[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
@martijnpoppen unfortunately there is no data shown in the app yet. Maybe the values are not aligned but I only see “-“ and “?” On the battery soc page. Please let me know if you require any additional info.
@Bug If you start the homey app with homey app run it will show you the logs.
If you can share those logs with me in a DM would be nice :slight_smile:
@martijnpoppen send you a DM. the charge now function returns “Missing Capability Listener: remote_batery_charge” in the app as well (and does not show anything in the log)
Thanks will check @Bug
So got some data from some of you.
seems like every car displays it’s data differently. I’ll check what needs to be done per car. But maybe I’ll have to change the way the app is build up now.
Will come with an update later :slight_smile:
I just can’t seem to get the app running for the life of me.
My own app is working via CLI.
Tried re-installing homey-cli, rebooting computer.
Tried googling the error but no solution found.
https://community.homey.app/t/volkswagen-we-connect/34493/220?u=peltsi51
I have some custom npm install scripts in the repo which allows to interact with the IoBroker adapter
So indeed a extra npm i should fix it
@martijnpoppen It seams that it wont update any of the values after login… Tried to remove and add again same thing gets all the values but then nothing… Now 9h later and 2 drives with the car nothing new is registered in the app…
@Peter_Johansson Hmm I’ll check that. Saw that too. Can you try to add the S-PIN? When I added that it did update for me.
@martijnpoppen is support for Skoda on the roadmap?
@reyntjensw Yes sure. But it might take a while to implement.
see: Volkswagen We Connect - #151
It didn’t.
I manually created an package.json inside com.wevolkswagen.connect\node_modules@iobroker\adapter-core
It’s working now, thanks!
Tried the S-PIN but it wouldnt do anything with the values on my car…
@Peter_Johansson :frowning:
I’ll take it along it the new update
FYI:
Athom was so kind to allow the app to the test channel.
So no need for CLI installs anymore :tada:
Awesome!!
Hmm, downloaded the app but I get stuck after entering the s-pin (not 100% it is correct though, but 99%). When S-Pin is entered and I click next, I get stuck at “Loading”. Is S-pin mandatory input?
S-PIN is not mandatory. Can you send a diagnostic report?
Please note that ID3 is far from done. I checked with @peltsi51 and saw that the API is different from the old VW connect.
I’ll compare the differences and probably have to come up with extra logic specifically for ID.
So proably after pairing you’ll get stuck. :cry:
Ah, that explains it. Let me see if I can pull a log, otherwise, continue in a suitable pace and according to your plan!
