Arie do we need to reselect capability ?
after re-selecting
Thank you.
after re-selecting
Thank you.
No, not really, the ID in the background is still the same.
You only need to re-select it if you want the cool real property name visual in the floweditor ![]()
Is it possible to get the zone name in a tag when using the card Get Insights from 0 minutes ago flowcard? This makes it easier to create a uniform logging card.
@Jeroen_W Sure! Please create a feature/support ticket (link at the top post).
Thanks!
I have the problem that the order of the fields in the creation does not match the order on the map. I want to put the values (day, week) next to each other. The fields were created in the order I want them, but they are then out of order on the map. It would be helpful to be able to assign the order of the fields on the map.
i’m back:
this should work right? because right now it doesn’t. either it does not allow text (because the dropdown contains stuff like “less then” and “greater then”) or it needs to be exactly the value is “Hoofdstraat 44”
if it is exact… could a dropdown option “contains” be added ?
Yes, a way to sort is on the todo list and i have already started with it, but this one takes time to develop correctly, i hope it will be done in the next 2 weeks.
Sure! Please create a feature ticket. Thanks!
Hi Arie,
Since some time now (at least since 05/06) my H23-system is quite unstable and I think it is related to my AVD’s. Either they are;
I am searching and searching to pinpoint the problem(s), but until now am not able to get this done. What is rather frustrating in the process is the fact that the app crashes randomly/continuously wile working with the different AVD’s to change some parameters. I think this is because of the Athom-imposed RAM-restriction concerning apps.
Attached are some screens of the system load.
I also have some concrete questions as I suspect the system-stress might be related to these AVD’s in particular.
Attached are some examples.
I hope to get some leads as of where to continue my search. Thanks in advance.
If you need more info, let me know.
To all you questions: yes you can.
When the app crashes again, let me know when it happends, so i can see if there is a crash log.
This and next week i don’t have much time at all, but after that, i hope to put more time in memory performance again for the DC app.
Simply provide debug log when/right after app crashes ![]()
I am unsure what you mean by this?
Each up and down line is a crash?
And i am wondering why you app uses more than 100mb at all.
DC/AVD that uses reflection, uses a lot of memory. But i haven’t seen that much memory usage at all.
I guess you indeed are crosing the MB limit set by Homey.
I still use the “old” athom-api, instead of the new homey-api. Once homey-api is working correct with the insights, i hope to migrate it. Hopefully, using capability-listeners (reflection) will use less memory than.
Yes they are, unfortunately. Or more precisely, I think strictly speaking they are not real app-crashes (sometimes I do, but most of the time I do not get the red crash alert in the app-list). Rather than that, the spikes correspond to the app getting unresponsive resulting in the devices getting offline. I guess at this point the app gets killed by Homey due to the high memory usage.
As you can imagine, I am tinkering on the high memory usage myself.
As stated, I really enjoy using the app to create elaborate AVD’s trying to both streamline and expand my automations wile at the same time - in the context of a lacking dashboard - improving overview by grouping related stuff.
But if reflection is indeed the reason for the high memory usage I should seriously reconsider the use of this killer-feature.
I doubt if its even possible to give a straightforward answer on such a broad question, but would you think using regular advanced flows to get the same outcome would result in a smaller memory footprint altogether? Than maybe I should revert back to a traditional structured approach and use reflection sparsely for some exceptions. (This would really be unfortunate as I put a lot of effort in the process already. And wile the memory issue is rather frustrating - to the point of getting inevitable - I was otherwise very pleased in the outcome.)
For now, I will at least pause the further conversion/rebuilding of my old devices/flows.
Yup, from what I know is, Pro 201x pauses/kills all apps using over 80MB for x minutes
For Pro 2023 I’m not sure, probably 140, 150 MB, like your graphs show.
I have some issues with the “Listen card”, the User and Client always returns “blank”, is this a known issue with HP2023? (FW.Rc133) It worked flawlessly with HP 2029, but now i can not set “from app” or “from Web” and so on, because it returns a blank tag.
Kind regards
Marius
I had the same. @Arie_J_Godschalk recommended to use the Get Insights from 0 minutes ago flowcard that worked perfect for me.
Its an Advanced Flow only Then card.
I do have advanced flow, @Arie_J_Godschalk . Last picture.
Edit: Found it.
That card also returns tags which is blank.
