[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
@Patrick_Meijer yeah Enyaq is not working as should.
Its a total different API
Will try to update to api v3 soon and see if that works :slight_smile:
Hi Martijn, Audi etron works with 1.13.2
Many thanks for your very fast support.
New app update (LIVE: 1.13.3)
Changelog:
  • NEW: update library (New API)
  • FIX: API error
Changelog:
  • FIX: API error
Changelog:
  • FIX: API error
Changelog:
  • FIX: API error
Changelog:
  • FIX: API error
More - apps - AppName - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Is there somebody who wants to share his/her Enyaq with me?
So I can check if I can update to API v3?
New app update (TEST: 1.14.1)
Changelog:
  • NEW: Make force refresh configurable (All cars)
  • NEW: Settings: Radius for is_home (All cars)
  • NEW: Settings: option to disable lock/unlock button behaviour (All cars)
  • NEW: Settings Option to set negative inspection values (All cars)
  • NEW: Add charging power (KW) (ID, CUPRA, E-TRON)
  • NEW: Add charging rate (KM per hour) (ID, CUPRA, E-TRON)
  • NEW: Add estimated range (EV / Hybrid) (Calculated as Range/SOC=Max range e.g.: 275km/0,87=316km)
Changelog:
Changelog:
Changelog:
Changelog:
You can install the TEST version by clicking the link above and press install
Don’t want to be part of this TEST version? Install the LIVE version → vwAudiSkodaSeatCupra
@Aleksander_Stalsberg added the requested feature (it’s in device settings).
See post above for update and test link
Amazing response! That should be Just what I wanted.
And found the correct app now, thanks! Will give the test version a go!
Start/Stop battery charge stopped working on my E-Up with version 1.14.X. Still works with version 1.13.4
Will check @braekk
@braekk can you send a diagnostic report from 1.14 (after you starte remote_battery)? Don’t see anything what can be related to the remote controls.
Yes. I’ll do that once the car is at home and plugged in again!
Thanks a lot :smiley:
I will share my Enyaq with you.
@Patrick_Meijer Thanks!
Hi Martijn,
same on eGolf today - sending diag - 75002fb4-5b37-4019-af58-3411b875911c
Found the issue in the test version and will make a fix tomorrow :smiley:
@Sharkys @braekk It’s fixed in the latest test version
@Bug changed the is_home radius to steps of 0.01 KM :slight_smile:
Is this in version 1.14.2 already? As in that version it is still 1-9999KM. Even when in Nairobi Kenia at 9999KM the car would still show at home :sweat_smile:
haha yeah didn’t want to set any limits :stuck_out_tongue:
@Bug fixed the radius
