[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
Would it be possible to add a WHEN-card for “Getting home” so it it’s possible to have that as a trigger?
@Bug sure will check tomorrow :slight_smile:
@koolla theres a Is home changed card. There you can add a and card later :slight_smile:
@martijnpoppen maybe you can also check the other values that stopped updating for the Golf GTE as well:
Range KM
Is home (obviously not working when location is not updating)
Plug connected y/n
Charge time remaining Min
Charge current A
Minimum charge limit %
And of course Lat and longitude
What still is updating is
Total distance
Service days (and km but did not drive far enough to see)
Is charging
Battery level
What never seems to update (for months)
Fuel level (only for 2018+ models so it seems)
Oil change (stale value of 1700KM and 17 days) >> on wishlist for calculation from inspection days/KM
Connected to API (but that one is expected I guess)
Is moving
Climatization time remaining (always 0)
Oil level
Climatization is on. (Hope you’re able to find the correct value on the golf GTE to make this work. On wishlist as well I think)
You still have access I believe so should be ok to test.
Thanks again for your help and response :+1:t2:
@bug
If all of that is not working you might want to check if the car is added correctly.
Can you check the type in the device settings?
And only on the test version or on the live version of the app?
I got the same since yesterday I belive, I got the ID.3. App just updated to v1.12.3
I did make a report for you. 2930330d-72dc-43c6-aa55-c0a01260da65
@tumtum100 same what exactly? :stuck_out_tongue:
Resterende laattijd, actieradius, totale gereden afstand, laadoel update niet.
Only battery percentage is updating so far I can see.
@tumtum100 do you have the same on the live version of the app?
There are no issues with the ID cars currently. And it uses a different API
Thank you for your fast reply, i installed the live version: v1.11.4. It is working now. It was my own fault sorry.
Guess there are multiple issues in the app due to the typo. New fix will come up this evening or tomorrow :sweat_smile:
The bottom ones in the list are left from the development era of the VW app. They could be removed if not updating (would still want the climatization on to start working :wink:)
The type is vwv2
The app version is the one pushed from the atom repository v1.12.3 “experimental” but that last bit was there for a long time already :wink:
The ones in the top part were working fine until yesterday.
Hi Martijn, no sure if it includes"Is moving" status for eGolf but it’s also not working anymore - 9488b100-5c83-4031-990d-a2ccb276706c
@Sharkys [APP][Pro] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra - #1358 by martijnpoppen
New app update (test: 1.12.4)
Changelog:
  • NEW: Lock/Unlock for ID/E-tron/Cupra cars
  • NEW: IsHome for ID/E-tron/Cupra Cars
  • NEW: improve device pairing - error messages
  • NEW: improve device pairing - S-PIN after car selection
  • FIX: lock/unlock status
  • FIX: Show warning when lock/unlocking for ID (not supported (yet))
  • FIX: isHome for ID/E-tron/Cupra cars
  • FIX: remaining climate time for old API
  • FIX: typo
Changelog:
  • FIX: Access token issue
  • FIX: typo
Changelog:
  • FIX: Skoda app crash
  • FIX: typo
Changelog:
  • FIX: typo
  • FIX: typo
More - apps - AppName - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → vwAudiSkodaSeatCupra
Issue with not upating values (in the test version of the app) should be resolved
@Bug for the other values I’ll investigate :slight_smile: but at least the ones which were broken due to the update should work again
Is home and location works good now with VW ID.3.
Nice!! :smiley:
@Bug
Did some investigation the values you mentioned:
Climatisation:
 "status": {
                "climatisationStatusData": {
                    "climatisationState": {
                        "timestamp": "2023-01-07T21:17:14Z",
                        "content": "off"
                    "climatisationStateErrorCode": {
                        "content": 0
                    "remainingClimatisationTime": {
                        "content": 0
                    "climatisationReason": {
                        "content": "invalid"
Looks like it’s coming back, but might be this is not updating at all… :confused:
Yep, I will go to the todo list soon to get new functionality in the app. :slight_smile:
Should be working :
 "position": {
            "isMoving": false,
            "heading": {
                "direction": 0
            "carCoordinate": {
                "latitude": REDACTED,
                "longitude": REDACTED
This is indeed not coming trough, will remove it from the Hybrid car
I see it on 100%, but might also be the battery percentage… But battery is on 3% at the moment. Is that correct? Otherwise I have to remove fuel too, as it doesnt update. But it’s coming back though…
"field_0x030103000A": {
                    "id": "0x030103000A",
                    "tsCarSentUtc": "2023-01-08T09:23:25Z",
                    "tsCarSent": "2023-01-08T10:23:28",
                    "tsCarCaptured": "2023-01-08T10:23:28",
                    "tsTssReceivedUtc": "2023-01-08T10:23:28Z",
                    "milCarCaptured": 197837,
                    "milCarSent": 197837,
                    "value": 100,
                    "unit": "%",
                    "textId": "fuel_level_ok"
