get past them!
You can find the test version here:
Cheers,
Mark
Hallo ich habe ein Problem mit dem Dyson PC1 . Das Gerät hinzugefügt funktioniert ohne Probleme. Aber danach bekomme ich immer die Fehlermeldung Missing Capability listener . Ein Reparatur Versuch ist laut App immer erfolgreich. Dennoch bekomme ich immer wieder den Fehler. Kann mir vielleicht jemand weiterhelfen? Für euere Hilfe wäre ich sehr dankbar :folded_hands:
Gruß Michi
Hello everyone,
After about 20 days of testing things are still looking good. I have submitted the new version (1.1.0) for certification, after which it will be available for everyone.
Many thanks for the 30+ of you that took the time to install the test version!
Cheers,
Mark
Seems there is a bug with “then” cards. The “Set fan speed to …” card is no longer associated with a Dyson fan device. I’m getting a “Cannot read property of undefined” error message when my flow executes. The only available “then” cards for a Dyson device are now: Turn off, Turn on, Toggle on or off.
Hi Phillippe,
Thanks for reporting this! I have reproduced the issue and will probably have a fix later today which I will try to get published asap.
Cheers,
Mark
Version 1.1.1 with a bugfix for the issue with triggers and actions in flows has been submitted and will be available soon.
:+1: It is working well now, thank you for the prompt fix.
the dyson link fans also missing on/off capabilities.
question is the power on/ off supposed to work
I have tried this up on my two homies hp2019 and hp2023
no problems installing my heat and cool dyson, all controls work except power
all i get is this error
missing compatibility listener : on/off
Thanks for this app, it looks like it offers a lot more then the official app.
I have been trying to switch over from the official dyson app, but when I try to add a dyson fan I, I enter my account information, and the code sent through email on the next page.on the next step the setup freezes, the ‘next’ button is greyed out and I eventually get a time out error.
Any suggestions on what may cause this? Thanks in advance!
I seem to be having exactly the same issue
same error here it just freezes with the next button greyed out, would really appreciate some help
Is the app still supported? Only receive 401
Hello, thank you for your app, it’s really great, we’ve been waiting for it for so long. I have a Dyson DP02 and it’s recognized, but I can’t turn it on. I get the error message shown in the photo. Could you please help me? Thank you.
Hello, thank you for your app, it’s really great, we’ve been waiting for it for so long. I have a Dyson DP02 and it’s recognized, but I can’t turn it on. I get the error message shown in the photo. Could you please help me? Thank you. The error is : Missing capability listener : onoff
@1400 Hello Mark,
I’m using the PH04 Humidifiers and they work with the separate Dyson WiFi Android App. I was able to add them to my Homey Pro 2026 with your app, and they show up in my devices list after pairing and authenticating via your app. However, they display with a red error triangle :red_triangle_pointed_up: and your app tells me to repair the connection.
When I attempt the repair, I am given this feedback:
{“ok”: false, “reason”:“UNKNOWN”, “errorCode”
:“ECONNRESET”, “errorMessage”:"read
ECONNRESET"}
What can be done to rectify this? Is there some sort of authentication failure point? Any help is appreciated. Thanks.
I have the same issue. Any suggestions?
Hello everyone,
I also can not seem to get my Dyson Purify PC1 working. (I got it Monday so it never worked)
I can add it. And and if test or repair it says is my connection is oké. But I get the Missing Capability Listener: onoff error and also continues reconnecting/ losing
The official Dyson app for homey js also not working.
The MyDyson app is. But of course I want to make flows. :wink:
But I admit I have an old homey (2019 v13.2.3)
Same, this nor the official dyson app works, for me at least
