[APP][Pro] Deco & Internet Monitor - Local monitoring of TP-Link Deco Wi-Fi, ISP box and Internet quality (no cloud)
Monitor your home network locally, without any cloud service: Internet quality, your ISP box and your TP-Link Deco mesh Wi-Fi become Homey devices, with Insights charts and Flow cards. Read-only: the app never changes any setting on the box or the Deco.
Test version: Deco & Internet Monitor | Homey
Source code (GPL-3.0): GitHub - Pepane13/homey-deco-internet-monitor · GitHub
:globe_with_meridians: Internet quality
  • Connectivity probes every 30 s to several targets (Cloudflare, Google, Quad9): latency, jitter, packet loss
  • LAN latency to the box (tells a local problem from an Internet outage) and DNS resolution time
  • Periodic speed test: run by the Livebox itself (full line speed, not capped by Homey’s Ethernet port) or from Homey (Cloudflare), with automatic fallback
  • Confirmed outages counted with their duration (no false alarm on a single failed probe)
  • Threshold alerts (download, upload, latency, jitter, loss) raised and cleared only after several consecutive measurements
:package: Internet box
Choose your provider before pairing:
  • Orange / Sosh: Livebox 4, 5, 6, 7
  • Bouygues Telecom: Bbox
  • SFR: SFR Box
Internet link state, public IP, connection and box uptime; real-time traffic (Livebox, Bbox); fibre optical power and native speed test (Livebox).
:antenna_bars: TP-Link Deco
  • One device per node, with its IP, role, model and firmware in the settings
  • Online state and connected clients per node; on the main Deco, clients per band (2.4 / 5 GHz / wired), CPU and memory
  • Client traffic per node, plus an “Average traffic” ↓/↑ indicator you can show on the tile
  • Wireless backhaul signal and speed for satellites
:high_voltage: Flow cards
Triggers: Internet went down / is back (with outage duration), speed test finished / failed, quality degraded / back to normal, box link down / back, connection renewed, box rebooted, public IP changed, fibre signal low / back to normal, Deco offline / online, mesh backhaul weak / back to normal, a device connected / disconnected.
Conditions: Internet available, connection quality good, box link up, Deco online, a device (name, IP or MAC) connected anywhere on the mesh.
Actions: run a speed test (also as an advanced card returning the results as tokens).
:warning: Good to know
  • Deco: the owner account is required. The Deco refuses manager accounts for local access, and each login closes the owner session in the Deco mobile app. Create a manager account for the mobile app and keep the owner account for Homey.
  • Homey Pro (Early 2023) has a 100 Mbit/s Ethernet adapter: speed tests run from Homey cannot exceed ~94 Mbit/s. The Livebox speed test has no such limit.
  • Latency is measured as the TCP handshake time (Homey apps cannot send ICMP pings), which closely follows a classic ping.
  • Some Deco firmwares (e.g. some Deco S7) use an older login protocol that is not supported yet.
:folded_hands: Testers wanted
Developed and tested on an Orange Livebox 5 + TP-Link Deco mesh. Bbox and SFR Box support is implemented from their local APIs but has not been tested on real hardware yet: if you own one, your feedback is very welcome.
Feedback, bugs and ideas: reply in this topic or open an issue on GitHub.
Version 1.1.0 is available (test channel, certification requested)
  • Diagnostic log and settings page: device status, log levels, copy, report export
  • Timeline notifications, switchable per category, and a daily summary
  • New Insights curves: Internet link quality (%) and box speed tests on the box device; latency and jitter from Homey to every Deco
  • Latency alerts now indicate whether the delay originates on the local network or on the Internet side
  • Implausible traffic samples from the box counters are discarded
